Got a gift with an online order, but.. what is it?
- Eadwine Rose
- Administrator
Other than a leather strap with two push clip things... THAT bit I COULD deduct myself.
When it is rolled like that it's about 1cm in diameter.
What IS this??
What IS this??
Re: Got a gift with an online order, but.. what is it?
I'd guess its to wrap a cable (cable tie).
An wedding ring from a very cheap groom?
- Eadwine Rose
- Administrator
I think you're right. It came with an order of ear pads. Those foam things of my wireless headphones needed replacing.
So I guess it is to wrap the wireless cable with..
Wireless cable?
Sure just like "military intelligence", "jumbo shrimp" ...
So that second picture Eadwine posted would be a picture of it doing its job.
Yep...
- Eadwine Rose
- Administrator
