Inkscape is an illustration editor which has everything needed to create professional-quality computer art. You can use it to make diagrams and illustrations, technical drawings, web graphics, clip art, icons and logos. A collection of hands-on tutorials show you how to combine lines, shapes and text of different types and styles to build up a picture.
A selection of powerful vector graphics editing tools comes as standard. There is excellent support for paths, gradients, layers, alpha transparency and text flow control. An extensive library of filters allow you to apply realistic effects and extensions allow you to work with bitmaps, barcodes and printing marks, amongst other things.
Most of the common vector formats are supported, including PDF, Adobe Illustrator and AutoCAD files, and it has unrivalled support for the SVG web graphics standard.
MX 17 Repository: The Inkscape Thread
We know have the 0.92.4 release of the drawing program in our test repository, backported from Sid. It will run on vanilla Stretch or MX 17-18 without requiring any other test repo libraries. Check the release notes for changes.
Re: MX 17 Repository: The Inkscape Thread
Great , Thanks for all the teams hard work.
Does it work for you? Feedback in this thread would be helpful.
@asqwerth yes i does .BTW. Its in the normal repo now :)
