Multi-boot of Encrypted distros
Vargr
#1 Post by Vargr »
https://medium.com/@manujarvinen/settin ... a1fcf8d502
This article is aimed at distro hoppers who like to install multiple Linux distributions to their system drive and to be able to replace them with minimal effort when new ones come along.
I'm trying to adapt this guide, I don't need that many distros however having encryption on each one is a must.
I tried to follow the guide as closely as possible but had a few issues, so I never got very far.
- made the follow partitions (GPT)
sda1 /boot
sda2 swap (not in use for now)
sda3 MX18
sda4 Second System to be installed later
sda5 free space like in the article
sda6 free space like in the article
sda7 /work (temporary storage, no encryption needed)
- started to set up MX18 first but the sda1 boot was changed from fat32 to ext4, no problem there as I won't be using windows.
- set up Mx18 to be encrypted and installed on sda3 with the boot on sda1, no swap selected for now
- grub was installed on mbr, the option to use ESP was not available
That's where the problem is cause if I install a second system I lose the first.
Is there any reason for ESP to be unselect-able?
Re: Multi-boot of Encrypted distros
#2 Post by dolphin_oracle »
Yes You don't Have An esp.In Your partitions.
/boot is not the esp. /boot is the place where the grub folder and initrd will be stored.
#3 Post by Adrian »
I think ESP needs to be a FAT partition with the ESP flag set up.
Vargr
#4 Post by Vargr »
Adrian wrote: Tue Feb 19, 2019 9:03 pm I think ESP needs to be a FAT partition with the ESP flag set up.
It was a fat32 partition with the ESP and BOOT flag on, but the MX installer changed to ext4.
Testing on a vm right now and the installer is not even showing the first partition as an option for boot :frown:
#5 Post by dolphin_oracle »
Vargr wrote: Thu Feb 21, 2019 3:15 pm
just saying, again, that the /boot partition is not the same thing as an ESP. the /boot is a seperate unencrypted partition housing the grub boot files, except for the EFI stub, which will be stored on the ESP (the fat32 formated partition).
So a UEFI encrypted setup will have the following at minimum.
1. ESP partition (fat32)
2. /boot partition (ext4 in our installer's case)
3. / (root) partition for the system
optionally you can have a /home partition and a /swap partition.
Vargr
#6 Post by Vargr »
So I'd have to change to something like this?
sda1 fat32 with the esp flag
sda2 boot (ext4)
sda3 swap (not in use for now)
sda4 MX18
sda5 Second System to be installed later
What the minimum size for the fat32 and boot partitions?
#7 Post by dolphin_oracle »
the ESP can be pretty small. some folks use 128 MB, I think we use 256MB for the ESP, and 256MB for the /boot when we make one of those in the autoinstaller. I would go larger on /boot if you plan to install multiple kernels.
Vargr
#8 Post by Vargr »
Testing on a VM I had this set up
It went perfect until the grub install
#9 Post by dolphin_oracle »
did you run the installer after you made your partitions, or did you try to make some partitions after running the installer.
sorry I can't ready the error messages or anything in the screenshots.
Vargr
#10 Post by Vargr »
Ran the installer after making the partitions.
Those screenshots got massively reduced, the first is just showing the format
sda1 fat32 with the esp flag 128mb
sda2 boot (ext4) 350mb
sda3 MX18 encrypted 10gb
sda4 open for second system 10gb
The error occurred right after installing grub.
"Sorry, installing GRUB failed. This may be due to a change in the disk formatting. You can uncheck GRUB and finish installing then reboot to the LiveDVD or LiveUSB and repair the installation with the reinstall GRUB function."
