Pinta makes Problems by INstallation on MX18.3
vvm
#1 Post by vvm »
Hi Altogether,e
I cannot install Pinta
on my HP-Notebook with MX 18.3,
trere is an ErrorMessage in Terminal.
root@MX:/home/vvm# apt install pinta -y
Reading package lists... Done
Building dependency tree
 pinta : Depends: libgtk2.0-cil (>= 2.12.10-1ubuntu1) but it is not going to be installed
         Depends: libmono-addins-gui0.2-cil (>= 1.0) but it is not going to be installed
root@MX:/home/vvm#
Thanks in Advance
vvm
JayM
Qualified MX Guide
Re: Pinta makes Problems by INstallation on MX18.3
#2 Post by JayM »
Please run MX Tools/Quick System Info, then right-click paste into a reply. (Quick System Info automatically copies the information to the clipboard and formats it properly for the forum so all you have to do is paste it.) Thanks.
vvm
#3 Post by vvm »
JayM thanks for your Answer,
here is SystemInfo:
  Host: MX Kernel: 4.14.0-3-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
  Desktop: Xfce 4.12.3 Distro: MX-18.3_x64 Continuum Feb 9  2019
  Type: Laptop System: HP product: HP Laptop 17-ak0xx
  v: Type1ProductConfigId serial: <filter>
  Mobo: HP model: 8345 v: 41.25 serial: <filter> UEFI [Legacy]: Insyde
  v: F.04 date: 06/09/2017
  ID-1: BAT0 charge: 40.6 Wh condition: 40.6/40.6 Wh (100%)
  model: 133-42-6E-A JC04041 status: Full
  Topology: Dual Core model: AMD A9-9420 RADEON R5 5 COMPUTE CORES 2C+3G
  bits: 64 type: MCP arch: Excavator L2 cache: 1024 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 11977
  Speed: 1397 MHz min/max: 1400/3000 MHz Core speeds (MHz): 1: 1397 2: 1397
  Device-1: AMD vendor: Hewlett-Packard driver: N/A bus ID: 00:01.0
  Display: x11 server: X.Org 1.19.2 driver: ati,vesa
  unloaded: fbdev,modesetting,radeon resolution: 1920x1080~N/A
  OpenGL: renderer: llvmpipe (LLVM 7.0 128 bits) v: 3.3 Mesa 18.2.6
  Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
  bus ID: 00:01.1
  Device-2: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
  bus ID: 00:09.2
  Sound Server: ALSA v: k4.14.0-3-amd64
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  vendor: Hewlett-Packard driver: r8169 v: 2.3LK-NAPI port: 3000
  bus ID: 02:00.0
  Device-2: Realtek vendor: Hewlett-Packard driver: rtl8723de
  v: v5.1.1.8_21285.20171026 port: 2000 bus ID: 03:00.0
  Local Storage: total: 931.51 GiB used: 15.28 GiB (1.6%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
  ID-1: / size: 19.35 GiB used: 7.68 GiB (39.7%) fs: ext4 dev: /dev/sda6
  ID-2: /home size: 249.96 GiB used: 7.60 GiB (3.0%) fs: ext4 dev: /dev/sda7
  ID-3: swap-1 size: 4.38 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
  System Temperatures: cpu: 30.0 C mobo: 28.0 C
  1: deb http://la.mxrepo.com/antix/stretch stretch main
  1: deb http://ftp.de.debian.org/debian/ stretch-updates main contrib non-free
  1: deb http://ftp.de.debian.org/debian/ stretch main contrib non-free
  Active apt repos in: /etc/apt/sources.list.d/mono-official-stable.list
  1: deb https://download.mono-project.com/repo/ubuntu stable-bionic main
  1: deb http://ftp.halifax.rwth-aachen.de/mxlinux/packages/mx/repo/ stretch main non-free
  Active apt repos in: /etc/apt/sources.list.d/skype-stable.list
  1: deb [arch=amd64] https://repo.skype.com/deb stable main
  Processes: 190 Uptime: 2m Memory: 7.33 GiB used: 541.4 MiB (7.2%)
  inxi: 3.0.33
Report copied to system clipboard
Press any key to close
#4 Post by timkb4cq »
Mixing Ubuntu repos with Debian ones often leads to this kind of dependency issue. You apparently have replaced some of Debian's Mono packages with Ubuntu Bionic packages. The way to resolve this would be to force all the packages you installed from that repo back to the versions in MX/Debian.
If you installed a lot of them it could be easier to re-install.
vvm
#5 Post by vvm »
timkb4cq thanks for your message,
could you write a small HowTo for me.
Thanks in Advance
vvm
#6 Post by timkb4cq »
First you need to find out which packages you installed from that repo.
If you don't have aptitude installed, install it. Running
aptitude search "?origin (mono-project) ?installed"
will give you a list of the packages you need to revert. Copy & paste these into a text editor and edit the list so it just contains the package names separated by spaces. You'll be pasting that list into a command.
Next, disable the mono-project repo. Synaptic -> Settings -> Repositories is probably the easiest place to do so. Then Reload in Synaptic or sudo apt-get update from a terminal.
Then run
aptitude clean
aptitude reinstall <list of packages you just made>
(don't insert the <> brackets.)
That should do it, but if you get an error saying a particular package is not available to reinstall then retry the command leaving that package off the list. When the command succeeds run
aptitude purge <that-unavailable-package>
vvm
#7 Post by vvm »
Hi timkb4cq,
thanks for your Message,
I have done this command,
my PC does not have any such packages:
root@MX:/home/vvm# aptitude search "?origin (mono-project) ?installed"
root@MX:/home/vvm#
What is the next step??
Thank in Advice
vvm
#8 Post by Stevo »
Did you disable the mono-project repo as Tim requested?
vvm
#9 Post by vvm »
Stevo thanks for your Message,
no, I did not
I don't know,
how I can make it
vvm
JayM
Qualified MX Guide
#10 Post by JayM »
As Tim said (but in more detail), open System/ Synaptic Package Manager, go to Settings, click Repositories, find that Ubuntu repository that you added, click on it to select it, click the Delete button. (And don't add any more Ubuntu or Mint repos to MX, or any PPAs. :smile: )
