I'm not sure what I may have bumped but ...
The top row of Task Bar icons disappeared in File Manager.
I've tried right-clicking everywhere for a menu but no joy.
Is there a simple way to restore them, please?
On this laptop I'm running MX-17.
Thanks
File Manager Task Bar Icons Disappeared [Solved]
- NevilsStation
Custom-built PC w/i7 CPU running MX-16.
Re: File Manager Task Bar Icons Disappeared
Not on MX, but does Ctrl-M do it?
Control M togggles the menu bar on and off, which is good to know in case OP is also missing his dropdown menus. There's no hotkey for the status bar though. You can enable or disable it from within the View menu.
- NevilsStation
