Lets duplicate the right circle (Ctl +D), Then select create circle, ellipse tool in left toolbar (F5). You will see two buttons bellow top menubar, one swich to segment and other swich to arc may be deactivate stage, But in your circle you find 3 dots, and by dragging them you convert them to a segment or arch type.Then Select both shapes by Dragging mouse on both or shift click on each element, now click on path, object to path and now both elements are path now, and selecting both click on division and it will devide the paths and you get two elements, one will be that arch needed and delete the other oneasqwerth wrote: ↑Wed May 23, 2018 12:05 am
Thanks for the tips.
However, by curved "C", I mean the light brown outline to the immediate left of the oval shape. See red arrow in the pic below. It's part of the same layer as the oval. I clicked on the "C" and tried to stretch, tweak and pull it, but just couldn't get it to follow exactly the curvature of the oval. Would appreciate some guidance on this.
I have attached one file above (download/file.php?id=12004&mode=view) with capsule cell but circle for balance is left in a gesture. may i completely remove the right circle and put a round edge rectangle?
