MX-17.1-RC1 Release Candidate Feedback
If posting hardware issues, please post the output of the terminal command "inxi -F" at a minimum.
If posting nvidia-installer issues, please post the contents of /var/log/ddm.log.
If posting remaster issues, please include the contents of /var/log/live/live-remaster.log
If posting issues with MX-PackeageInstaller "Popular Apps", please post contents of /var/log/mxpi.log or /var/log/mxpi.log.old (whichever contains the log of your issue).
- entropyfoe
Re: MX-17.1-RC1 Release Candidate Feedback
So, the 4.15 64 bit kernel is patched with all the new gcc retpoline compile fixes?
An the antiX site, it lists the fully patched as 4.15.5. What is the difference? I guess I don't follow the kernel numbering scheme too closely.
--4.15.0-1 kernels for both 32bit and 64bit isos (64 bit are patched for meltdown/spectre issues)
Asus PRIME X470-PRO
Nvidia GeForce GT 710
on-board ethernet & sound
Looks pretty darned good so far.
One minor item: when the Welcome screen comes up, if I click an icon/link the screen disappears for a second--and then pops back up.
No problems installation wise.
How to update now?
Btw, Cairo-dock is no longer is software repo.?
sudo add-apt-repository ppa:cairo-dock-team/ppa doesn't work for me either.
How to update now?
Panel missing. There is only the standard XFCE wallpaper. Can't get into settings no matter what I clicked on. The only thing that seemed to work is log out and opening the terminal. System info not available doesn't work in MX-17.1. I will post my system info from MX-17 instead.
System: Host: mauser Kernel: 4.15.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Machine: Device: desktop System: HP product: 510-p026 serial: N/A
Mobo: HP model: 81B4 v: 00 serial: N/A UEFI [Legacy]: AMI v: F.13 date: 08/02/2016
CPU: Quad core Intel Core i5-6400T (-MCP-) cache: 6144 KB
clock speeds: max: 2800 MHz 1: 899 MHz 2: 1102 MHz 3: 1111 MHz 4: 1048 MHz
Graphics: Card: Intel HD Graphics 530
Resolution: 1366x768@59.81hz, 1920x1080@60.00hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2) version: 4.5 Mesa 13.0.6
Audio: Card Intel Sunrise Point-H HD Audio driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.15.0-1-amd64
Network: Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller driver: r8169
IF: eth0 state: up speed: 100 Mbps duplex: full mac: ec:8e:b5:d8:80:88
Card-2: Intel Wireless 3165 driver: iwlwifi
IF: wlan0 state: down mac: 8e:40:a2:3c:53:08
Drives: HDD Total Size: 4000.8GB (18.3% used)
ID-1: /dev/sda model: HGST_HUS726040AL size: 4000.8GB
Partition: ID-1: / size: 3.6T used: 672G (20%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 12.88GB used: 0.00GB (0%) fs: swap dev: /dev/sda1
Sensors: System Temperatures: cpu: 30.0C mobo: 27.8C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 211 Uptime: 7 min Memory: 1153.7/11874.5MB
Client: Shell (quick-system-in) inxi: 2.3.54
Panel: is that Live or installed?Mauser wrote:Panel missing. There is only the standard XFCE wallpaper. Can't get into settings no matter what I clicked on. The only thing that seemed to work is log out and opening the terminal. System info not available doesn't work in MX-17.1. I will post my system info from MX-17 instead.Code: Select all
System: Host: mauser Kernel: 4.15.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3 Distro: MX-17_x64 Horizon December 15, 2017 Machine: Device: desktop System: HP product: 510-p026 serial: N/A Mobo: HP model: 81B4 v: 00 serial: N/A UEFI [Legacy]: AMI v: F.13 date: 08/02/2016 CPU: Quad core Intel Core i5-6400T (-MCP-) cache: 6144 KB clock speeds: max: 2800 MHz 1: 899 MHz 2: 1102 MHz 3: 1111 MHz 4: 1048 MHz Graphics: Card: Intel HD Graphics 530 Display Server: x11 (X.Org 1.19.2 ) drivers: modesetting (unloaded: fbdev,vesa) Resolution: 1366x768@59.81hz, 1920x1080@60.00hz OpenGL: renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2) version: 4.5 Mesa 13.0.6 Audio: Card Intel Sunrise Point-H HD Audio driver: snd_hda_intel Sound: Advanced Linux Sound Architecture v: k4.15.0-1-amd64 Network: Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller driver: r8169 IF: eth0 state: up speed: 100 Mbps duplex: full mac: ec:8e:b5:d8:80:88 Card-2: Intel Wireless 3165 driver: iwlwifi IF: wlan0 state: down mac: 8e:40:a2:3c:53:08 Drives: HDD Total Size: 4000.8GB (18.3% used) ID-1: /dev/sda model: HGST_HUS726040AL size: 4000.8GB Partition: ID-1: / size: 3.6T used: 672G (20%) fs: ext4 dev: /dev/sda2 ID-2: swap-1 size: 12.88GB used: 0.00GB (0%) fs: swap dev: /dev/sda1 Sensors: System Temperatures: cpu: 30.0C mobo: 27.8C Fan Speeds (in rpm): cpu: N/A Info: Processes: 211 Uptime: 7 min Memory: 1153.7/11874.5MB Client: Shell (quick-system-in) inxi: 2.3.54
Last edited by dolphin_oracle on Tue Mar 06, 2018 8:58 pm, edited 1 time in total.
Live.dolphin_oracle wrote:is that Live or installed?Mauser wrote:Panel missing. There is only the standard XFCE wallpaper. Can't get into settings no matter what I clicked on. The only thing that seemed to work is log out and opening the terminal. System info not available doesn't work in MX-17.1. I will post my system info from MX-17 instead.Code: Select all
@mauser: that would be new.
How did you make the stick?
Did you check the md5sum on the download?
Found out i didn't wait long enough for software manager to finish its update prior to searching for Cairo-dock.
Everything is runnin' just fine now.
