MX-17 Beta 1 Feedback Thread
Locked
#1 Post by dolphin_oracle »
MX-17 beta 1 images are now available for download and testing.
direct download:
https://sourceforge.net/projects/mx-lin ... X17/beta1/
torrents:
32bit http://linuxtracker.org/download.php?id ... rent&key=0
64bit http://linuxtracker.org/download.php?id ... rent&key=0
The beta 1 features the following :
  • latest live system changes and fixes from the antiX project
  • the latest updates from debian (stretch)
  • 4.9.0-4 kernels (alphas featured 4.9.0-3)
  • the 32 bit iso has a PAE kernel. The non-pae has been removed.
  • updated packages, including libreoffice 5.4.1
  • new and updated mx-apps
  • mx-tweak replaces mx-defaultlook and provides one-stop spot for simple compositor (Xfce or Compton), panel, and other "tweak" type changes
  • mx-conky provides a method for doing simple edits to conky files (color changes, etc...)
  • mx-network-assistanct replaces mx-broadcom-manager as a general purpose network troubleshooting tool.
  • mx-tools now has a larger interface
  • changes to the update mananger (apt-notifier), including new themes available in preferences
  • misc. changes to most of the other mx-apps
  • the applications menu now has a mx-tools submenu to help organize the menu a little bit.
  • gthumb replaces shotwell and mirage (both still available in mx-packageinstaller)
  • featherpad, a qt-based text editor with tabbed interface and code markup, replaces leafpad.
  • new art work and icons (current wallpaper is not final, just being used for beta 1 release)
  • several pre-packaged conky configurations (see conky-manager to change and select)
Known Issues
  • The manual has not yet been updated for MX-17.
  • Translations are not yet complete for the new mx-apps and some are still being updated.
  • Some testers during alpha reported shutdown problems when using the encrypted home option. We have included a fix, but it has received limited testing.
Please post conky comments here: The MX-17 conkies
If posting hardware issues, please post the output of the terminal command "inxi -F" at a minimum.
If posting nvidia-installer issues, please post the contents of /var/log/ddm.log.
If posting remaster issues, please include the contents of /var/log/live/live-remaster.log
Dolphin Oracle (on behalf of the MX dev team).
Last edited by dolphin_oracle on Mon Nov 06, 2017 2:28 pm, edited 6 times in total.
stsoh
Re: MX-17 Beta 1 Feedback Thread
#2 Post by stsoh »
remastercc can't end, after 100% progress, endless running. i haven't cancel it yet, it is still running for 20 mins as i wrote this. maybe i use becoz yumi multi-boot live on usb but mx16.1 don't have any problem with remastercc.
BitJam
#3 Post by BitJam »
@stsoh, please make a copy of /var/log/live/live-remaster.log and attach it. We had one report of this problem in antiX-17 but the devs were not able to reproduce it.
-- Richard Feynman
#4 Post by dolphin_oracle »
BitJam wrote:@stsoh, please make a copy of /var/log/live/live-remaster.log and attach it. We had one report of this problem in antiX-17 but the devs were not able to reproduce it.
@BitJam - just so you know, the live-remaster script is the same as what's on the antiX github, so hopefully we can solve this for both systems.
stsoh
#5 Post by stsoh »
attached live-remaster.log
chrispop99
#6 Post by chrispop99 »
During Alpha testing, there was a problem where installing with 'home' encryption prevented normal shutdown completion, hanging at 'Stopping remaining crypto disks...'.
This was resolved, and I tested the fix successfully. However, I've just installed Beta 1 on two machines, enabling 'home' encryption, and the failure to shutdown has returned.
One of the machines was the one I used to successfully test this in Alpha, so I don't think it's a hardware issue.
DELL XPS 15
Lots of test machines
BitJam
#7 Post by BitJam »
@chrispop99, there is a bug in the sendsigs script that was released. Please edit /etc/init.d/sendsigs as root and change line 34 to:
    for pid in $(pgrep "$PROTECT_LIST"); do
(remove the "-f")
-- Richard Feynman
#8 Post by dolphin_oracle »
dang it, grabbed the wrong ones.... noted for b2.
entropyfoe
#9 Post by entropyfoe »
When will beta1 or beta2 be public betas?
Available for download, testing, and reports?
Asus PRIME X470-PRO
Nvidia GeForce GT 710
on-board ethernet & sound
#10 Post by dolphin_oracle »
entropyfoe wrote:When will beta1 or beta2 be public betas?
its public now, in the wide open.
Locked
