$ deadbeef
starting deadbeef 1.8.0
server_start
searching for GUI plugins in /home/whell/.local/lib64/deadbeef
searching for GUI plugins in /home/whell/.eflocal/lib/deadbeef
searching for GUI plugins in /usr/lib/x86_64-linux-gnu/deadbeef
load_plugin_dir /usr/lib/x86_64-linux-gnu/deadbeef: scandir found 96 files
found gui plugin ddb_gui_GTK2.so
added GTK2 gui plugin
load gui plugin
checking GUI plugin: GTK2
found selected GUI plugin: GTK2
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/ddb_gui_GTK2.so
loading plugins from /home/whell/.local/lib64/deadbeef
loading plugins from /home/whell/.local/lib/deadbeef
loading plugins from /usr/lib/x86_64-linux-gnu/deadbeef
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/aac.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/adplug.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/alac.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/alsa.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/artwork.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/cdda.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/converter.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/converter_gtk2.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/dca.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/ddb_dumb.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/ddb_mono2stereo.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/ddb_shn.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/dsp_libsrc.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/ffap.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/ffmpeg.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/flac.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/gme.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/hotkeys.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/in_sc68.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/lastfm.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/m3u.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/mms.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/mp3.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/musepack.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/notify.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/nullout.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/opus.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/oss.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/pltbrowser_gtk2.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/psf.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/pulse.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/rg_scanner.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/shellexec.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/shellexecui_gtk2.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/sid.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/sndfile.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/supereq.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/tta.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/vfs_curl.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/vfs_zip.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/vorbis.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/vtx.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/wavpack.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/wildmidi.so
loading plugin /usr/lib/x86_64-linux-gnu/deadbeef/wma.so
starting plugin GTK2 user interface
starting plugin AAC player
starting plugin Adplug player
starting plugin ALAC player
starting plugin ALSA output plugin
starting plugin Album Artwork
starting plugin Audio CD player
starting plugin Converter
starting plugin Converter GTK2 UI
starting plugin dts decoder
starting plugin DUMB module player
starting plugin Mono to stereo
starting plugin Shorten player
starting plugin Resampler (Secret Rabbit Code)
starting plugin Monkey's Audio (APE) decoder
starting plugin FLAC decoder
starting plugin Game-Music-Emu player
starting plugin Hotkey manager
starting plugin SC68 player (Atari ST SNDH YM2149)
starting plugin last.fm scrobbler
starting plugin M3U and PLS support
starting plugin mms vfs
starting plugin MP3 player
starting plugin MusePack decoder
starting plugin OSD Notify
starting plugin Null output plugin
starting plugin Opus player
starting plugin OSS output plugin
starting plugin Playlist browser GTK2
starting plugin PSF player using Audio Overload SDK
starting plugin PulseAudio output plugin
starting plugin ReplayGain Scanner
starting plugin Shell commands
starting plugin Shellexec GTK2 UI
starting plugin SID player
starting plugin WAV/PCM player
starting plugin SuperEQ
starting plugin tta decoder
starting plugin cURL vfs
starting plugin ZIP vfs
starting plugin Ogg Vorbis decoder
starting plugin VTX player
starting plugin WavPack decoder
starting plugin WildMidi player
starting plugin WMA player
starting plugin stdio vfs
starting plugin FFMPEG audio player
streamer_set_output
selected output plugin: ALSA output plugin
INFO: from file /home/whell/.config/deadbeef/playlists/0.dbpl
INFO: from file /home/whell/.config/deadbeef/playlists/1.dbpl
resume: track 0 pos 6.282689 playlist 1
Failed to play track: /home/whell/Downloads/96k Bad Company - Run With The Pack/A1 Live For The Music.flac
gtkui plugin compiled for gtk version: 2.24.31
Segmentation Fault
backtrace() returned 5 addresses
deadbeef(+0x348aa) [0x5642383178aa]
/lib/x86_64-linux-gnu/libc.so.6(+0x33060) [0x7f0b1ff97060]
deadbeef(+0x46169) [0x564238329169]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x74a4) [0x7f0b2030a4a4]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x3f) [0x7f0b2004cd0f]
