Hello to the community. I'm a new MX Linux user!
I'm using MX as my main OS for a month++ and i am really really happy.
I leave Windows OS in the past and I do not intend to go back!!
I faced some problems on my trip to modify MX, but i overcame them quickly.
I'm gonna share with you one problem i face that i can't find a working "solution".
It's not that crazy, but it annoys me.
I use Compiz as my default WM for 1 week or more.
Everything was starting smoothly in my booting process.
But, after i installed Albert, WM does some mini laggy blinks during the boot process.
I disabled Albert from autostart but the problem is still there!
When i installed Albert, some dependencies of Qt got installed also.
Is it possible that Qt cause that mini lags-blinks?
I can provide you a video if that's helpful.
Thank you in advance for your time!
WM Lags-Blinks during boot process
Re: WM Lags-Blinks during boot process
Do you still get the blinks if you're not running Compiz?
You can always try uninstalling Albert and then running "sudo apt autoremove" to get rid of those Qt dependencies to see if those are the problem, too.
Thank you for your reply.
I managed to find the solution!
I just cleared out the sessions from ~/. cache/sessions/ and the boot process runs smoothly now.
