libmpc-dev: unmet dependency
robbwu
#1 Post by robbwu »
Hi there,
Not sure if this is the right place to ask for help.
I tried to install a specific package libmpc3-dev but encountered the following error:
$ sudo apt install libmpc-dev
Reading package lists... Done
Building dependency tree
 libmpc-dev : Depends: libmpc3 (= 1.0.3-1+b2) but 1.1.0-1~mx17 is to be installed
Any help?
Thanks in advance
Best regards
--robbwu
Eadwine Rose
Re: libmpc-dev: unmet dependency
#2 Post by Eadwine Rose »
Can you please post the output of MX Tools - Quick System Info?
Just hit paste in a reply, the formatting happens automatically.
Welcome to the forum!
robbwu
#3 Post by robbwu »
Here you go!
System:    Host: mx Kernel: 4.19.0-5-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
           Desktop: Xfce 4.12.3 Distro: MX-18.3_x64 Continuum May 26  2019
Machine:   Type: Laptop System: LENOVO product: 4286CTO v: ThinkPad X220 serial: <filter>
           Mobo: LENOVO model: 4286CTO serial: <filter> UEFI [Legacy]: LENOVO
           v: 8DET54WW (1.24 ) date: 10/18/2011
Battery:   ID-1: BAT0 charge: 0 Wh condition: N/A model: N/A status: Unknown
CPU:       Topology: Dual Core model: Intel Core i3-2350M bits: 64 type: MT MCP
           arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18341
           Speed: 1389 MHz min/max: 800/2300 MHz Core speeds (MHz): 1: 814 2: 830 3: 805 4: 812
Graphics:  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
           vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
           Display: x11 server: X.Org 1.19.2 driver: intel resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 18.2.6
Audio:     Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Lenovo
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0
           Sound Server: ALSA v: k4.19.0-5-amd64
Network:   Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e v: 3.2.6-k
           port: 6080 bus ID: 00:19.0
           Device-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce v: kernel
           port: 5000 bus ID: 03:00.0
Drives:    Local Storage: total: 232.89 GiB used: 13.67 GiB (5.9%)
           ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 93.02 GiB used: 13.67 GiB (14.7%) fs: ext4 dev: /dev/sda4
Sensors:   System Temperatures: cpu: 59.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 2982
           1: deb http://mirrors.rit.edu/mxlinux/mx-packages/mx/repo/ stretch main non-free
Info:      Processes: 201 Uptime: 1h 38m Memory: 3.74 GiB used: 1.47 GiB (39.4%) Init: SysVinit
           runlevel: 5 Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12 inxi: 3.0.33
#4 Post by timkb4cq »
The likeliest reason for this is that you, at some point, installed a package from the MX Test repository - either libmpc3 directly or another package that pulled libmpc3 in as a dependency.
Since libmpc-dev must be exactly the same version as libmpc3 you are getting this error. Install libmpc-dev from the Test repository using the MX Package Installer. You'll have to uncheck the checkbox that hides library & developer packages and Refresh the list to see it.
robbwu
#5 Post by robbwu »
Yes sir, you are spot on. Thanks!
Problem seems to be resolved by installing libmpc-dev from MX testing repo.
Cheers,
Return to “MX Repositories”
