Received two errors while using codecs installer.
error installing:
libdvdcss2-1.4.0-dmo1.amd64.deb
w64codecs20071007-dmo2-amd64.deb
Can't play dvds obviously.
TIA
[Solved] MX Codecs Installer
Re: MX Codecs Installer
Worked fine for me, can you please run the program from command line with "sudo -E mx-codecs" and display paste here whatever is spits out on the terminal? (use code or quote tags).
You might have a connectivity problem.
$ sudo -E mx-codecs
[sudo] password for mrpolite:
Gtk-Message: 16:23:57.494: Failed to load module "topmenu-gtk-module"
Could not resolve property : linearGradient4205
"mktemp -d"
exit code: 0
"dpkg --print-architecture"
exit code: 0
"wget -qO- http://deb-multimedia.org/dists/stable/main/binary-amd64/Packages.gz | zgrep ^Filename | grep libdvdcss2 | awk '{print $2}'"
exit code: 0
"wget -q http://deb-multimedia.org/pool/main/libd/libdvdcss/libdvdcss2_1.4.0-dmo1_amd64.deb"
exit code: 0
"wget -qO- http://deb-multimedia.org/dists/stable/non-free/binary-amd64/Packages.gz | zgrep ^Filename | grep w.*codecs | awk '{print $2}'"
exit code: 0
"wget -q http://deb-multimedia.org/pool/non-free/w/w64codecs/w64codecs_20071007-dmo2_amd64.deb"
exit code: 0
"dpkg -i libdvdcss2_1.4.0-dmo1_amd64.deb"
exit code: 2
"dpkg -i w64codecs_20071007-dmo2_amd64.deb"
exit code: 2
mrpolite@BMF:~
Can you try manually:
The dpkg needs to be executed in the same folder where you executed the wget command. There's a problem with the installation but I'm not sure what the problem is. What MX version do you use?
wget http://deb-multimedia.org/pool/main/libd/libdvdcss/libdvdcss2_1.4.0-dmo1_amd64.deb
I just ran dpkg and when it wouldn't run I realized Synaptic was open. I reran MX Codecs Installer with Synaptic closed and it worked.
Sorry and thanks.
Sorry and thanks.
Adrian wrote: ↑Thu Jul 12, 2018 5:33 pm Can you try manually:The dpkg needs to be executed in the same folder where you executed the wget command. There's a problem with the installation but I'm not sure what the problem is. What MX version do you use?Code: Select all
wget http://deb-multimedia.org/pool/main/libd/libdvdcss/libdvdcss2_1.4.0-dmo1_amd64.deb dpkg -i libdvdcss2_1.4.0-dmo1_amd64.deb
Thanks for the report! That's actually a bug that can be fixed, in MX Package Installer I check if other package managers lock the system and warn the user, I should probably apply the same thing to this app.
Hey of course Adrian! Thanks for MX and doing what you do.
