Hi Mate,
how I can uninstall a Kernel in MXLinux?
atb/vvm
How to remove/uninstall a useless Kernel [SOLVED]
- chrispop99
- Global Moderator
Re: How to remove/uninstall a useless Kernel
If it's one that is available from the Package Installer, select it in the PI, then click the uninstall button.
Obviously make certain it's the one you want to remove!
There is no real reason to remove it however; they don't take up much space, and will cause no harm.
DELL XPS 15
Lots of test machines
DELL XPS 15
Yes,
you are right,
but by every boot
I have select the kernel 4.14 every time...
atb/vvm
you are right,
but by every boot
atb/vvm
- entropyfoe
You can also remove with synaptic.
But the behavior you report is not what I experience.
Once I go into the grub advanced tab and select the kernel I want to boot, it remembers the one I picked, and boots that one by default on the next boot.
A guru may weigh in here, but is this the expected behavior ?
Asus PRIME X470-PRO
Nvidia GeForce GT 710
on-board ethernet & sound
This is a problem,
I started MX without KernelSeletion
and it is always 4.19 active and not 4.14
With 4.19 is my Laptop frozen
atb/vvm
atb/vvm
- chrispop99
- Global Moderator
Re: How to remove/uninstall a useless Kernel [SOLVED]
MX Tools>Boot Options would allow you to select which kernel was the default to boot to.
There is an entry in the User Manual to give you a basic description, together with a link to more detailed information.
DELL XPS 15
DELL XPS 15
Boot with the kernel you want to keep
Start Synaptic.
Choose "Status" "Installed".
In the Quick Search box, enter the kernel ABI version: 4.19.0-1 (get with "uname -a" for other kernels)
Uninstall the headers, image, and other components of the 4.19.0-1 kernel.
Start Synaptic.
Stevo,
thanks
atb/vvm
thanks
atb/vvm
And finally go to /boot/grub/ and remove all remains from old kernel by hand. As I did.... because Synaptic did not removed all parts of old kernel .
P.S.
In a fresh iso ( latest iso of MX Linux that one download from website ), what is the default kernel ? 4.19 ?
P.S.
