This looks like quite an innovation that might be usable for folks wanting to run xfce, use a tiler (the easy way) and are willing to give it a whirl. Zentile with xfce4...
https://www.reddit.com/r/unixporn/comme ... h_zentile/
https://github.com/blrsn/zentile
All you need to do to get it functioning on MXLinux 18.3 is download the binary, mark it executable and run per the instructions on github.
Zentile & xfce
Zentile & xfce
Re: Zentile & xfce
Hello,
... Zentile is a good idea to start and try the tiling way with MX.
... And like you, I also like bspwm WindowManager ... but my favorite light & userfriendly per default is (icewm, the antiX choice too )
viewtopic.php?f=140&p=573161#p573161
Re: Zentile & xfce
Right now I'm quite enamored with dwm & hlwm as well as bspwm (bspwm is my favorite, but I reserve the right to change my mind.)
Re: Zentile & xfce
... Right.
