Hello translators. Some short strings to be translated in set-dpi on Transifex. Thank you!
https://www.transifex.com/anticapitalis ... et-dpipot/
Re: set-dpi on Transifex
ES done.
Is this string correct as is? Looks like it has some problems with punctuation/grammar/parentheses/whatever.
Otherwise German done.Open Apps will Require Restart for Changes to Take Effect
The excess use of capital letters can't be correct in something that is meant to be possible to translate. Is it used in any other languages than English? If you write like that in Swedish, you can't expect anyone to take it serious.Is this string correct as is?
Henry
Changed to
Any open applications will require a restart for changes to take effect
Aha! That we can translate. Thanks.
Much better.
Henry
Henry
I had ignored the capitals and now it's done, again. :)
