foxreader works only from apimage
dimzev
#1 Post by dimzev »
For PDF files i have install foxreader.
I don't see this option when open right click menu up to PDF file.
for open it must run appimage from beginning.
can you help me ?
Richard
Re: foxreader works only from apimage
#2 Post by Richard »
@dimzev,
Welcome to the forum.
You seem to be having unusual problems in your 3 posts, so far.
We will need some information about your computer. Find the Quick System Information in the menu, click on it, then open a new reply under this topic, click in the new post, then right click and Insert or Paste.
Also, tell us which version you have installed.
regards, Richard.
Richard
#3 Post by Richard »
In MX 18.3, the current stable version, there are already installed a PDF reader that should open PDF files by default.
Richard
#4 Post by Richard »
Ok, my eyes are open. I see you are using antiX.
For that you'll need to run, in a terminal,
inxi -Fxzr
copy the output, open a post to the forum, click on the
[ code ] paste the output here between [ /code ]
without the spaces within the brackets,
which greatly enhances readability of the data.
Richard
#5 Post by Richard »
the PDF reader installed in antiX 17 is Evince.
in antiX 19beta is Qpdfview.
dimzev
#6 Post by dimzev »
dim@antix1:~
$ inxi -Fxzr
  Host: antix1 Kernel: 4.9.160-antix.2-486-smp i686 bits: 32 compiler: gcc v: 6.3.0
  Desktop: IceWM 1.4.2 Distro: antiX-17.4.1_386-full Helen Keller 28 March 2019
  Type: Laptop System: Hewlett-Packard product: HP Compaq 6730b (GW687AV) v: F.08
  serial: <filter>
  Mobo: Hewlett-Packard model: 30DD v: KBC Version 96.18 serial: <filter>
  BIOS: Hewlett-Packard v: 68PDD Ver. F.08 date: 09/18/2008
  ID-1: BAT0 charge: 45.8 Wh condition: 46.6/46.6 Wh (100%)
  model: Hewlett-Packard Primary status: Unknown
  Topology: Dual Core model: Intel Core2 Duo P8400 bits: 64 type: MCP arch: Penryn
  rev: 6 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 9043
  Speed: 2267 MHz min/max: 800/2267 MHz Core speeds (MHz): 1: 2267 2: 800
  Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Hewlett-Packard
  driver: i915 v: kernel bus ID: 00:02.0
  Display: server: X.Org 1.19.2 driver: modesetting unloaded: fbdev,vesa
  resolution: 1280x800~60Hz
  OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express x86/MMX/SSE2 v: 2.1 Mesa 13.0.6
  Device-1: Intel 82801I HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
  v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k4.9.160-antix.2-486-smp
  Device-1: Broadcom Limited BCM4312 802.11b/g LP-PHY vendor: Hewlett-Packard
  driver: wl v: kernel port: 6000 bus ID: 02:00.0
  Device-2: Broadcom Limited NetLink BCM5787M Gigabit Ethernet PCI Express
  vendor: Hewlett-Packard driver: tg3 v: 3.137 port: 6000 bus ID: 85:00.0
  Local Storage: total: 111.79 GiB used: 7.07 GiB (6.3%)
  ID-1: /dev/sda vendor: Toshiba model: MK1252GSX size: 111.79 GiB
  ID-1: / size: 17.40 GiB used: 3.49 GiB (20.0%) fs: ext4 dev: /dev/sda3
  ID-2: /home size: 20.84 GiB used: 793.5 MiB (3.7%) fs: ext4 dev: /dev/sda4
  ID-3: swap-1 size: 6.52 GiB used: 400 KiB (0.0%) fs: swap dev: /dev/sda5
  System Temperatures: cpu: 46.0 C mobo: 43.0 C
  1: deb http://ftp.cc.uoc.gr/mirrors/linux/mx/antix/stretch stretch main nosystemd nonfree
  1: deb http://ftp.gr.debian.org/debian/ stretch-updates main contrib non-free
  1: deb http://ftp.gr.debian.org/debian/ stretch main contrib non-free
  Active apt repos in: /etc/apt/sources.list.d/geogebra.list
  1: deb http://www.geogebra.net/linux/ stable main
  No active apt repos in: /etc/apt/sources.list.d/onion.list
  Processes: 160 Uptime: 3h 07m Memory: 1.90 GiB used: 706.1 MiB (36.3%)
  Init: SysVinit runlevel: 5 Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12 inxi: 3.0.33
the right click on PDF files give me 2 options:
-evince
-mupdf
and work both of them .
i need foxreader because have options dont have the above PDF reader.
thank you very much Richard for your help
can you tell me if my laptop is 64 or 32 ?
manyroads
#7 Post by manyroads »
In your data above it says you are running:
Your system is capable of running 64-bit according to the HP specs I looked at. I recommend trying 64-bit from a LiveUSB to test it out. Personally I prefer sticking with 64-bit if at all possible. Many 32-bit apps are going away. 32-bit is all but gone.... sorry.
btw :welcome:
Edit: Here's the HP link: https://support.hp.com/us-en/document/c01324212
Return to “antiX”
