[SOLVED] how to make the terminal more or less transparent ?
- calixtus06
Hello, I'm french and I discover MX.
I've got XFCE desktop and sometimes I would like to see through the terminal to apply a command line .
Thanks
Nico
Thanks
Nico
- masterpeace
Re: how to make the terminal more or less transparent ?
go to mx tools > tweak > compositor tab > compositor dropdown menu choose compton > apply
add compton to "session and startup" in application autostart from whisker menu
then you will have to set the opacity / transparency in the terminal's preference .
Be aware different terminals may or may not allow transparency.
You don't have to use Compton - Xfwm compositor works fine. Just right click the xfce terminal window and select Appearance tab... as below:
MX 18 MX 19 - Manjaro
Just to piggy back on Chris' comment, actually any compositor will do the trick even old timey ones like xcompmgr.
- calixtus06
I can't translate "tweak" but I 've already the compositor dropdownmasterpeace wrote: ↑Sun Aug 25, 2019 12:19 pm go to mx tools > tweak > compositor tab > compositor dropdown menu choose compton > apply
Terminator has the option in Preferences > Profiles > Background
Not that I've ever used the option.
- calixtus06
Run MX Tools/MX Tweak, enable the Compton compositor (it seems to have fewer issues than the Xfwm one) and click the big wide Apply button. Then right=click anywhere in the Xfce terminal, click Preferences, click the Appearance tab, and drag the Opacity slider to your desired setting. I can't say about Terminator as I don't use it, but that's how you do it for the standard Xfce terminal.
(BTW your window manager is Xfwm. Conky is the desktop clock thing.)
- calixtus06
it works !! thanks !! "tweak" means "refine" and that's why I didn't understand the messages upper
