MX-17/MX-18.1: WARNING: GNOME's "Contacts" application installs the libzeitgeist
MX-16_fan
#1 Post by MX-16_fan »
EDIT: Added "MX-18.1" to heading, as this problem persists with the version that ships with MX-18.1 (3.22.1-1+b2).
@all:
I've noticed that when you install Contacts (package: gnome-contacts), "GNOME's integrated address book" (https://wiki.gnome.org/Apps/Contacts), you also allow the intrusion of a part of the zeitgeist system into your OS.
Just wanted to let you know.
See a different discussion about the libzeitgeist and Empathy here: viewtopic.php?f=108&t=44459.
Greetings, Joe
MX-16_fan
Re: MX-17/MX-18.1: WARNING: GNOME's "Contacts" application installs the libzeitgeist
#2 Post by MX-16_fan »
@Stevo:
Would it be possible to remove this dependency? Greetings, Joe
