This is triggered by the --admin / -a option, and is seen in -S line, System.
For example, inxi -GSa or inxi -baz or inxi -Fazxx
This new support/debugging feature is available in inxi 3.0.34, hot off the presses last night. This might be of use to you, I already found a slightly misconfigured grub default linux command line item on one system with it. I know, I know, it's easy to cat /proc/cmdline, but this just saves a step, and gets all the results in one easy to read block.
inxi -baxxxzy80 --no-host
Kernel: 4.17.0-17.3-liquorix-amd64 x86_64 bits: 64 compiler: gcc v: 7.3.0
parameters: audit=0 BOOT_IMAGE=/boot/vmlinuz-4.17.0-17.3-liquorix-amd64
root=UUID=4f6b4acd-fa5c-400e-8b48-364b1f44dd17 ro quiet nomodeset
nouveau.modeset=0
Desktop: Xfce 4.12.4 tk: Gtk 2.24.31 info: xfce4-panel wm: xfwm4
dm: LightDM 1.18.3 Distro: Debian GNU/Linux buster/sid
Type: Desktop System: Gigabyte product: X470 AORUS ULTRA GAMING v: N/A
serial: <filter>
Mobo: Gigabyte model: X470 AORUS ULTRA GAMING-CF v: x.x serial: <filter>
UEFI [Legacy]: American Megatrends v: F2 date: 03/14/2018
6-Core: AMD Ryzen 5 2600 type: MT MCP arch: Zen+ speed: 1523 MHz
min/max: 1550/3400 MHz
Device-1: NVIDIA GT218 [GeForce 210] vendor: Gigabyte driver: nvidia
v: 340.107 bus ID: 09:00.0 chip ID: 10de:0a65
Display: x11 server: X.Org 1.20.0 driver: nvidia
resolution: 1280x1024~60Hz, 1280x1024~60Hz
OpenGL: renderer: N/A v: N/A direct render: N/A
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: 5.4.0-k
port: f000 bus ID: 06:00.0 chip ID: 8086:1539
Local Storage: total: 1.98 TiB used: 743.82 GiB (36.6%)
Processes: 376 Uptime: 14h 36m Memory: 31.43 GiB used: 6.15 GiB (19.6%)
Init: systemd v: 239 runlevel: 5 Compilers: gcc: 8.1.0 alt: 5/6/7/8
Shell: bash v: 4.4.23 running in: xfce4-terminal inxi: 3.0.34
