[Solved]Horizontal line under Cairo Dock
lovelorn
#1 Post by lovelorn »
Hi There
I installed MX Linux last night and did some tweaks , installed some apps and a Cairo Dock
But when I open Cairo Dock , A horizontal line appears on my entire screen just like this :
And when I close Cairo Dock , The HR line disappears ......
I thought it might be a graphics problem so I installed nVidia driver by MX nVidia installer
What I should I do to still use Cairo Dock , but get rid of this annoying line ?
  Host: amd Kernel: 4.19.0-1-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
  Desktop: Xfce 4.12.3 Distro: MX-18.1_x64 Continuum Feb 9  2019
  Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
  Mobo: ASUSTeK model: H81M-C v: Rev X.0x serial: <filter>
  BIOS: American Megatrends v: 2202 date: 10/27/2014
  Topology: Dual Core model: Intel Pentium G3220 bits: 64 type: MCP
  arch: Haswell rev: 3 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11973
  Speed: 1397 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 798 2: 798
  Device-1: NVIDIA GT218 [GeForce G210] driver: nvidia v: 340.107
  bus ID: 01:00.0
  Display: x11 server: X.Org 1.19.2 driver: nvidia resolution: 1366x768~60Hz
  OpenGL: renderer: GeForce G210/PCIe/SSE2 v: 3.3.0 NVIDIA 340.107
  Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Device-2: NVIDIA High Definition Audio driver: snd_hda_intel v: kernel
  bus ID: 01:00.1
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 03:00.0
  IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
  Local Storage: total: 1.82 TiB used: 398.99 GiB (21.4%)
  ID-1: /dev/sda vendor: Toshiba model: DT01ACA100 size: 931.51 GiB
  ID-2: /dev/sdb type: USB vendor: Western Digital
  model: WD My Passport 259F size: 931.48 GiB
  ID-1: / size: 383.49 GiB used: 8.04 GiB (2.1%) fs: ext4 dev: /dev/sda3
  ID-2: swap-1 size: 4.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 60 C
  Fan Speeds (RPM): cpu: 0
  1: deb http://ftp.ir.debian.org/debian/ stretch-updates main contrib non-free
  1: deb http://ftp.ir.debian.org/debian/ stretch main contrib non-free
  1: deb https://mirror.ps.kz/mx/packages/mx/repo/ stretch main non-free
  1: deb https://deb.opera.com/opera-stable/ stable non-free #Opera Browser (final releases)
  1: deb http://repo.vivaldi.com/stable/deb/ stable main
  Processes: 205 Uptime: 2h 33m Memory: 3.79 GiB used: 1.88 GiB (49.4%)
  inxi: 3.0.29
Thanks
manyroads
Re: Horizontal line under Cairo Dock
#2 Post by manyroads »
You have a compositor setting that allows/creates/provides desktop/ panel shadows. Turn that off and your problem should disappear.
lovelorn
#3 Post by lovelorn »
Thank You a lot , Sir
I removed compositor effect and now it's fixed .... Just can I ask You another question ?
I don't experience screen distortion any more , But last night when I was installing apps , On every installation , screen froze , App menu was opening up and screen distort for a while ..... Can that relate to GPU ?
#4 Post by richb »
First, please start another thread for your mounting question.
Second, Please mark this thread {Solved] by adding it to the first post title.
You should always start a new thread for a different help topic.
lovelorn
#5 Post by lovelorn »
Ok , Sir
Return to “MX Modified”
