minitube
minitube
It seems that minitube needs gstreamer0.10-ffmpeg which brings in libavcodec53 libavformat53 libavutil51 .
Can it (the one in MX-14) work with phonon-backend-vlc or phonon-backend-gstreamer?
Re: minitube
*bump*
anyone know?
anyone know?
Re: minitube
I'll have to try to build it that way. It looks possible.
But first I'll have to build phonon-backend-vlc because when wheezy-backports built the new vlc they didn't build the matching phonon-backend, so it's now been removed by that upgrade...
Re: minitube
You should be able to reinstall the CR rebuild of phonon-backend-vlc--I don't know why that upgrade removes it, unless it's not preferring the "mepis" versions on the command line. Reinstalling in Synaptic goes without a hitch.
But rebuilding gstreamer-ffmpeg against the newer libav in backports would be the best solution. It also has an option to use an internal ffmpeg, but that would make the final package that much bigger--best to use the backports packages that vlc already requires.
Tim, do you have time to redo gstreamer-ffmpeg? I can if you don't.
Or how about smtube? That's a small package, and can be set to use vlc as the player, so it does not drag in mplayer or gstreamer-ffmpeg at all.
Re: minitube
It doesn't seem like the latest smtube got into the repo, for some reason, but is in here:
http://ubuntuone.com/3cptlJl8RY53HQSLLwznID
I also believe that smtube would allow for the removal of any phonon backends, libphonon4, and gstreamer-ffmpeg.
Re: minitube
I think that smtube would be a better choice than minitube for the iso. As mentioned in the previous posts it has less dependencies than minitube and it is also very light on resources compared to minitube ( for those with lower resource systems ). It also lets you pick the media player for playback as well as the playback quality so those who are concerned about bandwidth usage it uses less. Monitor your network usage while using minitube for a couple hours and you will see a big difference. Also, keep in mind that it requires a relatively recent version of Qt which may become an issue with future releases / updates to minitube.
Dale
Dale
Re: minitube
We had smtube in alpha4, but several users claimed it didn't work. I think the real issue wasn't that smtube didn't work, but would only start working the first time it was opened once user had set up vlc as the default (even though it was set up to be the default) before searching and playing the video.
Re: minitube
I've put the newer smplayer / smtube in the M12 Testing CR.
The current Minitube 2.0 works in M12 with phonon-backend-vlc & without gstreamer-ffmpeg, but in MX-14 that results in no sound. Same versions of the libav stuff, vlc, minitube & phonon. Vlc plays the link with sound if pointed there manually. Puzzled.
Minitube 2.1.5 is giving me build problems. Qmake generates build lines in the Makefile for non-existent translations files!
Working on it...
Working on it...
Re: minitube
Minitube 2.1.5 exhibits the same behavior.
Re: minitube
If it is taken out please put minitube in the meta installer. It is more polished than smtube.
