minimized applications disappear
When I minimize applications including browsers they disappear and I can no longer find them. Where do they go and how do I get them back?; also, how do you add items to the panel and why do minimized apps not go to the panel?. Thanks
http://patentabsurdity.com/
AMD 64x2 2.6GHz 4GB ram MX-18.1 KDE regular updates
"beware a frequent flirt with potential disaster"
Re: minimized applications disappear
In the Users Manual in the Panel subsection.
Where dear sir do I find the panel subsection?Jerry3904 wrote:In the Users Manual in the Panel subsection.
Since you are running antiX, it would help to know which version, and which desktop manager you have selected, since antiX comes with several and the answer may be different (for example) for Icewm than it is for Fluxbox.
antix16, disappears running rox-icewm and running xfce
I installed xfce through synaptic so maybe something missing there.
Well try what is in the MX Users Manual, Customization > Panel subsection. May not all work for you.
Thanks again, took a quick look at that section and will study it further with trial and err till I get it going right.
In icewm apps.should be.minimized.to the icewm task bar by default. I would like to see a Screenshot of.your.situation. also inxi -F please.JBoman wrote:When I minimize applications including browsers they disappear and I can no longer find them. Where do they go and how do I get them back?; also, how do you add items to the panel and why do minimized apps not go to the panel?. Thanks
I cannot reproduce the problem here running live. I see tabs for minimized windows in IceWM and in xfce (installed via the meta-package installer) in the taskbar/panel.JBoman wrote:When I minimize applications including browsers they disappear and I can no longer find them. Where do they go and how do I get them back?; also, how do you add items to the panel and why do minimized apps not go to the panel?. Thanks
-- Richard Feynman
-- Richard Feynman
