Is it possible to get the current versions of bspwm & sxhkd loaded into the MX18+ testrepos (or somewhere a simple guy like me can find them)?
When I try to do a manual install dependency software fails:
sudo apt-get install libxcb-xinerama0-dev
Reading package lists... Done
Building dependency tree
libxcb-xinerama0-dev : Depends: libxcb-xinerama0 (= 1.12-3) but 1.13.1-1~mx17+1 is to be installed
The sources & build instructions for the bspwm/ sxhkd install software are available here:
https://github.com/baskerville/bspwm/wiki
Thank you *TOO MUCH*
