AVL-MXE 5.11-rt kernel?
Hey there!
Big fan of AV Linux, it's really made getting my studio setup running on Linux WAY easier. Quick question on the AVL realtime kernel. Is there any estimate on when a 5.11-rt kernel might be available? Unfortunately my interface (MOTU m4) requires a 5.11 kernel to function. I have been using the Liquorix kernel, but it's not quite stable enough at the latency settings I would prefer to use. I've just started getting into playing MIDI drums, so I'm particulary sensitive to it. Latency is where I want it at a sample rate of 48K and a buffer size of 64, even 128 is acceptable. However with the Liquorix kernel, I get tons of overruns when I try and record anything. I can record with zero overruns at a buffer size of 512, which is perfect for everything except virtual instruments.
Not a big deal and I can totally wait, just curious if there was a time-line out there or if I should look into building my own kernel in the mean time.
Re: AVL-MXE 5.11-rt kernel?
Hi and thanks!Zaphod118 wrote: ↑Sun Jun 06, 2021 5:06 pm Hey there!
I don't really have a definitive answer at the moment: (a) the Kernels are usually compiled and uploaded by Trulan Martin as he is the only other person involved with AVL and he maintains the Kernel repo and we have not corresponded in a while or discussed an update.. (b) The next big fish for me to fry is getting ready for moving to Debian 11 bullseye, and (c) It seems other that in an increasingly number of cases the RT Kernel is becoming more of a PITA than its worth, it flat out doesn't work reliably at all with some newer hardware (including my own), the nVidia driver question is a constant issue and many (certainly not all) people seem to get the low latency performance they need from lowlatency and liquorix Kernels.
I guess in a nutshell if you are comfortable compiling your own 5.11 RT I would probably suggest doing that for now anyway. A very nice thing these days is that aufs is not needed for Snapshotting and Remastering any more so there is really not a lot of magical differences between the AV Linux kernel and one you roll yourself!
Thanks for the reply! That’s totally fair, wasn’t sure if there was a set release cadence or not. Good to know there’s not a whole lot of secret sauce in the kernel. I’ve got some experience with Gentoo so I’m no stranger to compiling my own kernel. Seems like that’s the way to go then. Thanks for the heads up on potential issues. Luckily the 5.9-rt kernel seemed to work with everything in my system except my interface so hopefully 5.11-rt will be similar. Since I’ve got you here might as well ask :) - anything obvious I should be aware of in configuring the kernel that’s not covered in the various Linux real-time audio guides?AVLinux wrote: ↑Mon Jun 07, 2021 3:03 pm
Hi and thanks!
Thanks again!
No, not that I'm aware of... always have a look at the 'staging drivers' section often there is up and coming support for newer interfaces in there (or there used to be anyway). For years I had an April annual release but I am fairly new to MX which necessitated some interim releases and now we're seeing a new Debian Stable release soon which will probably require yet another interim release..Zaphod118 wrote: ↑Mon Jun 07, 2021 7:14 pmThanks for the reply! That’s totally fair, wasn’t sure if there was a set release cadence or not. Good to know there’s not a whole lot of secret sauce in the kernel. I’ve got some experience with Gentoo so I’m no stranger to compiling my own kernel. Seems like that’s the way to go then. Thanks for the heads up on potential issues. Luckily the 5.9-rt kernel seemed to work with everything in my system except my interface so hopefully 5.11-rt will be similar. Since I’ve got you here might as well ask :) - anything obvious I should be aware of in configuring the kernel that’s not covered in the various Linux real-time audio guides?AVLinux wrote: ↑Mon Jun 07, 2021 3:03 pm
Hi and thanks!
Thanks again!
Here is a quick n' dirty Kernel guide for using GIT and building Debian Packages:
*SUGGESTED GUIDE TO BUILDING AN RT KERNEL WITH GIT
1. You should determine what the most recent RT Patch is and for which kernel version it applies.. Look at this web page:
https://mirrors.edge.kernel.org/pub/lin ... ojects/rt/
2. Let's use 5.9.1-rt19 as an example.. So first fetch the kernel source code with 'git clone':
git clone git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git linux
3. When the cloning of the Stable Kernel source has completed, change directory to the 'linux' directory:
cd linux
4. In order to build the kernel with RT Preemption we need to add a git remote for the RT Source code:
git remote add rt-stable https://git.kernel.org/pub/scm/linux/ke ... ble-rt.git
git remote add rt-devel https://git.kernel.org/pub/scm/linux/ke ... -devel.git
5. Now fetch the RT remote sources to your 'linux' directory:
git fetch --all
6. Then checkout the source code for the kernel which in our example is 5.9.1-rt19:
git checkout v5.9.1-rt19
7. When the checkout has completed successfully you will likely want to import the configuration of your current kernel:
cp /boot/config-`uname -r`* .config
8. If you want to browse or make changes to the current config then run the configuration utility 'xconfig'
make xconfig
9. Once configuration is complete you can build your kernel and create Debian packages:
make deb-pkg
I tried a xanmod 5.12.9-xanmod1-cacule kernel
https://xanmod.org/
and did some latency tests
https://support.digium.com/s/article/Ho ... tency-test
on my system
These are good figures. But how do they relate to Qjackctl settings of say Frames/Period - 128 , Sample Rate 44100? Periods/Buffer 2 in
https://xanmod.org/
on my system
Snapshot created on: 20210610_0243
System: Host: <filter> Kernel: 5.12.9-xanmod1-cacule x86_64 bits: 64 compiler: N/A
parameters: hwclock=local lang=de_DE tz=Europe/Berlin quiet nosplash splasht
Desktop: Openbox 3.6.1 info: xfce4-panel dm: SLiM 1.3.6 Distro: AVL-MXE
base: Debian GNU/Linux 10 (buster)
Machine: Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: H97M-PLUS v: Rev X.0x serial: <filter>
UEFI [Legacy]: American Megatrends v: 3602 date: 04/08/2018
CPU: Topology: Quad Core model: Intel Core i5-4590S bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 7 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 24001
Speed: 3001 MHz min/max: 800/3700 MHz Core speeds (MHz): 1: 3001 2: 3000 3: 3000
4: 3001
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spec_store_bypass status: Vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Type: srbds status: Vulnerable: No microcode
Type: tsx_async_abort
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0412
Display: x11 server: X.Org 1.20.10 driver: modesetting unloaded: fbdev,vesa
compositor: compton v: 0.1~beta2+20150922 resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 20.3.4
compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
Device-2: Intel 9 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:8ca0
Sound Server: ALSA v: k5.12.9-xanmod1-cacule
Network: Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: kernel port: f080
bus ID: 00:19.0 chip ID: 8086:15a1
Drives: Local Storage: total: 14.62 GiB used: 3.94 GiB (27.0%)
ID-1: /dev/sdd type: USB vendor: SanDisk model: Extreme size: 14.62 GiB block size:
physical: 512 B logical: 512 B serial: <filter> rev: 0001 scheme: MBR
Partition: ID-1: / raw size: N/A size: 12.21 GiB used: 64.3 MiB (0.5%) fs: overlay
source: ERR-102
ID-2: swap-1 size: 20.00 GiB used: 0 KiB (0.0%) fs: swap swappiness: 10 (default 60)
cache pressure: 50 (default 100) dev: /dev/sda6\040(deleted)
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C
Repos: Active apt repos in: /etc/apt/sources.list
1: deb http://liquorix.net/debian/ buster main
2: deb http://www.bandshed.net/kernels/apt/ buster main
3: deb [trusted=yes] https://cinelerra-gg.org/download/pkgs/debian10/ buster main
4: deb https://dl.winehq.org/wine-builds/debian/ buster main
No active apt repos in: /etc/apt/sources.list.d/connectify.list
1: deb http://deb.debian.org/debian/ buster-updates main contrib non-free
1: deb http://deb.debian.org/debian/ buster main contrib non-free
2: deb http://deb.debian.org/debian-security/ buster/updates main contrib non-free
3: deb-src http://deb.debian.org/debian/ buster main contrib non-free
Active apt repos in: /etc/apt/sources.list.d/kxstudio-debian-ppas.list
1: deb http://ppa.launchpad.net/kxstudio-debian/libs/ubuntu/ bionic main
2: deb http://ppa.launchpad.net/kxstudio-debian/music/ubuntu/ bionic main
3: deb http://ppa.launchpad.net/kxstudio-debian/plugins/ubuntu/ bionic main
4: deb http://ppa.launchpad.net/kxstudio-debian/apps/ubuntu/ bionic main
5: deb http://ppa.launchpad.net/kxstudio-debian/kxstudio/ubuntu/ bionic main
Active apt repos in: /etc/apt/sources.list.d/kxstudio-external.list
1: deb [arch=amd64,i386] https://kx.studio/repo/ stable free
2: deb [arch=amd64,i386] https://kx.studio/repo/ gcc5 free
1: deb http://ftp.halifax.rwth-aachen.de/mxlinux/packages/mx/repo/ buster main non-free
2: deb http://ftp.halifax.rwth-aachen.de/mxlinux/packages/mx/repo/ buster ahs
Active apt repos in: /etc/apt/sources.list.d/spotify.list
1: deb http://repository.spotify.com/ stable non-free
Active apt repos in: /etc/apt/sources.list.d/xanmod-kernel.list
1: deb http://deb.xanmod.org releases main
Info: Processes: 215 Uptime: 20m Memory: 15.33 GiB used: 497.9 MiB (3.2%) Init: SysVinit
v: 2.96 runlevel: 5 default: 5 Compilers: gcc: 8.3.0 alt: 8 Shell: quick-system-in
running in: quick-system-in inxi: 3.0.36
demo@mx1:~/rt-tests
$ sudo chrt -f 99 ./cyclictest -t1 -p 80 -i 10000 -n -l 100000
# /dev/cpu_dma_latency set to 0us
policy: fifo: loadavg: 0.08 0.14 0.17 1/499 13686
T: 0 (10817) P:80 I:10000 C: 46764 Min: 1 Act: 2 Avg: 1 Max: 41
demo@mx1:~/rt-tests
$ sudo hdparm -t /dev/sdc1
/dev/sdc1:
Timing buffered disk reads: 704 MB in 3.00 seconds = 234.39 MB/sec
Same test with the AVL-rt-kernel 5.9.1-rt20avl1:
alt_user@avlmx:/usr/src/rt-tests
policy: fifo: loadavg: 2.85 1.40 0.81 1/498 7290
T: 0 ( 6973) P:80 I:10000 C: 11880 Min: 1 Act: 2 Avg: 1 Max: 6
N.B.: There is a XANMOD-RT-kernel which I did not test.
Here the results for the XANMOD real-time Linux kernel (PREEMPT_RT)
$ uname -r
5.10.41-rt42-xanmod1
policy: fifo: loadavg: 3.20 1.62 0.72 1/334 5082
T: 0 ( 4748) P:80 I:10000 C: 12583 Min: 1 Act: 1 Avg: 1 Max: 10
I think I am finding out firsthand exactly what you mean here :) I successfully compiled the 5.11-rt kernel (thanks to your helpful quick guide!) by just copying the 5.9-rt-avl config. Compiled fine and installed everything, but rebooting with the new kernel turned my machine into a stuttering mess. Like several seconds of lag between pressing a key and seeing the letters appear on screen. I don’t have anything crazy either, I’m using a 10th gen i7 with integrated graphics. Is this the kind of thing you have seen? It’s odd because the 5.9-rt kernel worked fine except for my interface.
I’m thinking this might all be moot as in the meantime I have discovered that Reaper is much more stable at smaller buffer sizes than ardour.
Thanks again for your time and help!
- pianokeyjoe
I am reading this along to see what if any updates there were to this question. Sigh.. So basically any newer MIDI/AUDIO interfaces are going to need the latest kernel? If so, why? I am also mostly recording MIDI and midi synth virtual instruments so this does apply to me too. I will keep an eye on this thread.. I am sticking with my old stuff and AVL-MXE 19.3(the second update released in 2020)until things are sorted..
Pianokeyjoe
Intel i5 3.10ghz ,8GB ram, Intel onboard everything, 500GB HDD, MX-LINUX 19.3
