Hello,
fu-sen noticed that the clock localisation string in mx-installer on Transifex was incorrect when asking to right-click and select "Adjust date and time". Instead, the user should be asked to select "Properties". You will most likely be able to select the top suggestion and replace just that part of the string.
One string in mx-installer to redo
- Eadwine Rose
- Administrator
Re: One string in mx-installer to redo
Changed and all is at 100% again :) Including two xwindow containing strings that popped up
Done for french. But many typos left in general. We'll try to make correction before 21.
Done in Catalan.
MX-21.3_x64 KDE Plasma / ASUSTeK PRIME B250M-A / Intel Core i5-7500 / Intel HD Graphics 630 + i915 /1920 x 1080 pxl
Net: Realtek RTL8192EE + Realtek RTL8111/8168/8411 / HDD: 1 x SSD PLUS (1 TB); 2xST2000 (2x2 TB) / DVDRAM HL-DT.
Old Giza, Thanks for the fix.
I happened to notice the problem and reported it.
I translated Japanese again.
BALLOON | FU-SEN from Japan - https://balloon.gdn/ - https://github.com/fu-sen
