When trying to install MX-18.3_x64, the installer stops with the message
Error: /boot/grub/theme/theme.txt
Error: invalid magic number
Error: you need to load the kernel first 4:141 missing separator after property name ‘fC’
viewtopic.php?f=92&t=48921
Unfortunately, I can't solve the problem.
I tried to install other versions of MX-18.3_x64, MX-18.3_August_x64, MX-19beta-1_x64, MX-17.1_x64, MX-17_x64. Unfortunately, the problem persists, only the error code changes, sometimes it is "X" sometimes "C"
Other distributions, not only Linux, I run without problems in Live mode, as well as I can install on an ssd disk.
What should I do?
