samba 2
samba 2
Hi
I am having a strange problem.
Just found Antix and I love it
However I am unable to mount a windows10 share from the 64 bit version
I get an error(22) invalid argument
Checking the kernel log I see that the vers=2.0 argument is unknown
This works from the 32 bit version ?
tried on several different machines and vmplayer and Virtualbox with the same results
Any ideas?
Any ideas?
Re: samba 2
Hi, and welcome. I'm going to move this to the antiX Forum.
Re: samba 2
often with windows10 you must specify a username and password, even if the share is not password protected.
I've got a windows10 share at home. I'll try out antiX on it tonight and see if it works, but I've done this in the past without issue. I use the "connectshares" utility in antiX for this.
if you want to post the command you were using to mount the share I can try that too.
one more option: spacefm in antiX can be configured to mount samba shares as well.
Re: samba 2
Hi
Thanks for the response
I am using the username and password variables on the mount line
I can use the exact same mount line on 32 bit version and it works
I tried "connectshares" but cannot find a way to change to samba version 2 or higher
Windows has stopped using samba 1
Re: samba 2
Hi
Command is
mount -t cifs //192.168.1.10/stuff /mnt -o username=XXXXX,pasworrd=XXXXXX,vers=2.0
Thanks
Command is
Thanks
Re: samba 2
Ok thanks. I'll investigate when I get home tonight, unless someone else gets to it first.john.mcmstr wrote: ↑Mon Feb 25, 2019 11:49 am Hi
Command is
Thanks
Re: samba 2
Hi to all.
Any help / update ?
Am out of ideas
Thanks
John
Any help / update ?
Am out of ideas
Thanks
John
Re: samba 2
Not a direct answer, but you can activate smb 1 in Windows.
MX-19-KDE x64, on Ryzen 5, 16GB RAM, SSD. Nvidia graphics.
Re: samba 2
Anyone?
smbclient works fine with the -m SMB3 option
Thanks
Thanks
Re: samba 2
right now I can't duplicate your problem.
here's the output of "findshares", which finds my shares OK
and using the connectshares tool it connects OK too. (you can see the mount point). The mount command connectshares uses doesn't specify a type of samba share at all.
a manual mount with this also works
the share is hosted by a windows 10 PC. I've done no special configuration to it.
this also works (modification of your mount command...in your post password is spelled wrong but I figure thats just a typo in your post.
So I'm not sure where your problem actually lies. Unfortunately network issues aren't my speciality but I was really hopping to find an issue with my antiX setup since I have the windows server, but I haven't found the problem.
demo@antix1:~
$ findshares
Local Host Name = antix1
Local IP Address = 192.168.1.133 on wlan0
Scanning from 192.168.1.133 on wlan0
Samba/Windows Shares
WORKGROUP
LINKSYS16521 192.168.1.100 Samba 3.0.28a
IPC$ IPC Service (Samba 3.0.28a)
WORKGROUP
MX 192.168.1.104 Samba 4.5.16-Debian
print$ Printer Drivers
IPC$ IPC Service (Samba 4.5.16-Debian)
HP_LaserJet_Pro_MFP_M225dw HP_LaserJet_Pro_MFP_M225dw
HOME
DESKTOP-8HGT9DD 192.168.1.110
HOME
MEDIAPC 192.168.1.142
ADMIN$ Remote Admin
baritone play along
C$ Default share
E$ Default share
IPC$ Remote IPC
media
scans
Users
Server Remote Resource Local Mount Point
192.168.1.142 media /mnt/mediapc/media\040on\040mediapc
sudo mount -t cifs //mediapc/media /mnt/test
sudo mount -t cifs //mediapc/media /mnt/test -o username=fred,password=fred
