Hello,
I have a couple of questions about terminal in Linux,
1)
I know that file names are case-sensitive, but what about terminal, for example when I have prompt with this message:
can I just type lower case "y" and hit enter or do I have to type upper case "Y" as shown, and hit enter? Is there any difference? I saw some people don't even type "y", they just hit enter without typing anything, will it work?
2)
I saw someone used commands like:
and I know that these flags enable auto accept for prompt when installing or updating packages, but some I heard that this flag can cause problems and it is better to accept manually, is that true? What is the best way to update and upgrade packages using apt-get in one line?
3)
When I use
how can I see in the terminal, if I have updates available? Because all I can see is a bunch of links
