I have mentioned this trouble at another thread; however, as suggested, I'm opening this new one in order to allow me assign it as solved once I get the due answer!
Here, the QAS :
Snapshot created on: 20210111_1539
System: Host: <filter> Kernel: 5.10.0-8.1-liquorix-amd64 x86_64 bits: 64 compiler: N/A
parameters: audit=0 intel_pstate=disable
BOOT_IMAGE=/boot/vmlinuz-5.10.0-8.1-liquorix-amd64
root=UUID=<filter> ro audit=0 intel_pstate=disable splash
quiet
Desktop: Xfce 4.14.2 tk: Gtk 3.24.5 info: xfce4-panel wm: xfwm4 dm: LightDM 1.26.0
Distro: MX-19.3_ahs_x64 patito feo February 15 2019
base: Debian GNU/Linux 10 (buster)
Machine: Type: Desktop Mobo: ASUSTeK model: M5A78L-M LX/BR v: Rev X.0x serial: <filter>
BIOS: American Megatrends v: 1101 date: 04/19/2013
CPU: Topology: Dual Core model: AMD Athlon II X2 240 bits: 64 type: MCP arch: K10
family: 10 (16) model-id: 6 stepping: 2 microcode: 10000C7 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 11249
Speed: 2800 MHz min/max: 800/2800 MHz Core speeds (MHz): 1: 2800 2: 2800
Vulnerabilities: Type: itlb_multihit status: Not affected
Type: spec_store_bypass status: Not affected
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: AMD Cedar [Radeon HD 5000/6000/7350/8350 Series]
vendor: Hightech Information System driver: radeon v: kernel bus ID: 01:00.0
chip ID: 1002:68f9
Display: x11 server: X.Org 1.20.9 driver: ati,radeon unloaded: fbdev,modesetting,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 5.10.0-8.1-liquorix-amd64 LLVM 10.0.0)
v: 3.3 Mesa 20.1.8 compat-v: 3.1 direct render: Yes
Audio: Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1002:4383
Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
vendor: Hightech Information System driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aa68
Device-3: Logitech OrbiCam type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-3:2
chip ID: 046d:0892 serial: <filter>
Sound Server: ALSA v: k5.10.0-8.1-liquorix-amd64
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel port: e800
bus ID: 02:00.0 chip ID: 10ec:8168
Drives: Local Storage: total: 1.02 TiB used: 96.58 GiB (9.3%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-00RKKA0 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s serial: <filter>
rev: 0A80 scheme: MBR
ID-2: /dev/sdb vendor: Kingston model: SA400S37120G size: 111.79 GiB block size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: B1E2 scheme: MBR
Partition: ID-1: / raw size: 55.89 GiB size: 54.77 GiB (97.98%) used: 15.28 GiB (27.9%) fs: ext4
dev: /dev/sdb1
ID-2: /home raw size: 435.66 GiB size: 427.82 GiB (98.20%) used: 81.31 GiB (19.0%)
fs: ext4 dev: /dev/sda3
Sensors: System Temperatures: cpu: 37.4 C mobo: N/A gpu: radeon temp: 41 C
Fan Speeds (RPM): N/A gpu: radeon fan: 0
Repos: No active apt repos in: /etc/apt/sources.list
1: deb http://mirror.unesp.br/debian/ buster-updates main contrib non-free
1: deb http://mirror.unesp.br/debian/ buster main contrib non-free
2: deb http://deb.debian.org/debian-security/ buster/updates main contrib non-free
3: deb http://mirror.unesp.br/debian/ buster-backports non-free contrib main
1: deb https://mirrors.evowise.com/mxlinux-packages/mx/repo/ buster main non-free
2: deb https://mirrors.evowise.com/mxlinux-packages/mx/repo/ buster ahs
Active apt repos in: /etc/apt/sources.list.d/skype-stable.list
1: deb [arch=amd64] https://repo.skype.com/deb/ stable main
Active apt repos in: /etc/apt/sources.list.d/softmaker.list
1: deb https://shop.softmaker.com/repo/apt/ wheezy non-free
1: deb http://repo.vivaldi.com/stable/deb/ stable main
Info: Processes: 235 Uptime: 2d 20h 34m Memory: 7.77 GiB used: 2.53 GiB (32.5%)
Init: SysVinit v: 2.93 runlevel: 5 default: 5 Compilers: gcc: 8.3.0 alt: 8
Shell: quick-system-in running in: quick-system-in inxi: 3.0.36
Any clue of what is happening?...
