If this is in wrong forum move it
i have trouble printing to my HP Deskjet 2621 it knows the printer is there it shows up but any thing i want to print goes into the processing file and sits there
I am running MX on a Imac but have run Linux Mint 19 with no troubles , any help would be great
Printer problems
Re: Printer problems
When in doubt always provide quick system information (from the menu) with hardware related help requests.Cowboy44 wrote: ↑Tue Apr 02, 2019 1:10 am If this is in wrong forum move it
BTW: Welcome to the forum.
- Eadwine Rose
- Administrator
Open the menu, type
printer
in the search box up top, and then click
print settings
in the screen that pops up, right click on your printer and check if it has a checkmark next to enabled.
If it does not, make sure to remove the processing jobs first, otherwise as soon as you hit enable all those things will get printed
printer
print settings
Well I have learned something. I never knew that was in the menu. I have always just kept localhost bookmarked.
Many thanks for info it seems to be working again
- Eadwine Rose
- Administrator
Glad to hear that!
Well i thought it was fixed
went to print a document this morning printer printed a plank page nothing on it out of ink i thought
did a HP test page prints
went back to document printed a blank page
I had this same problem with mint debian when i tried it
But not with Mint Mate
In my experience the HP printers won't print using the stock MX Linux image viewer. Try installing a different image viewer like Mirage or some other one that is not the stock MX Linux image viewer. Once it prints remove the stock MX Linux viewer.
The above video shows a simple way to set up HP printers.
I am wondering if this could be added to MX because it allows newbies who have no terminal knowledge to easily set up their printers.
If it was added to the whisker menu as something like "HP Printer Setup" it would be easily found.
