debiandog's quickremaster for mx-linux
Re: debiandog's quickremaster for mx-linux
#11 Post by anticapitalista »
@bled - which version of debian dog are you using? stretch 64 bit? Do you have a frugal install or a 'normal' install to a hard disk?
#12 Post by richb »
Just did a snapshot with MX Snapshot using lz4 compression. The result was a 3.1 GB snapshot and it took about 90 seconds. I verified in the log it was lz4 compressed.
#13 Post by Adrian »
richb wrote: Thu Dec 06, 2018 8:50 pm Just did a snapshot with MX Snapshot using lz4 compression. The result was a 3.1 GB snapshot and it took about 90 seconds. I verified in the log it was lz4 compressed.
It also creates md5 and sha256 sum files, one for linuxfs too so maybe about 10-15 seconds are probably spent for that. Unless you run this on a 20 year-old PC it won't take 10 minutes and in any case it won't create a 1.3GB file.
skidoo
#14 Post by skidoo »
I audited it last year and AFAIK it hasn't been updated since then.
retrieved from h t t p s://fredx181.github.io/StretchDog/amd64/Packages/Included/
quick-remaster_1.0.6_all.deb
ouch, it unconditionally discards the entire contents of usr/share/man, /usr/share/doc/, usr/share/gtk-doc/, usr/share/gnome/help/, usr/share/info/
#15 Post by asqwerth »
Every 1 or 2 months, OP will post something about lz4 or a puppy-based distro, or both.
He first went on a posting spree about lz4 compression around the time MX17.1 was released in March 2018.
Now, just before MX18 is released it happens again? Hmm.
skidoo
#16 Post by skidoo »
credit where credit is due, eh?
IIRC, it was bled who "enlightened" us to the availability + benefit of lz4 mksquashfs option.
Don't trust memory, use the forum search (query: lz4, show:topics). Yep, earliest mention of lz4 in the forum was a topic started by @bled
#17 Post by asqwerth »
The initial credit, sure.
But the regular lz4 and puppy posts thereafter are so strange. Especially if you say that debiandog hasn't been updated for some time.
#18 Post by anticapitalista »
skidoo wrote: Fri Dec 07, 2018 3:20 am credit where credit is due, eh?
+1 - bled's online 'manner' might be blunt, but it did lead us to use lz4 compression
Richard
#19 Post by Richard »
Question?
Is there a way to create a snapshot with lz4,
and then increase the compression of the iso
with a pass of another algorithm
without losing the ability to install?
That might use fewer resources
at a lower temperature.
Just a thought.
#20 Post by Adrian »
That's correct. I didn't know at that time that lz4 was so fast (but obviously not that good at compression), don't think we needed to change anything to make it work in mx-snapshot there's a compression option in mx-snapshot.conf
I don't know, but won't you lose the speed light CPU utilization benefit (also compressing already compressed file is usually less efficient than compressing a flat file)
