If you see there is an update of +1900 packages, please DON'T upgrade. Its upgrades to buster which breaks your whole system. It removes systemd-shim, lightdm, netwwork-manager, and other important packages. If you do, don't logout before reinstalling the removed packages.
Here are few resent issues:
viewtopic.php?f=104&t=51379#p513797
viewtopic.php?f=97&t=51377
Please DON'T update if +1900 packages
Re: Please DON'T UPDATE
This only applies if you have MANUALLY changed "stretch" to "stable" in the debian.list sources file. which isn't an MX issue. Please so edit your original post title.
if a user has manually changed "stretch" to "stable" in their sources, then just change it back. If they did it once, they can do it again.
Last edited by dolphin_oracle on Mon Jul 08, 2019 2:44 pm, edited 1 time in total.
People should update, what they don't need to do is muck up with their sources. Then the Debian warranty applies "if you break it, you get to keep the two pieces" -- which is not that bad as it sounds it's a re-install with preserving the /home so at most a 20-30 min. affair but again, not recommended and self-inflicted.
MODERATOR
Please change your post title. It implies that users should not update which is not correct unless a user has manually changed his repo list as detailed in post #2
- Eadwine Rose
- Administrator
Re: Please DON'T update if +1900 packages
I genuinely want to know.. why did you change that source to "stable"? What was the thought pattern to do this?
Not being condescending, I am just trying to understand so maybe we can prevent others from doing this.
I remember we had MX 16 users that had the same exact self-inflicted system borking back when Stretch became Stable. Note to self: put out a warning for MX 20 users in 2-3 years just before Bullseye goes to Stable.Eadwine Rose wrote: ↑Mon Jul 08, 2019 3:02 pm I genuinely want to know.. why did you change that source to "stable"? What was the thought pattern to do this?
LOL, but once MX 19 comes out with Buster repos, can't we just change the current MX 18.3 mx.list to match it and just jump to MX 19?
Read the explanation here as to why you are taking a big risk if you just switch repos after MX19 based on Buster is released.
https://mxlinux.org/mx-repos/
You can if you want to break your system. Buster's changed from GTK2 to GTK2 among other things, and MX-19 will change from Xfce 4.12 to 4.14. Buster-based distros are not compatible with their Stretch-based counterparts, which is what caused problems for people who had modified their repositories so they said "debian stable" instead of the original "debian stretch". Once Buster became the new Debian Stable and they ran an update their systems were hosed. You'll need to install MX-19 from scratch (but you can preserve /home when you do.)
Please read https://mxlinux.org/blog/debian-stable-is-now-buster/
