dual boot: error messages
Hello,
My System:
MBR dual boot: Windows 7 Starter and MX Linux 18.3 (installed yesterday)
I have an about 10 years old netbook:
Processor: Intel Atom 270N
RAM: 1 GB
HD: 160 GB
System: 32 bit
Screen 10.1 inch
When I boot, there are some error messages: Hope you can read it.
Is this normal?
Thank you.
My System:
RAM: 1 GB
HD: 160 GB
System: 32 bit
Screen 10.1 inch
Is this normal?
Thank you.
Re: dual boot: error messages
some of those old netbooks have wonky graphics. what graphics hardware does it have?
So this errors have something to do with the graphic card?
-> This is a Mobile Intel(R) 945 Express Chipset Family.
possibly anyway.
I assume that you are not getting to a desktop?
you could try
xorg=intel
FWIW antiX with the 4.9 kernel may work better anyway.
Well, the desktop appears. But there are windows who are too big. For example libre Office. The window has not place on the screen. And I am not able to make it smaller with the mouse. I can not see the bottom of the window.
I have never used any linux distrubution until now. So can you exacly say me, where I have to paste this code?
if you get a desktop, you don't need to paste it, but if you did, you would do it on the live media boot screen.
as to resolution, I wonder what your system is defaulting to. those old netbooks only have 1024/600 screens. but usually running apps "full screen" snaps them to the screen size.
So I can ignore this "boot-errors"?
I have tried Libre Office on my eeepc901 and get the same problems as Duliwi, but Libre Office Writer on its own works OK, as does Firefox and all other apps I have tried.
BTW Alt-leftclick drag is useful for those cases which hide the bottom of the screen.
P.S. The eeePC is running MX15 32-bit.
I would if its working.
If you want, you can get rid of the plymouth error by disabling or unintalling plymouth. You can disable in mx-boot-options.
