Hmmm... Any one has problem to run Palemoon in MX 17 32 bit ?
Palemoon refuses to load/start.I get follow message
Your Palemoon Profile can not be loaded. It may be missing or inaccesible.
Palemoon starts only with command
sudo Palemoon %u
I changen ownership of folder
/home/penguin/.moonchild productions/
but this did not resolved problem.Something that I missed?
Strange. I tested in my Sparky Linux 32 bit. Palemoon works perfectly. I migrated the *.ini files under directory
from Sparky, but the problem persists.
Palemoon refuses to start[RESOLVED] - delete cache directory
Re: Palemoon refuses to start
Copy command below and paste into a USER terminal, and hit enter.
Post output to forum.
Compare the user ID and group ID and user and group in the output of above commands they should all match.
The directories should have read,write,execute permissions for owner.
Example output below:
id;ls -an ~/".moonchild productions";ls -al ~/".moonchild productions"
kruppt@aptosid-an52:~$ id;ls -an ~/".moonchild productions";ls -al ~/".moonchild productions"
uid=1000(kruppt) gid=1000(kruppt) groups=1000(kruppt),4(adm),6(disk),20(dialout),22(voice),24(cdrom),25(floppy),26(tape),27(sudo),29(audio),30(dip),40(src),44(video),46(plugdev),100(users),102(fuse),104(scanner),105(mlocate),109(netdev),121(debian-tor),149(lightdm)
total 28
drwx------ 3 1000 1000 4096 Apr 19 2015 .
drwx------ 336 1000 1000 20480 Dec 25 20:04 ..
drwx------ 2 1000 1000 4096 Nov 19 14:52 pale moon
total 28
drwx------ 3 kruppt kruppt 4096 Apr 19 2015 .
drwx------ 336 kruppt kruppt 20480 Dec 25 20:04 ..
drwx------ 2 kruppt kruppt 4096 Nov 19 14:52 pale moon
Did you install Palemoon from the MX-17 repo? Or from the MX Package Installer?
Samsung 860 500GB SSDs (2)
Kruppt wrote:Copy command below and paste into a USER terminal, and hit enter.
Post output to forum.Compare the user ID and group ID and user and group in the output of above commands they should all match.Code: Select all
kruppt@aptosid-an52:~$ id;ls -an ~/".moonchild productions";ls -al ~/".moonchild productions" uid=1000(kruppt) gid=1000(kruppt) groups=1000(kruppt),4(adm),6(disk),20(dialout),22(voice),24(cdrom),25(floppy),26(tape),27(sudo),29(audio),30(dip),40(src),44(video),46(plugdev),100(users),102(fuse),104(scanner),105(mlocate),109(netdev),121(debian-tor),149(lightdm) total 28 drwx------ 3 1000 1000 4096 Apr 19 2015 . drwx------ 336 1000 1000 20480 Dec 25 20:04 .. drwx------ 2 1000 1000 4096 Nov 19 14:52 pale moon total 28 drwx------ 3 kruppt kruppt 4096 Apr 19 2015 . drwx------ 336 kruppt kruppt 20480 Dec 25 20:04 .. drwx------ 2 kruppt kruppt 4096 Nov 19 14:52 pale moon
my terminal output
1- my penguin user is part of 12 groups.id;ls -an ~/".moonchild productions";ls -al ~/".moonchild productions"
uid=1000(penguin) gid=1000(penguin) groups=1000(penguin),7(lp),20(dialout),24(cdrom),25(floppy),27(sudo),29(audio),30(dip),44(video),46(plugdev),100(users),108(netdev),114(vboxsf),116(lpadmin),119(scanner)
total 12
drwx------ 3 1000 1000 4096 Dec 25 13:19 .
drwxr-xr-x 49 1000 100 4096 Dec 26 15:07 ..
drwx------ 3 1000 1000 4096 Dec 25 13:21 pale moon
total 12
drwx------ 3 penguin penguin 4096 Dec 25 13:19 .
drwxr-xr-x 49 penguin users 4096 Dec 26 15:07 ..
drwx------ 3 penguin penguin 4096 Dec 25 13:21 pale moon
2- The second difference is drwxr-xr-x 49 1000 100 4096 Dec 26 15:07
Any idea? As I said. I copied functional user ini directory from Sparky Linux but this did not resolved my problem.
1- I installed Palemoon from MX -Linux MX Installer. Removed/Purged
2- Installed Palemoon as descibred here
https://software.opensuse.org/download.html?project=home:stevenpusser&package=palemoon
3-Installed Palemmon package borrow by Sparky Linux
https://sparkylinux.org/repo/pool/main/p/palemoon/
Any Idea?
Re: Palemoon refuses to start[RESOLVED]
Resolved... !!!
I searched a lot on the INTERNET but I did not found answer. I am not very sure whats happens and why .moonchild productions get wrong permissions. But I found solution.
IF your/home/user/.moonchild productions/ exists
THAN have a look at your cache directory .
DELETE /homeuser/.moonchild productions/ directotry
AND restart Palemoon.
Done!
Done!
The different Group ID should not have caused problems, but...
Run below command in USER term to make sure all directories, sub-directories, and files along
profile path recursively have proper user, group .
Need to know the actual full path to your profile folder, so please run in term
below command and post the output to forum.
Also post contents of your profile.ini file along path:
/home/penguin/.moonchild productions/pale moon/profiles.ini
to forum,. run below command in user term, then copy output from term and paste into post.
sudo chown -vR penguin:penguin ~/".moonchild productions"
ls -al ~/".moonchild productions/pale moon"
cat "/home/penguin/.moonchild productions/pale moon/profiles.ini"
