antiX-19-b1-full (64 and 32 bit) available
namida12
Re: antiX-19-b1-full (64 and 32 bit) available
#61 Post by namida12 »
Running again. have not done a Kernel update.
/var/log/Xorg.0.log , Time: Wed Jun 19 19:05:01 2019
[     6.483]
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[     6.483] Build Operating System: Linux 4.9.0-8-amd64 x86_64 Debian
[     6.483] Current Operating System: Linux antix2 4.9.176-antix.1-amd64-smp #1 SMP PREEMPT Thu May 16 14:48:01 EEST 2019 x86_64
[     6.483] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.176-antix.1-amd64-smp root=UUID=2f01a603-250a-4392-a126-81f875ed0d9a ro vga=791 quiet
[     6.483] Build Date: 05 March 2019  08:11:12PM
[     6.483] xorg-server 2:1.20.4-1 (https://www.debian.org/support)
[     6.483] Current version of pixman: 0.36.0
[     6.483] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[     6.483] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[     6.483] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jun 19 19:05:01 2019
[     6.483] (==) Using config file: "/etc/X11/xorg.conf"
[     6.483] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     6.483] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     6.485] (==) No Layout section.  Using the first Screen section.
[     6.485] (**) |-->Screen "Screen0" (0)
[     6.485] (**) |   |-->Monitor "Monitor0"
[     6.485] (**) |   |-->Device "Device0"
[     6.485] (==) Automatically adding devices
[     6.485] (==) Automatically enabling devices
[     6.485] (==) Automatically adding GPU devices
[     6.485] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     6.486] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[     6.486] 	Entry deleted from font path.
[     6.487] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[     6.487] 	Entry deleted from font path.
[     6.487] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[     6.487] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/100dpi/:unscaled,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	built-ins
[     6.487] (==) ModulePath set to "/usr/lib/xorg/modules"
[     6.487] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[     6.487] (II) Loader magic: 0x560a6bad8e20
[     6.487] (II) Module ABI versions:
[     6.487] 	X.Org ANSI C Emulation: 0.4
[     6.487] 	X.Org Video Driver: 24.0
[     6.487] 	X.Org XInput driver : 24.1
[     6.487] 	X.Org Server Extension : 10.0
[     6.487] (++) using VT number 7
[     6.487] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     6.489] (--) PCI:*(56@0:0:0) 1002:15dd:1002:15dd rev 200, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfe500000/524288, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[     6.489] (II) LoadModule: "glx"
[     6.490] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     6.492] (II) Module glx: vendor="X.Org Foundation"
[     6.492] 	compiled for 1.20.4, module version = 1.0.0
[     6.492] 	ABI class: X.Org Server Extension, version 10.0
[     6.492] (II) LoadModule: "vesa"
[     6.493] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[     6.493] (II) Module vesa: vendor="X.Org Foundation"
[     6.493] 	compiled for 1.20.1, module version = 2.4.0
[     6.493] 	Module class: X.Org Video Driver
[     6.493] 	ABI class: X.Org Video Driver, version 24.0
[     6.493] (II) VESA: driver for VESA chipsets: vesa
[     6.502] (II) Loading sub module "vbe"
[     6.502] (II) LoadModule: "vbe"
[     6.502] (II) Loading /usr/lib/xorg/modules/libvbe.so
[     6.503] (II) Module vbe: vendor="X.Org Foundation"
[     6.503] 	compiled for 1.20.4, module version = 1.1.0
[     6.503] 	ABI class: X.Org Video Driver, version 24.0
[     6.503] (II) Loading sub module "int10"
[     6.503] (II) LoadModule: "int10"
[     6.503] (II) Loading /usr/lib/xorg/modules/libint10.so
[     6.503] (II) Module int10: vendor="X.Org Foundation"
[     6.503] 	compiled for 1.20.4, module version = 1.0.0
[     6.503] (II) VESA(0): initializing int10
[     6.504] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[     6.504] (II) VESA(0): VESA BIOS detected
[     6.504] (II) VESA(0): VESA VBE Version 3.0
[     6.504] (II) VESA(0): VESA VBE Total Mem: 49152 kB
[     6.504] (II) VESA(0): VESA VBE OEM: AMD ATOMBIOS
[     6.504] (II) VESA(0): VESA VBE OEM Software Rev: 16.2
[     6.504] (II) VESA(0): VESA VBE OEM Vendor: (C) 1988-2010, Advanced Micro Devices, Inc.
[     6.504] (II) VESA(0): VESA VBE OEM Product: RAVEN
[     6.504] (II) VESA(0): VESA VBE OEM Product Rev: 01.00
[     6.516] (II) VESA(0): Creating default Display subsection in Screen section
	"Screen0" for depth/fbbpp 24/32
[     6.516] (==) VESA(0): Depth 24, (--) framebuffer bpp 32
[     6.516] (==) VESA(0): RGB weight 888
[     6.516] (==) VESA(0): Default visual is TrueColor
[     6.516] (==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
[     6.516] (II) Loading sub module "ddc"
[     6.516] (II) LoadModule: "ddc"
[     6.516] (II) Module "ddc" already built-in
[     6.516] (II) VESA(0): VESA VBE DDC supported
[     6.516] (II) VESA(0): VESA VBE DDC Level 2
[     6.516] (II) VESA(0): VESA VBE DDC transfer in appr. 1 sec.
[     6.576] (II) VESA(0): VESA VBE DDC read successfully
[     6.576] (II) VESA(0): Manufacturer: ACR  Model: 9a  Serial#: 2433786331
[     6.576] (II) VESA(0): Year: 2009  Week: 11
[     6.576] (II) VESA(0): EDID Version: 1.4
[     6.576] (II) VESA(0): Digital Display Input
[     6.576] (II) VESA(0): 8 bits per channel
[     6.576] (II) VESA(0): Digital interface is DisplayPort
[     6.576] (II) VESA(0): Max Image Size [cm]: horiz.: 51  vert.: 29
[     6.576] (II) VESA(0): Gamma: 2.20
[     6.576] (II) VESA(0): DPMS capabilities: StandBy Suspend Off
[     6.576] (II) VESA(0): Supported color encodings: RGB 4:4:4
[     6.576] (II) VESA(0): First detailed timing is preferred mode
[     6.576] (II) VESA(0): Preferred mode is native pixel format and refresh rate
[     6.576] (II) VESA(0): redX: 0.649 redY: 0.338   greenX: 0.289 greenY: 0.609
[     6.576] (II) VESA(0): blueX: 0.146 blueY: 0.070   whiteX: 0.313 whiteY: 0.329
[     6.576] (II) VESA(0): Supported established timings:
[     6.576] (II) VESA(0): 720x400@70Hz
[     6.576] (II) VESA(0): 640x480@60Hz
[     6.576] (II) VESA(0): 640x480@67Hz
[     6.576] (II) VESA(0): 800x600@56Hz
[     6.576] (II) VESA(0): 800x600@60Hz
[     6.576] (II) VESA(0): 1024x768@60Hz
[     6.576] (II) VESA(0): 1024x768@70Hz
[     6.576] (II) VESA(0): Manufacturer's mask: 0
[     6.576] (II) VESA(0): Supported standard timings:
[     6.576] (II) VESA(0): #0: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     6.576] (II) VESA(0): #1: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[     6.576] (II) VESA(0): #2: hsize: 1280  vsize 800  refresh: 60  vid: 129
[     6.576] (II) VESA(0): #3: hsize: 1440  vsize 900  refresh: 60  vid: 149
[     6.576] (II) VESA(0): #4: hsize: 1600  vsize 1200  refresh: 60  vid: 16553
[     6.576] (II) VESA(0): #5: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[     6.576] (II) VESA(0): Supported detailed timing:
[     6.576] (II) VESA(0): clock: 148.5 MHz   Image Size:  510 x 287 mm
[     6.576] (II) VESA(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     6.576] (II) VESA(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[     6.576] (II) VESA(0): Monitor name: X233H
[     6.576] (II) VESA(0): Ranges: V min: 56 V max: 76 Hz, H min: 31 H max: 83 kHz, PixClock max 185 MHz
[     6.576] (II) VESA(0): Serial No: LFM0C0234041
[     6.576] (II) VESA(0): EDID (in hex):
[     6.576] (II) VESA(0): 	00ffffffffffff0004729a00dba11091
[     6.576] (II) VESA(0): 	0b130104a5331d78e26085a6564a9c25
[     6.576] (II) VESA(0): 	125054b30c008180714f81009500a940
[     6.576] (II) VESA(0): 	d1c001010101023a801871382d40582c
[     6.576] (II) VESA(0): 	4500fe1f1100001a000000fc00583233
[     6.576] (II) VESA(0): 	33480a20202020202020000000fd0038
[     6.576] (II) VESA(0): 	4c1f5312000a202020202020000000ff
[     6.576] (II) VESA(0): 	004c464d3043303233343034310a0010
[     6.576] (II) VESA(0): EDID vendor "ACR", prod id 154
[     6.576] (II) VESA(0): Using EDID range info for horizontal sync
[     6.576] (II) VESA(0): Using EDID range info for vertical refresh
[     6.576] (II) VESA(0): Printing DDC gathered Modelines:
[     6.576] (II) VESA(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync -vsync (67.5 kHz eP)
[     6.576] (II) VESA(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     6.576] (II) VESA(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[     6.576] (II) VESA(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[     6.576] (II) VESA(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     6.576] (II) VESA(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     6.576] (II) VESA(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[     6.576] (II) VESA(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     6.576] (II) VESA(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     6.576] (II) VESA(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     6.576] (II) VESA(0): Modeline "1280x800"x0.0   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz e)
[     6.576] (II) VESA(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[     6.576] (II) VESA(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     6.576] (II) VESA(0): Searching for matching VESA mode(s):
[     6.576] Mode: 110 (640x480)
[     6.576] 	ModeAttributes: 0xbb
[     6.576] 	WinAAttributes: 0x7
[     6.576] 	WinBAttributes: 0x0
[     6.576] 	WinGranularity: 64
[     6.576] 	WinSize: 64
[     6.576] 	WinASegment: 0xa000
[     6.576] 	WinBSegment: 0x0
[     6.576] 	WinFuncPtr: 0xc0004cb5
[     6.576] 	BytesPerScanline: 1280
[     6.576] 	XResolution: 640
[     6.576] 	YResolution: 480
[     6.576] 	XCharSize: 8
[     6.576] 	YCharSize: 16
[     6.576] 	NumberOfPlanes: 1
[     6.576] 	BitsPerPixel: 16
[     6.576] 	NumberOfBanks: 1
[     6.576] 	MemoryModel: 6
[     6.576] 	BankSize: 0
[     6.576] 	NumberOfImages: 75
[     6.576] 	RedMaskSize: 5
[     6.576] 	RedFieldPosition: 10
[     6.576] 	GreenMaskSize: 5
[     6.576] 	GreenFieldPosition: 5
[     6.576] 	BlueMaskSize: 5
[     6.576] 	BlueFieldPosition: 0
[     6.576] 	RsvdMaskSize: 0
[     6.576] 	RsvdFieldPosition: 0
[     6.576] 	DirectColorModeInfo: 0
[     6.576] 	PhysBasePtr: 0xe0000000
[     6.576] 	LinBytesPerScanLine: 1280
[     6.576] 	BnkNumberOfImagePages: 75
[     6.577] 	LinNumberOfImagePages: 75
[     6.577] 	LinRedMaskSize: 5
[     6.577] 	LinRedFieldPosition: 10
[     6.577] 	LinGreenMaskSize: 5
[     6.577] 	LinGreenFieldPosition: 5
[     6.577] 	LinBlueMaskSize: 5
[     6.577] 	LinBlueFieldPosition: 0
[     6.577] 	LinRsvdMaskSize: 0
[     6.577] 	LinRsvdFieldPosition: 0
[     6.577] 	MaxPixelClock: 400000000
[     6.577] Mode: 111 (640x480)
[     6.577] 	ModeAttributes: 0xbb
[     6.577] 	WinAAttributes: 0x7
[     6.577] 	WinBAttributes: 0x0
[     6.577] 	WinGranularity: 64
[     6.577] 	WinSize: 64
[     6.577] 	WinASegment: 0xa000
[     6.577] 	WinBSegment: 0x0
[     6.577] 	WinFuncPtr: 0xc0004cb5
[     6.577] 	BytesPerScanline: 1280
[     6.577] 	XResolution: 640
[     6.577] 	YResolution: 480
[     6.577] 	XCharSize: 8
[     6.577] 	YCharSize: 16
[     6.577] 	NumberOfPlanes: 1
[     6.577] 	BitsPerPixel: 16
[     6.577] 	NumberOfBanks: 1
[     6.577] 	MemoryModel: 6
[     6.577] 	BankSize: 0
[     6.577] 	NumberOfImages: 75
[     6.577] 	RedMaskSize: 5
[     6.577] 	RedFieldPosition: 11
[     6.577] 	GreenMaskSize: 6
[     6.577] 	GreenFieldPosition: 5
[     6.577] 	BlueMaskSize: 5
[     6.577] 	BlueFieldPosition: 0
[     6.577] 	RsvdMaskSize: 0
[     6.577] 	RsvdFieldPosition: 0
[     6.577] 	DirectColorModeInfo: 0
[     6.577] 	PhysBasePtr: 0xe0000000
[     6.577] 	LinBytesPerScanLine: 1280
[     6.577] 	BnkNumberOfImagePages: 75
[     6.577] 	LinRedFieldPosition: 11
[     6.577] 	LinGreenMaskSize: 6
[     6.577] Mode: 113 (800x600)
[     6.578] 	BytesPerScanline: 1664
[     6.578] 	XResolution: 800
[     6.578] 	YResolution: 600
[     6.578] 	XCharSize: 8
[     6.578] 	YCharSize: 14
[     6.578] 	NumberOfPlanes: 1
[     6.578] 	BitsPerPixel: 16
[     6.578] 	NumberOfBanks: 1
[     6.578] 	MemoryModel: 6
[     6.578] 	BankSize: 0
[     6.578] 	NumberOfImages: 47
[     6.578] 	RedMaskSize: 5
[     6.578] 	RedFieldPosition: 10
[     6.578] 	GreenMaskSize: 5
[     6.578] 	GreenFieldPosition: 5
[     6.578] 	BlueMaskSize: 5
[     6.578] 	BlueFieldPosition: 0
[     6.578] 	RsvdMaskSize: 0
[     6.578] 	RsvdFieldPosition: 0
[     6.578] 	DirectColorModeInfo: 0
[     6.578] 	PhysBasePtr: 0xe0000000
[     6.578] 	LinBytesPerScanLine: 1664
[     6.578] 	BnkNumberOfImagePages: 47
[     6.578] 	LinNumberOfImagePages: 47
[     6.578] 	LinRedMaskSize: 5
[     6.578] 	LinRedFieldPosition: 10
[     6.578] 	LinGreenMaskSize: 5
[     6.578] 	LinGreenFieldPosition: 5
[     6.578] 	LinBlueMaskSize: 5
[     6.578] 	LinBlueFieldPosition: 0
[     6.578] 	LinRsvdMaskSize: 0
[     6.578] 	LinRsvdFieldPosition: 0
[     6.578] 	MaxPixelClock: 400000000
[     6.578] Mode: 114 (800x600)
[     6.578] 	ModeAttributes: 0xbb
[     6.578] 	WinAAttributes: 0x7
[     6.578] 	WinBAttributes: 0x0
[     6.578] 	WinGranularity: 64
[     6.578] 	WinSize: 64
[     6.578] 	WinASegment: 0xa000
[     6.578] 	WinBSegment: 0x0
[     6.578] 	WinFuncPtr: 0xc0004cb5
[     6.578] 	RedFieldPosition: 11
[     6.578] 	GreenMaskSize: 6
[     6.578] 	LinRedFieldPosition: 11
[     6.578] 	LinGreenMaskSize: 6
[     6.579] Mode: 116 (1024x768)
[     6.579] 	ModeAttributes: 0xbb
[     6.579] 	WinAAttributes: 0x7
[     6.579] 	WinBAttributes: 0x0
[     6.579] 	WinGranularity: 64
[     6.579] 	WinSize: 64
[     6.579] 	WinASegment: 0xa000
[     6.579] 	WinBSegment: 0x0
[     6.579] 	WinFuncPtr: 0xc0004cb5
[     6.579] 	BytesPerScanline: 2048
[     6.579] 	XResolution: 1024
[     6.579] 	YResolution: 768
[     6.579] 	XCharSize: 8
[     6.579] 	YCharSize: 16
[     6.579] 	NumberOfPlanes: 1
[     6.579] 	BitsPerPixel: 16
[     6.579] 	NumberOfBanks: 1
[     6.579] 	MemoryModel: 6
[     6.579] 	BankSize: 0
[     6.579] 	NumberOfImages: 29
[     6.579] 	RedMaskSize: 5
[     6.579] 	RedFieldPosition: 10
[     6.579] 	GreenMaskSize: 5
[     6.579] 	GreenFieldPosition: 5
[     6.579] 	BlueMaskSize: 5
[     6.579] 	BlueFieldPosition: 0
[     6.579] 	RsvdMaskSize: 0
[     6.579] 	RsvdFieldPosition: 0
[     6.579] 	DirectColorModeInfo: 0
[     6.579] 	PhysBasePtr: 0xe0000000
[     6.579] 	LinBytesPerScanLine: 2048
[     6.579] 	BnkNumberOfImagePages: 29
[     6.579] 	LinNumberOfImagePages: 29
[     6.579] 	LinRedMaskSize: 5
[     6.579] 	LinRedFieldPosition: 10
[     6.579] 	LinGreenMaskSize: 5
[     6.579] 	LinGreenFieldPosition: 5
[     6.579] 	LinBlueMaskSize: 5
[     6.579] 	LinBlueFieldPosition: 0
[     6.579] 	LinRsvdMaskSize: 0
[     6.579] 	LinRsvdFieldPosition: 0
[     6.579] 	MaxPixelClock: 400000000
[     6.579] Mode: 117 (1024x768)
[     6.579] 	RedFieldPosition: 11
[     6.579] 	GreenMaskSize: 6
[     6.579] 	LinRedFieldPosition: 11
[     6.579] 	LinGreenMaskSize: 6
[     6.580] Mode: 119 (1280x1024)
[     6.580] 	ModeAttributes: 0xbb
[     6.580] 	WinAAttributes: 0x7
[     6.580] 	WinBAttributes: 0x0
[     6.580] 	WinGranularity: 64
[     6.580] 	WinSize: 64
[     6.580] 	WinASegment: 0xa000
[     6.580] 	WinBSegment: 0x0
[     6.580] 	WinFuncPtr: 0xc0004cb5
[     6.580] 	BytesPerScanline: 2560
[     6.580] 	XResolution: 1280
[     6.580] 	YResolution: 1024
[     6.580] 	XCharSize: 8
[     6.580] 	YCharSize: 16
[     6.580] 	NumberOfPlanes: 1
[     6.580] 	BitsPerPixel: 16
[     6.580] 	NumberOfBanks: 1
[     6.580] 	MemoryModel: 6
[     6.580] 	BankSize: 0
[     6.580] 	NumberOfImages: 17
[     6.580] 	RedMaskSize: 5
[     6.580] 	RedFieldPosition: 10
[     6.580] 	GreenMaskSize: 5
[     6.580] 	GreenFieldPosition: 5
[     6.580] 	BlueMaskSize: 5
[     6.580] 	BlueFieldPosition: 0
[     6.580] 	RsvdMaskSize: 0
[     6.580] 	RsvdFieldPosition: 0
[     6.580] 	DirectColorModeInfo: 0
[     6.580] 	PhysBasePtr: 0xe0000000
[     6.580] 	LinBytesPerScanLine: 2560
[     6.580] 	BnkNumberOfImagePages: 17
[     6.580] 	LinNumberOfImagePages: 17
[     6.580] 	LinRedMaskSize: 5
[     6.580] 	LinRedFieldPosition: 10
[     6.580] 	LinGreenMaskSize: 5
[     6.580] 	LinGreenFieldPosition: 5
[     6.580] 	LinBlueMaskSize: 5
[     6.580] 	LinBlueFieldPosition: 0
[     6.580] 	LinRsvdMaskSize: 0
[     6.580] 	LinRsvdFieldPosition: 0
[     6.580] 	MaxPixelClock: 400000000
[     6.580] Mode: 11a (1280x1024)
[     6.580] 	RedFieldPosition: 11
[     6.580] 	GreenMaskSize: 6
[     6.580] 	LinRedFieldPosition: 11
[     6.580] 	LinGreenMaskSize: 6
[     6.581] Mode: 165 (1280x960)
[     6.581] 	ModeAttributes: 0xbb
[     6.581] 	WinAAttributes: 0x7
[     6.581] 	WinBAttributes: 0x0
[     6.581] 	WinGranularity: 64
[     6.581] 	WinSize: 64
[     6.581] 	WinASegment: 0xa000
[     6.581] 	WinBSegment: 0x0
[     6.581] 	WinFuncPtr: 0xc0004cb5
[     6.581] 	BytesPerScanline: 2560
[     6.581] 	XResolution: 1280
[     6.581] 	YResolution: 960
[     6.581] 	XCharSize: 8
[     6.581] 	YCharSize: 16
[     6.581] 	NumberOfPlanes: 1
[     6.581] 	BitsPerPixel: 16
[     6.581] 	NumberOfBanks: 1
[     6.581] 	MemoryModel: 6
[     6.581] 	BankSize: 0
[     6.581] 	NumberOfImages: 19
[     6.581] 	RedMaskSize: 5
[     6.581] 	RedFieldPosition: 11
[     6.581] 	GreenMaskSize: 6
[     6.581] 	GreenFieldPosition: 5
[     6.581] 	BlueMaskSize: 5
[     6.581] 	BlueFieldPosition: 0
[     6.581] 	RsvdMaskSize: 0
[     6.581] 	RsvdFieldPosition: 0
[     6.581] 	DirectColorModeInfo: 0
[     6.581] 	PhysBasePtr: 0xe0000000
[     6.581] 	LinBytesPerScanLine: 2560
[     6.581] 	BnkNumberOfImagePages: 19
[     6.581] 	LinNumberOfImagePages: 19
[     6.581] 	LinRedMaskSize: 5
[     6.581] 	LinRedFieldPosition: 11
[     6.581] 	LinGreenMaskSize: 6
[     6.581] 	LinGreenFieldPosition: 5
[     6.581] 	LinBlueMaskSize: 5
[     6.581] 	LinBlueFieldPosition: 0
[     6.581] 	LinRsvdMaskSize: 0
[     6.581] 	LinRsvdFieldPosition: 0
[     6.581] 	MaxPixelClock: 400000000
[     6.581] *Mode: 166 (1280x960)
[     6.581] 	BytesPerScanline: 5120
[     6.581] 	BitsPerPixel: 32
[     6.581] 	NumberOfImages: 9
[     6.581] 	RedMaskSize: 8
[     6.581] 	RedFieldPosition: 16
[     6.581] 	GreenMaskSize: 8
[     6.581] 	GreenFieldPosition: 8
[     6.581] 	BlueMaskSize: 8
[     6.581] 	LinBytesPerScanLine: 5120
[     6.581] 	BnkNumberOfImagePages: 9
[     6.581] 	LinNumberOfImagePages: 9
[     6.581] 	LinRedMaskSize: 8
[     6.581] 	LinRedFieldPosition: 16
[     6.581] 	LinGreenMaskSize: 8
[     6.581] 	LinGreenFieldPosition: 8
[     6.581] 	LinBlueMaskSize: 8
[     6.582] *Mode: 121 (640x480)
[     6.582] 	ModeAttributes: 0xbb
[     6.582] 	WinAAttributes: 0x7
[     6.582] 	WinBAttributes: 0x0
[     6.582] 	WinGranularity: 64
[     6.582] 	WinSize: 64
[     6.582] 	WinASegment: 0xa000
[     6.582] 	WinBSegment: 0x0
[     6.582] 	WinFuncPtr: 0xc0004cb5
[     6.582] 	BytesPerScanline: 2560
[     6.582] 	XResolution: 640
[     6.582] 	YResolution: 480
[     6.582] 	XCharSize: 8
[     6.582] 	YCharSize: 16
[     6.582] 	NumberOfPlanes: 1
[     6.582] 	BitsPerPixel: 32
[     6.582] 	NumberOfBanks: 1
[     6.582] 	MemoryModel: 6
[     6.582] 	BankSize: 0
[     6.582] 	NumberOfImages: 39
[     6.582] 	RedMaskSize: 8
[     6.582] 	RedFieldPosition: 16
[     6.582] 	GreenMaskSize: 8
[     6.582] 	GreenFieldPosition: 8
[     6.582] 	BlueMaskSize: 8
[     6.582] 	BlueFieldPosition: 0
[     6.582] 	RsvdMaskSize: 0
[     6.582] 	RsvdFieldPosition: 0
[     6.582] 	DirectColorModeInfo: 0
[     6.582] 	PhysBasePtr: 0xe0000000
[     6.582] 	LinBytesPerScanLine: 2560
[     6.582] 	BnkNumberOfImagePages: 39
[     6.582] 	LinNumberOfImagePages: 39
[     6.582] 	LinRedMaskSize: 8
[     6.582] 	LinRedFieldPosition: 16
[     6.582] 	LinGreenMaskSize: 8
[     6.582] 	LinGreenFieldPosition: 8
[     6.582] 	LinBlueMaskSize: 8
[     6.582] 	LinBlueFieldPosition: 0
[     6.582] 	LinRsvdMaskSize: 0
[     6.582] 	LinRsvdFieldPosition: 0
[     6.582] 	MaxPixelClock: 400000000
[     6.582] *Mode: 122 (800x600)
[     6.582] 	BytesPerScanline: 3328
[     6.582] 	XResolution: 800
[     6.582] 	YResolution: 600
[     6.582] 	YCharSize: 14
[     6.582] 	NumberOfImages: 23
[     6.582] 	LinBytesPerScanLine: 3328
[     6.582] 	BnkNumberOfImagePages: 23
[     6.582] 	LinNumberOfImagePages: 23
[     6.583] *Mode: 123 (1024x768)
[     6.583] 	ModeAttributes: 0xbb
[     6.583] 	WinAAttributes: 0x7
[     6.583] 	WinBAttributes: 0x0
[     6.583] 	WinGranularity: 64
[     6.583] 	WinSize: 64
[     6.583] 	WinASegment: 0xa000
[     6.583] 	WinBSegment: 0x0
[     6.583] 	WinFuncPtr: 0xc0004cb5
[     6.583] 	BytesPerScanline: 4096
[     6.583] 	XResolution: 1024
[     6.583] 	YResolution: 768
[     6.583] 	XCharSize: 8
[     6.583] 	YCharSize: 16
[     6.583] 	NumberOfPlanes: 1
[     6.583] 	BitsPerPixel: 32
[     6.583] 	NumberOfBanks: 1
[     6.583] 	MemoryModel: 6
[     6.583] 	BankSize: 0
[     6.583] 	NumberOfImages: 14
[     6.583] 	RedMaskSize: 8
[     6.583] 	RedFieldPosition: 16
[     6.583] 	GreenMaskSize: 8
[     6.583] 	GreenFieldPosition: 8
[     6.583] 	BlueMaskSize: 8
[     6.583] 	BlueFieldPosition: 0
[     6.583] 	RsvdMaskSize: 0
[     6.583] 	RsvdFieldPosition: 0
[     6.583] 	DirectColorModeInfo: 0
[     6.583] 	PhysBasePtr: 0xe0000000
[     6.583] 	LinBytesPerScanLine: 4096
[     6.583] 	BnkNumberOfImagePages: 14
[     6.583] 	LinNumberOfImagePages: 14
[     6.583] 	LinRedMaskSize: 8
[     6.583] 	LinRedFieldPosition: 16
[     6.583] 	LinGreenMaskSize: 8
[     6.583] 	LinGreenFieldPosition: 8
[     6.583] 	LinBlueMaskSize: 8
[     6.583] 	LinBlueFieldPosition: 0
[     6.583] 	LinRsvdMaskSize: 0
[     6.583] 	LinRsvdFieldPosition: 0
[     6.583] 	MaxPixelClock: 400000000
[     6.583] *Mode: 124 (1280x1024)
[     6.583] 	BytesPerScanline: 5120
[     6.583] 	XResolution: 1280
[     6.583] 	YResolution: 1024
[     6.583] 	NumberOfImages: 8
[     6.583] 	LinBytesPerScanLine: 5120
[     6.583] 	BnkNumberOfImagePages: 8
[     6.583] 	LinNumberOfImagePages: 8
[     6.584] Mode: 145 (1400x1050)
[     6.584] 	ModeAttributes: 0xbb
[     6.584] 	WinAAttributes: 0x7
[     6.584] 	WinBAttributes: 0x0
[     6.584] 	WinGranularity: 64
[     6.584] 	WinSize: 64
[     6.584] 	WinASegment: 0xa000
[     6.584] 	WinBSegment: 0x0
[     6.584] 	WinFuncPtr: 0xc0004cb5
[     6.584] 	BytesPerScanline: 2816
[     6.584] 	XResolution: 1400
[     6.584] 	YResolution: 1050
[     6.584] 	XCharSize: 8
[     6.584] 	YCharSize: 16
[     6.584] 	NumberOfPlanes: 1
[     6.584] 	BitsPerPixel: 16
[     6.584] 	NumberOfBanks: 1
[     6.584] 	MemoryModel: 6
[     6.584] 	BankSize: 0
[     6.584] 	NumberOfImages: 15
[     6.584] 	RedMaskSize: 5
[     6.584] 	RedFieldPosition: 11
[     6.584] 	GreenMaskSize: 6
[     6.584] 	GreenFieldPosition: 5
[     6.584] 	BlueMaskSize: 5
[     6.584] 	BlueFieldPosition: 0
[     6.584] 	RsvdMaskSize: 0
[     6.584] 	RsvdFieldPosition: 0
[     6.584] 	DirectColorModeInfo: 0
[     6.584] 	PhysBasePtr: 0xe0000000
[     6.584] 	LinBytesPerScanLine: 2816
[     6.584] 	BnkNumberOfImagePages: 15
[     6.584] 	LinNumberOfImagePages: 15
[     6.584] 	LinRedMaskSize: 5
[     6.584] 	LinRedFieldPosition: 11
[     6.584] 	LinGreenMaskSize: 6
[     6.584] 	LinGreenFieldPosition: 5
[     6.584] 	LinBlueMaskSize: 5
[     6.584] 	LinBlueFieldPosition: 0
[     6.584] 	LinRsvdMaskSize: 0
[     6.584] 	LinRsvdFieldPosition: 0
[     6.584] 	MaxPixelClock: 400000000
[     6.584] *Mode: 146 (1400x1050)
[     6.584] 	BytesPerScanline: 5632
[     6.584] 	BitsPerPixel: 32
[     6.584] 	NumberOfImages: 7
[     6.584] 	RedMaskSize: 8
[     6.584] 	RedFieldPosition: 16
[     6.584] 	GreenMaskSize: 8
[     6.584] 	GreenFieldPosition: 8
[     6.584] 	BlueMaskSize: 8
[     6.584] 	LinBytesPerScanLine: 5632
[     6.584] 	BnkNumberOfImagePages: 7
[     6.584] 	LinNumberOfImagePages: 7
[     6.584] 	LinRedMaskSize: 8
[     6.584] 	LinRedFieldPosition: 16
[     6.584] 	LinGreenMaskSize: 8
[     6.584] 	LinGreenFieldPosition: 8
[     6.584] 	LinBlueMaskSize: 8
[     6.585] 	LinRsvdMaskSize: 0
[     6.585] 	LinRsvdFieldPosition: 0
[     6.585] 	MaxPixelClock: 400000000
[     6.585] Mode: 175 (1600x1200)
[     6.585] 	ModeAttributes: 0xbb
[     6.585] 	WinAAttributes: 0x7
[     6.585] 	WinBAttributes: 0x0
[     6.585] 	WinGranularity: 64
[     6.585] 	WinSize: 64
[     6.585] 	WinASegment: 0xa000
[     6.585] 	WinBSegment: 0x0
[     6.585] 	WinFuncPtr: 0xc0004cb5
[     6.585] 	BytesPerScanline: 3200
[     6.585] 	XResolution: 1600
[     6.585] 	YResolution: 1200
[     6.585] 	XCharSize: 8
[     6.585] 	YCharSize: 16
[     6.585] 	NumberOfPlanes: 1
[     6.585] 	BitsPerPixel: 16
[     6.585] 	NumberOfBanks: 1
[     6.585] 	MemoryModel: 6
[     6.585] 	BankSize: 0
[     6.585] 	NumberOfImages: 12
[     6.585] 	RedMaskSize: 5
[     6.585] 	RedFieldPosition: 11
[     6.585] 	GreenMaskSize: 6
[     6.585] 	GreenFieldPosition: 5
[     6.585] 	BlueMaskSize: 5
[     6.585] 	BlueFieldPosition: 0
[     6.585] 	RsvdMaskSize: 0
[     6.585] 	RsvdFieldPosition: 0
[     6.585] 	DirectColorModeInfo: 0
[     6.585] 	PhysBasePtr: 0xe0000000
[     6.585] 	LinBytesPerScanLine: 3200
[     6.585] 	BnkNumberOfImagePages: 12
[     6.585] 	LinNumberOfImagePages: 12
[     6.585] 	LinRedMaskSize: 5
[     6.585] 	LinRedFieldPosition: 11
[     6.585] 	LinGreenMaskSize: 6
[     6.585] 	LinGreenFieldPosition: 5
[     6.585] 	LinBlueMaskSize: 5
[     6.585] 	LinBlueFieldPosition: 0
[     6.586] *Mode: 176 (1600x1200)
[     6.586] 	ModeAttributes: 0xbb
[     6.586] 	WinAAttributes: 0x7
[     6.586] 	WinBAttributes: 0x0
[     6.586] 	WinGranularity: 64
[     6.586] 	WinSize: 64
[     6.586] 	WinASegment: 0xa000
[     6.586] 	WinBSegment: 0x0
[     6.586] 	WinFuncPtr: 0xc0004cb5
[     6.586] 	BytesPerScanline: 6400
[     6.586] 	XResolution: 1600
[     6.586] 	YResolution: 1200
[     6.586] 	XCharSize: 8
[     6.586] 	YCharSize: 16
[     6.586] 	NumberOfPlanes: 1
[     6.586] 	BitsPerPixel: 32
[     6.586] 	NumberOfBanks: 1
[     6.586] 	MemoryModel: 6
[     6.586] 	BankSize: 0
[     6.586] 	NumberOfImages: 5
[     6.586] 	RedMaskSize: 8
[     6.586] 	RedFieldPosition: 16
[     6.586] 	GreenMaskSize: 8
[     6.586] 	GreenFieldPosition: 8
[     6.586] 	BlueMaskSize: 8
[     6.586] 	BlueFieldPosition: 0
[     6.586] 	RsvdMaskSize: 0
[     6.586] 	RsvdFieldPosition: 0
[     6.586] 	DirectColorModeInfo: 0
[     6.586] 	PhysBasePtr: 0xe0000000
[     6.586] 	LinBytesPerScanLine: 6400
[     6.586] 	BnkNumberOfImagePages: 5
[     6.586] 	LinNumberOfImagePages: 5
[     6.586] 	LinRedMaskSize: 8
[     6.586] 	LinRedFieldPosition: 16
[     6.586] 	LinGreenMaskSize: 8
[     6.586] 	LinGreenFieldPosition: 8
[     6.586] 	LinBlueMaskSize: 8
[     6.586] 	LinBlueFieldPosition: 0
[     6.586] 	LinRsvdMaskSize: 0
[     6.586] 	LinRsvdFieldPosition: 0
[     6.586] 	MaxPixelClock: 400000000
[     6.587] Mode: 1d2 (1920x1080)
[     6.587] 	ModeAttributes: 0xbb
[     6.587] 	WinAAttributes: 0x7
[     6.587] 	WinBAttributes: 0x0
[     6.587] 	WinGranularity: 64
[     6.587] 	WinSize: 64
[     6.587] 	WinASegment: 0xa000
[     6.587] 	WinBSegment: 0x0
[     6.587] 	WinFuncPtr: 0xc0004cb5
[     6.587] 	BytesPerScanline: 3840
[     6.587] 	XResolution: 1920
[     6.587] 	YResolution: 1080
[     6.587] 	XCharSize: 8
[     6.587] 	YCharSize: 16
[     6.587] 	NumberOfPlanes: 1
[     6.587] 	BitsPerPixel: 16
[     6.587] 	NumberOfBanks: 1
[     6.587] 	MemoryModel: 6
[     6.587] 	BankSize: 0
[     6.587] 	NumberOfImages: 11
[     6.587] 	RedMaskSize: 5
[     6.587] 	RedFieldPosition: 11
[     6.587] 	GreenMaskSize: 6
[     6.587] 	GreenFieldPosition: 5
[     6.587] 	BlueMaskSize: 5
[     6.587] 	BlueFieldPosition: 0
[     6.587] 	RsvdMaskSize: 0
[     6.587] 	RsvdFieldPosition: 0
[     6.587] 	DirectColorModeInfo: 0
[     6.587] 	PhysBasePtr: 0xe0000000
[     6.587] 	LinBytesPerScanLine: 3840
[     6.587] 	BnkNumberOfImagePages: 11
[     6.587] 	LinNumberOfImagePages: 11
[     6.587] 	LinRedMaskSize: 5
[     6.587] 	LinRedFieldPosition: 11
[     6.587] 	LinGreenMaskSize: 6
[     6.587] 	LinGreenFieldPosition: 5
[     6.587] 	LinBlueMaskSize: 5
[     6.587] 	LinBlueFieldPosition: 0
[     6.587] 	LinRsvdMaskSize: 0
[     6.587] 	LinRsvdFieldPosition: 0
[     6.587] 	MaxPixelClock: 400000000
[     6.587] *Mode: 1d4 (1920x1080)
[     6.587] 	BytesPerScanline: 7680
[     6.587] 	BitsPerPixel: 32
[     6.587] 	NumberOfImages: 5
[     6.587] 	RedMaskSize: 8
[     6.587] 	RedFieldPosition: 16
[     6.587] 	GreenMaskSize: 8
[     6.587] 	GreenFieldPosition: 8
[     6.587] 	BlueMaskSize: 8
[     6.587] 	LinBytesPerScanLine: 7680
[     6.587] 	BnkNumberOfImagePages: 5
[     6.587] 	LinNumberOfImagePages: 5
[     6.587] 	LinRedMaskSize: 8
[     6.587] 	LinRedFieldPosition: 16
[     6.587] 	LinGreenMaskSize: 8
[     6.587] 	LinGreenFieldPosition: 8
[     6.587] 	LinBlueMaskSize: 8
[     6.587]
[     6.587] (II) VESA(0): Total Memory: 768 64KB banks (49152kB)
[     6.587] (II) VESA(0): Monitor0: Using hsync range of 31.00-83.00 kHz
[     6.587] (II) VESA(0): Monitor0: Using vrefresh range of 56.00-76.00 Hz
[     6.587] (II) VESA(0): Monitor0: Using maximum pixel clock of 185.00 MHz
[     6.587] (WW) VESA(0): Unable to estimate virtual size
[     6.587] (II) VESA(0): Not using built-in mode "1600x1200" (no mode of this name)
[     6.587] (II) VESA(0): Not using built-in mode "1400x1050" (no mode of this name)
[     6.587] (II) VESA(0): Not using built-in mode "1280x1024" (no mode of this name)
[     6.587] (II) VESA(0): Not using built-in mode "1280x960" (no mode of this name)
[     6.587] (II) VESA(0): Not using built-in mode "1024x768" (no mode of this name)
[     6.587] (II) VESA(0): Not using built-in mode "800x600" (no mode of this name)
[     6.587] (II) VESA(0): Virtual size is 1920x1080 (pitch 1920)
[     6.587] (**) VESA(0): *Built-in mode "1920x1080"
[     6.587] (**) VESA(0): *Built-in mode "640x480"
[     6.587] (**) VESA(0): Display dimensions: (510, 290) mm
[     6.587] (**) VESA(0): DPI set to (95, 94)
[     6.587] (**) VESA(0): Using "Shadow Framebuffer"
[     6.587] (II) Loading sub module "shadow"
[     6.587] (II) LoadModule: "shadow"
[     6.587] (II) Loading /usr/lib/xorg/modules/libshadow.so
[     6.588] (II) Module shadow: vendor="X.Org Foundation"
[     6.588] 	compiled for 1.20.4, module version = 1.1.0
[     6.588] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     6.588] (II) Loading sub module "fb"
[     6.588] (II) LoadModule: "fb"
[     6.588] (II) Loading /usr/lib/xorg/modules/libfb.so
[     6.588] (II) Module fb: vendor="X.Org Foundation"
[     6.588] 	compiled for 1.20.4, module version = 1.0.0
[     6.588] (II) Loading sub module "int10"
[     6.588] (II) LoadModule: "int10"
[     6.588] (II) Loading /usr/lib/xorg/modules/libint10.so
[     6.588] (II) Module int10: vendor="X.Org Foundation"
[     6.588] 	ABI class: X.Org Video Driver, version 24.0
[     6.588] (II) VESA(0): initializing int10
[     6.588] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[     6.588] (II) VESA(0): VESA BIOS detected
[     6.588] (II) VESA(0): VESA VBE Version 3.0
[     6.588] (II) VESA(0): VESA VBE Total Mem: 49152 kB
[     6.588] (II) VESA(0): VESA VBE OEM: AMD ATOMBIOS
[     6.588] (II) VESA(0): VESA VBE OEM Software Rev: 16.2
[     6.588] (II) VESA(0): VESA VBE OEM Vendor: (C) 1988-2010, Advanced Micro Devices, Inc.
[     6.588] (II) VESA(0): VESA VBE OEM Product: RAVEN
[     6.588] (II) VESA(0): VESA VBE OEM Product Rev: 01.00
[     6.588] (II) VESA(0): virtual address = (nil), VGAbase = (nil)
	physical address = 0xe0000000, size = 50331648
[     6.589] (II) VESA(0): virtual address = 0x7fc0caf93000, VGAbase = 0x7fc0caf93000
	physical address = 0xa0000, size = 65536
[     6.589] (II) VESA(0): Setting up VESA Mode 0x1D4 (1920x1080)
[     6.589] (II) VESA(0): VBESetVBEMode failed, mode set without customized refresh.
[     6.621] (==) VESA(0): Default visual is TrueColor
[     6.622] (==) VESA(0): Backing store enabled
[     6.622] (**) VESA(0): DPMS enabled
[     6.622] (II) Initializing extension Generic Event Extension
[     6.622] (II) Initializing extension SHAPE
[     6.622] (II) Initializing extension MIT-SHM
[     6.623] (II) Initializing extension XInputExtension
[     6.623] (II) Initializing extension XTEST
[     6.623] (II) Initializing extension BIG-REQUESTS
[     6.623] (II) Initializing extension SYNC
[     6.623] (II) Initializing extension XKEYBOARD
[     6.623] (II) Initializing extension XC-MISC
[     6.623] (II) Initializing extension SECURITY
[     6.623] (II) Initializing extension XFIXES
[     6.623] (II) Initializing extension RENDER
[     6.623] (II) Initializing extension RANDR
[     6.623] (II) Initializing extension COMPOSITE
[     6.624] (II) Initializing extension DAMAGE
[     6.624] (II) Initializing extension MIT-SCREEN-SAVER
[     6.624] (II) Initializing extension DOUBLE-BUFFER
[     6.624] (II) Initializing extension RECORD
[     6.624] (II) Initializing extension DPMS
[     6.624] (II) Initializing extension Present
[     6.624] (II) Initializing extension DRI3
[     6.624] (II) Initializing extension X-Resource
[     6.624] (II) Initializing extension XVideo
[     6.624] (II) Initializing extension XVideo-MotionCompensation
[     6.624] (II) Initializing extension SELinux
[     6.624] (II) SELinux: Disabled on system
[     6.624] (II) Initializing extension GLX
[     6.624] (II) AIGLX: Screen 0 is not DRI2 capable
[     6.680] (II) IGLX: Loaded and initialized swrast
[     6.680] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[     6.680] (II) Initializing extension XFree86-VidModeExtension
[     6.680] (II) Initializing extension XFree86-DGA
[     6.680] (II) Initializing extension XFree86-DRI
[     6.680] (II) Initializing extension DRI2
[     6.717] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     6.717] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     6.717] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     6.717] (II) LoadModule: "libinput"
[     6.718] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     6.722] (II) Module libinput: vendor="X.Org Foundation"
[     6.722] 	compiled for 1.20.4, module version = 0.28.2
[     6.722] 	Module class: X.Org XInput Driver
[     6.722] 	ABI class: X.Org XInput driver, version 24.1
[     6.722] (II) Using input driver 'libinput' for 'Power Button'
[     6.722] (**) Power Button: always reports core events
[     6.722] (**) Option "Device" "/dev/input/event1"
[     6.722] (**) Option "_source" "server/udev"
[     6.725] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     6.725] (II) event1  - Power Button: device is a keyboard
[     6.725] (II) event1  - Power Button: device removed
[     6.736] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event1"
[     6.736] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     6.736] (**) Option "xkb_model" "pc105"
[     6.736] (**) Option "xkb_layout" "us"
[     6.736] (**) Option "xkb_options" "grp:alt_shift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
[     6.756] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     6.756] (II) event1  - Power Button: device is a keyboard
[     6.756] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     6.756] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     6.756] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     6.756] (II) Using input driver 'libinput' for 'Power Button'
[     6.756] (**) Power Button: always reports core events
[     6.756] (**) Option "Device" "/dev/input/event0"
[     6.756] (**) Option "_source" "server/udev"
[     6.757] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     6.757] (II) event0  - Power Button: device is a keyboard
[     6.757] (II) event0  - Power Button: device removed
[     6.766] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3/event0"
[     6.766] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     6.766] (**) Option "xkb_model" "pc105"
[     6.766] (**) Option "xkb_layout" "us"
[     6.766] (**) Option "xkb_options" "grp:alt_shift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
[     6.766] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     6.766] (II) event0  - Power Button: device is a keyboard
[     6.766] (II) config/udev: Adding input device Generic USB Keyboard (/dev/input/event11)
[     6.766] (**) Generic USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.766] (**) Generic USB Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.766] (II) Using input driver 'libinput' for 'Generic USB Keyboard'
[     6.766] (**) Generic USB Keyboard: always reports core events
[     6.766] (**) Option "Device" "/dev/input/event11"
[     6.766] (**) Option "_source" "server/udev"
[     6.767] (II) event11 - Generic USB Keyboard: is tagged by udev as: Keyboard
[     6.767] (II) event11 - Generic USB Keyboard: device is a keyboard
[     6.767] (II) event11 - Generic USB Keyboard: device removed
[     6.778] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:15:00.0/usb1/1-5/1-5:1.0/0003:040B:2000.0001/input/input14/event11"
[     6.778] (II) XINPUT: Adding extended input device "Generic USB Keyboard" (type: KEYBOARD, id 8)
[     6.778] (**) Option "xkb_model" "pc105"
[     6.778] (**) Option "xkb_layout" "us"
[     6.778] (**) Option "xkb_options" "grp:alt_shift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
[     6.779] (II) event11 - Generic USB Keyboard: is tagged by udev as: Keyboard
[     6.779] (II) event11 - Generic USB Keyboard: device is a keyboard
[     6.779] (II) config/udev: Adding input device Generic USB Keyboard (/dev/input/event12)
[     6.779] (**) Generic USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.779] (**) Generic USB Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.779] (II) Using input driver 'libinput' for 'Generic USB Keyboard'
[     6.779] (**) Generic USB Keyboard: always reports core events
[     6.779] (**) Option "Device" "/dev/input/event12"
[     6.779] (**) Option "_source" "server/udev"
[     6.780] (II) event12 - Generic USB Keyboard: is tagged by udev as: Keyboard
[     6.780] (II) event12 - Generic USB Keyboard: device is a keyboard
[     6.780] (II) event12 - Generic USB Keyboard: device removed
[     6.790] (II) libinput: Generic USB Keyboard: needs a virtual subdevice
[     6.790] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:15:00.0/usb1/1-5/1-5:1.1/0003:040B:2000.0002/input/input15/event12"
[     6.790] (II) XINPUT: Adding extended input device "Generic USB Keyboard" (type: MOUSE, id 9)
[     6.790] (**) Option "AccelerationScheme" "none"
[     6.790] (**) Generic USB Keyboard: (accel) selected scheme none/0
[     6.790] (**) Generic USB Keyboard: (accel) acceleration factor: 2.000
[     6.790] (**) Generic USB Keyboard: (accel) acceleration threshold: 4
[     6.790] (II) event12 - Generic USB Keyboard: is tagged by udev as: Keyboard
[     6.790] (II) event12 - Generic USB Keyboard: device is a keyboard
[     6.791] (II) config/udev: Adding input device Generic USB Keyboard (/dev/input/mouse0)
[     6.791] (II) No input driver specified, ignoring this device.
[     6.791] (II) This device may have been added with another device file.
[     6.791] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event13)
[     6.791] (**) Logitech USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[     6.791] (**) Logitech USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[     6.791] (II) Using input driver 'libinput' for 'Logitech USB Optical Mouse'
[     6.791] (**) Logitech USB Optical Mouse: always reports core events
[     6.791] (**) Option "Device" "/dev/input/event13"
[     6.791] (**) Option "_source" "server/udev"
[     6.792] (II) event13 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[     6.792] (II) event13 - Logitech USB Optical Mouse: device set to 1000 DPI
[     6.792] (II) event13 - Logitech USB Optical Mouse: device is a pointer
[     6.792] (II) event13 - Logitech USB Optical Mouse: device removed
[     6.810] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:15:00.0/usb1/1-6/1-6:1.0/0003:046D:C05A.0003/input/input16/event13"
[     6.810] (II) XINPUT: Adding extended input device "Logitech USB Optical Mouse" (type: MOUSE, id 10)
[     6.810] (**) Option "AccelerationScheme" "none"
[     6.810] (**) Logitech USB Optical Mouse: (accel) selected scheme none/0
[     6.810] (**) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[     6.810] (**) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[     6.811] (II) event13 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[     6.811] (II) event13 - Logitech USB Optical Mouse: device set to 1000 DPI
[     6.811] (II) event13 - Logitech USB Optical Mouse: device is a pointer
[     6.811] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse1)
[     6.811] (II) No input driver specified, ignoring this device.
[     6.811] (II) This device may have been added with another device file.
[     6.811] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event2)
[     6.812] (II) No input driver specified, ignoring this device.
[     6.812] (II) This device may have been added with another device file.
[     6.812] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=7 (/dev/input/event3)
[     6.812] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=8 (/dev/input/event4)
[     6.812] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=9 (/dev/input/event5)
[     6.813] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event7)
[     6.813] (II) No input driver specified, ignoring this device.
[     6.813] (II) This device may have been added with another device file.
[     6.813] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event8)
[     6.813] (II) config/udev: Adding input device HD-Audio Generic Line Out (/dev/input/event9)
[     6.813] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event10)
[     6.813] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event6)
[     6.815] (**) Generic USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     6.815] (**) Generic USB Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.815] (II) Using input driver 'libinput' for 'Generic USB Keyboard'
[     6.815] (**) Generic USB Keyboard: always reports core events
[     6.815] (**) Option "Device" "/dev/input/event12"
[     6.815] (**) Option "_source" "_driver/libinput"
[     6.815] (II) libinput: Generic USB Keyboard: is a virtual subdevice
[     6.815] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:15:00.0/usb1/1-5/1-5:1.1/0003:040B:2000.0002/input/input15/event12"
[     6.815] (II) XINPUT: Adding extended input device "Generic USB Keyboard" (type: KEYBOARD, id 11)
[     6.815] (**) Option "xkb_model" "pc105"
[     6.815] (**) Option "xkb_layout" "us"
[     6.815] (**) Option "xkb_options" "grp:alt_shift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
namida12
#62 Post by namida12 »
anticapitalista,
Thank you and anyone that helped you assemble this rock solid b1 release. Have run it unmodified.
Topology: Quad Core model: AMD Ryzen 3 2200G with Radeon Vega Graphics
Uptime: 5d 17h 34m Memory: 6.81 GiB used: 1.16 GiB (17.0%)
JR
Buck Fankers
#63 Post by Buck Fankers »
I installed anti19Xb1 32 bit next to previous version 17.something, dual boot.
I don't know what I messed up, but my user account was not created. (I used the same usernames for user and root, as for 17.x install, but since it is on different partition, this should be OK correct? And they are not sharing home or anything. Each home is inside root, didn't create separate home partitions.
When I restarted machine there were demo and root accounts installed, my two accounts were missing.
For now disregard this, I will repeat install tomorrow, next time I will pay attention what I will be doing ;-)
#64 Post by fehlix »
Buck Fankers wrote: Thu Jul 04, 2019 4:03 pm ... I used the same usernames for user and root
... restarted machine there were demo and root accounts installed,
... my two accounts were missing.
You might try to rephrase this, it's a bit unclear at least for me...
I would just install, and create one new user during installation.
brolly
#65 Post by brolly »
SIlly question before I try Antix 19b. Is XFCE the default DE?
#66 Post by anticapitalista »
brolly wrote: Fri Jul 05, 2019 12:27 pm SIlly question before I try Antix 19b. Is XFCE the default DE?
No. IceWM on a ROX pinboard is.
Buck Fankers
#67 Post by Buck Fankers »
fehlix wrote: Thu Jul 04, 2019 5:08 pm
Yes sorry I wrote it wrong and confusing.
I did regular install, and I created new user, and I used the same password for user as for root. I understand this is a little less secure but still OK.
On another partition, the same disk, I have installed antiX 17.3 or 17.4 from before. That antiX17.x has the same user name as user of new antiX19b1 that is on a different partition. Homes are not being shared. Homes don't have separate partitions.
For some reason, after installation of antiX19b1, there is only demo user. The one I created during install is not there. Well at least it is not offered as one to log into it. Just demo.
But chances are I probably did something wrong.
The reason I'm writing this is, I'm just trying to explain my confusing post from before.
I will install it again, make sure I'm double checking everything and report back if the same situation happens again.
brolly
#68 Post by brolly »
anticapitalista wrote: Fri Jul 05, 2019 12:42 pm
Thanks fot the headsup :toast2:
manyroads
#69 Post by manyroads »
brolly wrote: Fri Jul 05, 2019 6:33 pm Thanks fot the headsup :toast2:
If you want to make it antiX19 into xfce setup... here are some instructions:
https://eirenicon.org/knowledge-base/co ... -tutorial/
brolly
#70 Post by brolly »
manyroads wrote: Fri Jul 05, 2019 7:52 pm
I appreciate it. I'm on to it as we speak. Lawdy Lawd that's one long code :eek:
Return to “antiX”
