Network button problem
Network manager icon from bottom panel, next to the date, show not connected even if connected. Network works but button display is erroneus.
Re: Network button problem
if the network is configured by some other method, say /etc/network/interfaces, then network-manager-gnome will not manage it and it will show odd messages.
looking at your other threads, I'm suspecting a policykit issue here as well, as network-manager-gnome utilizes the policykit system for permissions. It probably can't figure out what is going on, even if network-manager (the daemon) has already made your connection.
From one of his threads about an Options Manager (not sure what that is), he mentioned MATE.
Might want to check how and from where he installed his MATE DE.
policykit starts at the start-up, it is checked as starting service at boot
but does the authentication agent start?
how about posting the info from the "Quick-system-info" tool in our menu.
sorry, where is that quick system info tool ?
should be in teh "System" menu, and also in MX-tools menu.
