MX-18 beta 1 feedback
Re: MX-18 beta 1 feedback
CONFIG_CRYPTO_XTS is needed from what I found on the net.
here's what we have on the 32 bit.anticapitalista wrote: ↑Sun Dec 09, 2018 1:12 pm CONFIG_CRYPTO_XTS is needed from what I found on the net.
CONFIG_CRYPTO_XTS=m
antiX kernels has that as CONFIG_CRYPTO_XTS=y
I installed it last night, on Desktop only. I'm using it now. So far the stuff I've done so far works, but GIMP 2.10 clashes with data files needed for MyPaint (no such problem with 2.8 and I hate the grey scheme but none of that is the fault of this excellent distro). Hopefully I'll be able to push a few things and test them over the next few days.
Can report now: Printing and Scanning working perfectly
To revert GIMP interface theme: https://www.daviesmediadesign.com/custo ... interface/
Laptop: Lenovo V15 ADA
Media Centre: Lenovo Q190
I tried a snapshot with the antix 4.19.7 kernel but I'm getting a copy modules error in the cli LUM.
Don't "=y" and "=m" both enable the feature? One just makes it part of the monolithic kernel and the other makes it a loadable module.
honestly not sure, but the 64 bit has an "m" as well.
I've only tried 2, but I can't make a 32 bit encrypted usb with a 4.19 kernel, yet.
building a 64 bit encrypted usb seems to work fine with our kernel (confirming richb's post)
MX-LSD conky disappears when I click anywhere on the desktop
same story with the 4.18 kernel. 32 bit kernel from alpha 1dolphin_oracle wrote: ↑Sun Dec 09, 2018 4:10 pmhonestly not sure, but the 64 bit has an "m" as well.
same with antiX-4.19.7 kernel (on antiX).dolphin_oracle wrote: ↑Sun Dec 09, 2018 5:33 pmsame story with the 4.18 kernel. 32 bit kernel from alpha 1dolphin_oracle wrote: ↑Sun Dec 09, 2018 4:10 pmhonestly not sure, but the 64 bit has an "m" as well.
I know the 4.9 antiX kernel does work.
