Hi!:
For various days now, I'm getting the following errors when I run sudo apt update:
Err:12 http://www.gtlib.gatech.edu/pub/MX-Linu ... ce/mx/repo buster InRelease
Could not connect to www.gtlib.gatech.edu:80 (2610:148:1f00:6f00:216:36ff:fe8e:1308). - connect (113: No route to host) Could not connect to www.gtlib.gatech.edu:80 (128.61.111.11). - connect (111: Connection refused) Could not connect to www.gtlib.gatech.edu:80 (2610:148:1f00:6f00:250:56ff:fe92:434b). - connect (113: No route to host) Could not connect to www.gtlib.gatech.edu:80 (128.61.111.7). - connect (111: Connection refused) Could not connect to www.gtlib.gatech.edu:80 (2610:148:1f00:6f00:216:36ff:fee9:2178). - connect (113: No route to host) Could not connect to www.gtlib.gatech.edu:80 (128.61.111.10). - connect (111: Connection refused) Could not connect to www.gtlib.gatech.edu:80 (128.61.111.. - connect (111: Connection refused) Could not connect to www.gtlib.gatech.edu:80 (128.61.111.9). - connect (111: Connection refused) Could not connect to www.gtlib.gatech.edu:80 (2610:148:1f00:6f00:21b:24ff:fe1d:e940), connection timed out Could not connect to www.gtlib.gatech.edu:80 (2610:148:1f00:6f00:20c:29ff:fe3c:63a8), connection timed out
I can connect to other repositories w/o problems. Am I be missing important updates because of the above? Please, advice. Thanks.
[Solved]Unable to connect to repo
- williepabon
Mac Mini, Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz, 16 Gig RAM, OS: OSX Catalina in dual boot with Ubuntu 20.04.1 LTS
Re: Unable to connect to repo
Could be that that MX repo mirror is down. Open MX Repo Manager, and in the first tab, MANUALLY SELECT another mirror (ie, don't click on "Select Fastest Mirror" button at the bottom).williepabon wrote: ↑Sun Nov 01, 2020 11:19 pm Hi!:
I can connect to other repositories w/o problems. Am I be missing important updates because of the above? Please, advice. Thanks.Code: Select all
Err:12 http://www.gtlib.gatech.edu/pub/MX-Linux/workspace/mx/repo buster InRelease Could not connect to www.gtlib.gatech.edu:80 (2610:148:1f00:6f00:216:36ff:fe8e:1308). - connect (113: No route to host) Could not connect to www.gtlib.gatech.edu:80 (128.61.111.11). - connect (111: Connection refused) Could not connect to www.gtlib.gatech.edu:80 (2610:148:1f00:6f00:250:56ff:fe92:434b). - connect (113: No route to host) Could not connect to www.gtlib.gatech.edu:80 (128.61.111.7). - connect (111: Connection refused) Could not connect to www.gtlib.gatech.edu:80 (2610:148:1f00:6f00:216:36ff:fee9:2178). - connect (113: No route to host) Could not connect to www.gtlib.gatech.edu:80 (128.61.111.10). - connect (111: Connection refused) Could not connect to www.gtlib.gatech.edu:80 (128.61.111.8). - connect (111: Connection refused) Could not connect to www.gtlib.gatech.edu:80 (128.61.111.9). - connect (111: Connection refused) Could not connect to www.gtlib.gatech.edu:80 (2610:148:1f00:6f00:21b:24ff:fe1d:e940), connection timed out Could not connect to www.gtlib.gatech.edu:80 (2610:148:1f00:6f00:20c:29ff:fe3c:63a8), connection timed out
I suggest the Utah or Milan mirror.
Then do another
sudo apt update
and let us know if it's ok now.
hello williepabon and asqwerth
checking the mirrors here
indicates you might switch to umd, rit, or waterloo (?) for making possible update indicating upgradable packages.
http://rsync-mxlinux.org/mirmon/packages.html
can check the mirrors when things are unusual.
- williepabon
Hello i_ri, asqwerth:
Thanks for answering. You guys solved my problem. Changed to the New York repo and that did it. Thanks again.
