Conky CPU temperature issue - SOLVED
tascoast
Re: Conky CPU temperature issue
#31
Post by tascoast » Sun Jan 28, 2018 4:54 am
I've tried looking at the MX-17 Conky. I can make occasional sense of color/formatting via html, while picking out the odd command to get info for conky to display.
Terminal output
$ sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0:       +43.0°C  (high = +76.0°C, crit = +100.0°C)
Core 1:       +44.0°C  (high = +76.0°C, crit = +100.0°C)
Terminal output
$ sensors | grep 'Core 0'
Core 0:       +42.0°C  (high = +76.0°C, crit = +100.0°C)
For the extract from the MX Conky text file below,
# CPU
${voffset -8}${font Open Sans:Bold:size=10}${color0}CPU ${color EC0100}${hr 3}
$color${font}Intel® Xeon® Processor E3-1241 ${freq_g cpu0}GHz $alignr $cpu%
${font}Core 0 ${color3}${execi 4 sensors | grep 'Core 0' | cut -c18-24} ${alignc 60}${color2}${cpubar cpu0}${color}
${font}Core 1 ${color3}${execi 4 sensors | grep 'Core 1' | cut -c18-24} ${alignc 60}${color2}${cpubar cpu1}${color}
I have deleted the surplus CPUs, being a twin core machine (inxi at bottom).
It appears that Terminal recognises grep but that Conky fails to obtain and/or display the output of the the commands in my case (blue highlight).
Perhaps I need to substitute a different command or alter some adjacent parameters but that's just guesswork after reading this thread.
System:    Host: mx1 Kernel: 4.13.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Machine:   Device: desktop System: LENOVO product: 7522RU3 v: ThinkCentre A58 serial: N/A
           Mobo: LENOVO model: N/A serial: N/A BIOS: LENOVO v: 5HKT52AUS date: 07/15/2010
CPU:       Dual core Intel Core2 Duo E7300 (-MCP-) cache: 3072 KB
           clock speeds: max: 2670 MHz 1: 1603 MHz 2: 2403 MHz
Graphics:  Card: Intel 4 Series Integrated Graphics Controller
           Resolution: 1680x1050@59.88hz
           OpenGL: renderer: Mesa DRI Intel G41 version: 2.1 Mesa 13.0.6
Audio:     Card Intel NM10/ICH7 Family High Def. Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.13.0-1-amd64
Network:   Card: Marvell 88E8057 PCI-E Gigabit Ethernet Controller driver: sky2
           IF: eth0 state: down mac: 00:01:6c:48:1a:77
Drives:    HDD Total Size: 1000.2GB (44.1% used)
           ID-1: /dev/sda model: WDC_WD10EZEX size: 1000.2GB
Partition: ID-1: / size: 34G used: 6.2G (20%) fs: ext4 dev: /dev/sda7
           ID-2: /home size: 31G used: 3.0G (11%) fs: ext4 dev: /dev/sda6
           ID-3: swap-1 size: 4.29GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 46.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 175 Uptime: 1:13 Memory: 864.8/3920.8MB Client: Shell (bash) inxi: 2.3.54
#32
Post by asqwerth » Sun Jan 28, 2018 5:38 am
Conky seems to use things like sed and awk to extract the text from the exec-ed commands but I'm not into scripting.
This possibly might also work in conky: acpitemp
Or or might not.
https://ubuntuforums.org/showthread.php?t=1744012
tascoast
#33
Post by tascoast » Sun Jan 28, 2018 6:50 am
I googled and decided to just change numbers until I was seeing two different temperature readings of similar magnitude.
I don't really understand the numbers I changed or the logic of, simply trying various....using 3 to get the other cpu temp output was the winning guess.
I think I now have each CPU's temp sensors showing. It looks quite suitable to me at least, and a simplified coding of sorts, in keeping with the output style of the conky.
# CPU
${font}Core 0 ${color3}${hwmon 0 temp 2}C ${alignc 60}${color2}${cpubar cpu0}${color}
${font}Core 1 ${color3}${hwmon 0 temp 3}C ${alignc 60}${color2}${cpubar cpu1}${color}
*Note it is currently quite warm mid Summer here after temperatures of around 30C.
Eadwine Rose
#34
Post by Eadwine Rose » Sun Jan 28, 2018 8:10 am
Those are nice temps for an Intel processor!
MX-18.3_x64 May 26 2019 * 4.19.0-5-amd64 ext4 Xfce 4.12.3 * 8-core AMD Ryzen 7 2700
Asus TUF B450-Plus Gaming UEFI * Asus GTX 1050 Ti Nvidia 390.116 * 2x16Gb DDR4 2666 Kingston HyperX Predator
Samsung 860EVO * Samsung S24D330 & P2250 * HP Envy5030
tascoast
#35
Post by tascoast » Mon Jan 29, 2018 8:12 am
Eadwine Rose wrote:Those are nice temps for an Intel processor!
I'm getting 38C and 34C on a much cooler evening with light rain lingering after heavier falls during the day.
I don't know if one CPU is shouldering more load or if it's simply thermodynamics and slight cooling differences, or even if the sensors are calibrated and reliable.
Could I be running it hotter perhaps, if inclined :car: ?
FWIW my other machine did not respond to the preceding code change, so presumably other CPU design again.
rickc
Re: Conky CPU temperature issue - SOLVED
#36
Post by rickc » Mon Jan 29, 2018 2:29 pm
Thanks all for the help
I've marked this as solved - basically the answer is lots of scripting patience, ie trying different stuff with the conkyrc until you get it right.
