Is there a good way to run a script at logout (that is, xfce4-session-logout)?
1) Rename /usr/bin/xfce4-session-logout and replace it with a script which ends by calling the renamed xfce4-session-logout. https://forum.xfce.org/viewtopic.php?id=10859 This works, but I don't like it.
2) In /etc/lightdm/lightdm.conf, session-cleanup-script=my-script: "The script runs when I log out by restarting the machine, but it does not run when I merely log out without restarting." https://ubuntuforums.org/showthread.php?t=1918649
3) command in .bash_logout "does not run for an ordinary logout." https://superuser.com/questions/410525/ ... -commands
Thanks
How to run script at logout? (solved)
Re: How to run script at logout?
MX does this with XFCE4 already, in order to run the "shutdown" sound. The file is /usr/local/bin/xfce4-session. There is another script also, /usr/local/bin/xfce4-session-logout.
You could edit one of these?
Laptop: Lenovo V15 ADA
Media Centre: Lenovo Q190
mx19 will support this feature. for 18, you will need to do as davemx says.
Yes, I should have said. XFCE is adding the feature you want to XFCE4.14, so you might want to wait until until MX19. You have to admire the MX devs for their inventiveness in adding features to XFCE via the /usr/local folders, hopefully their job will be simplified!dolphin_oracle wrote: ↑Tue Jul 30, 2019 4:26 pm mx19 will support this feature. for 18, you will need to do as davemx says.
Thanks to both of you. This will do nicely!
