Reduce locales so update speeds up!
apt dist-upgrade takes a long time to compile endless, for me useless, Locales like Brazilian Portuguese ...
Yes i think i can do it my own by dpkg-reconfigure locale, but if its reduced otb that would be useful for anybody?!
Do you have a wishlist?
Thanks for MX Linux
Thanks for MX Linux
- Eadwine Rose
- Administrator
Re: Reduce locales so update speeds up!
As su enter:
uncheck all that you don't want and choose a default.
You only have to do this once on the install and that's that. Upgrades and stuff don't go through endless locales then. Mine just went with only the English and Dutch language locales getting upgraded.
dpkg-reconfigure locales
How would you feel if we removed your locale since it is useless for ...?JohnML wrote: ↑Mon Feb 18, 2019 11:58 am apt dist-upgrade takes a long time to compile endless, for me useless, Locales like Brazilian Portuguese ...
Thanks for MX Linux
As you posted and Eadwine added, it takes 2 seconds to reconfigure.
This particular one won't go far, but in general users can request "enhancements" in the Bugs software:Do you have a wishlist?
http://bugs.mxlinux.org
Please don't report it as a bug, or a feature request.
If you forum search
query: localepurge
author: skidoo
you will find that we (me, and others) have discussed locales management in great depth.
Sometimes the topic focus has been toward "reducing bloat", at other times it has been toward "optimization" ~~ the retrieval of extraneous translations files during each apt update operation can incur significant delay, as well as the (re)building of locales-related files following each package install/upgrade operation.
Content from the pre-existing discusssions could be distilled into a wiki page.
How to title the page? It is a subject which coult "fit" under multiple descriptions:
"customizations / tweaks to consider after installing"
"customizations / tweaks to consider before performing [ live-remaster | snapshot | backup | install ] "
If you forum search
query: localepurge
author: skidoo
Ok, i will not report it as a Bug, because its No bug!
Just as an Idea: Reduce the locales to these few the installer offers in first(?) screen ?!
What about an one liner to comment all the locales that are not the default ones?
Back up /etc/locale.gen because I am not sure it works for any LANG settings (it worked for me for en_US.UTF-8 but if it doesn't find your LANG in the file it will comment out all the locales) -- first line makes a copy of your locale.gen
sudo cp -i /etc/locale.gen /etc/locale.bak
sudo sed -i "/^$LANG\|^#/! s/.*/# /" /etc/locale.gen
Any thought this could be added to what MX System Locales has? I realize it would require an actual GUI with 2 lines and buttons or something like that. Would be very handy.Adrian wrote: ↑Mon Feb 18, 2019 4:21 pm What about an one liner to comment all the locales that are not the default ones?
Back up /etc/locale.gen because I am not sure it works for any LANG settings (it worked for me for en_US.UTF-8 but if it doesn't find your LANG in the file it will comment out all the locales) -- first line makes a copy of your locale.genCode: Select all
sudo cp -i /etc/locale.gen /etc/locale.bak sudo sed -i "/^$LANG\|^#/! s/.*/# /" /etc/locale.gen
It works for people who use one locale, it won't work for people who use multiple locales, those will still need to select/deselect locales manually (unless somebody comes up with a smarter script)
Yes. Not the one liner above, but something similar. ...will prototyping after boot-rescue has finished (soon - i hope;)Jerry3904 wrote: ↑Mon Feb 18, 2019 5:47 pmAny thought this could be added to what MX System Locales has? I realize it would require an actual GUI with 2 lines and buttons or something like that. Would be very handy.Adrian wrote: ↑Mon Feb 18, 2019 4:21 pm What about an one liner to comment all the locales that are not the default ones?
