REQUEST: EHfive/pulseaudio-modules-bt
casket
#1 Post by casket »
Thank you for taking interest in my request. I want this to be ported in MX Linux. Can anyone help me?
Source: https://github.com/EHfive/pulseaudio-mo ... wJ3Y29x2V4
This would mean alot!
System:    Host: mxCasket Kernel: 5.1.2-antix.1-amd64-smp x86_64 bits: 64 Desktop: Xfce 4.12.3
           Distro: MX-18.3_x64 Continuum Apr 7  2019
Machine:   Type: Portable System: Dell product: Vostro1510 v: Null serial: <root required>
           Mobo: Dell model: 0M277C serial: <root required> BIOS: Dell v: A15 date: 03/18/2009
Battery:   ID-1: BAT1 charge: 32.0 Wh condition: 42.2/48.8 Wh (86%)
CPU:       Topology: Dual Core model: Intel Core2 Duo T6670 bits: 64 type: MCP
           L2 cache: 2048 KiB
           Speed: 1851 MHz min/max: 1200/2201 MHz Core speeds (MHz): 1: 1649 2: 1730
Graphics:  Device-1: Intel Mobile GM965/GL960 Integrated Graphics driver: i915 v: kernel
           Display: x11 server: X.Org 1.19.2 driver: intel resolution: 1280x800~60Hz
           OpenGL: renderer: Mesa DRI Intel 965GM v: 2.1 Mesa 18.3.2
Audio:     Device-1: Intel 82801H HD Audio driver: snd_hda_intel
           Sound Server: ALSA v: k5.1.2-antix.1-amd64-smp
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           IF: eth0 state: down mac: 00:21:70:9f:23:f6
           Device-2: D-Link type: USB driver: rtl8192eu
           IF: wlan0 state: up mac: 40:9b:cd:99:5d:c3
Drives:    Local Storage: total: 465.76 GiB used: 298.28 GiB (64.0%)
           ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050M size: 465.76 GiB
Partition: ID-1: / size: 19.56 GiB used: 9.54 GiB (48.8%) fs: ext4 dev: /dev/sda5
           ID-2: /home size: 16.63 GiB used: 5.63 GiB (33.9%) fs: ext4 dev: /dev/sda7
           ID-3: swap-1 size: 7.97 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
Sensors:   System Temperatures: cpu: 52.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 3200
Info:      Processes: 190 Uptime: 34m Memory: 3.85 GiB used: 1.47 GiB (38.3%) Shell: bash
           inxi: 3.0.33
Re: REQUEST: EHfive/pulseaudio-modules-bt
#2 Post by Stevo »
Needed to build:
pulseaudio>=11.59.1
bluez~=5.0
dbus
sbc
[Optional] ffmpeg(libavcodec>=58, libavutil>=56) >= 4.0
[Optional] fdk-aac(-free)>=0.1.5: pulseaudio-modules-bt use LC-AAC only
[Optional] ldacBT/libldac
cmake
pkg-config, libtool, ...
We currently only have pulseaudio 10.0 available in our Stretch base. :frown:
casket
#3 Post by casket »
Stevo wrote: Fri May 31, 2019 6:02 pm Needed to build:
pulseaudio>=11.59.1
bluez~=5.0
dbus
sbc
cmake
I kinda know this, that the dependencies are no match for the module I want to install. Therefore I have had everything anticipated that these dependencies might need to be ported as well and asked for it. If you are willing to do all these then it would be great for all of us Veteran Stevo! Cheers!
#4 Post by Stevo »
Well, yes, we've backported pulseaudio in the past with success, and we do have the updated ffmpeg in our test repo already, so I'll look at it later.
casket
#5 Post by casket »
I would be looking up to you then!
