Viewing Code
- Gordon Cooper
Viewing Code
I'm having trouble reading the boxes of code included in posts. The text is faint - very. Does it have to be pale blue/grey?
Re: Viewing Code
I have the same problem. Currently I'm experimenting with changing the colors that are used by my Browser. A sample of one is attached.
--Mark Twain
--Mark Twain
Re: Viewing Code
Here's what they use on the Debian forum: http://forums.debian.net/viewtopic.php?p=551566#p551566 (green text on white background)
- Gordon Cooper
Re: Viewing Code
Glad I'm not the only one. Not too sure about the red on black, although it's easy to read. Will also experiment.
Edit: Does anyone know which Style is being used here? There's a lot of options available for phpBB.
Re: Viewing Code
I'm sure it is in the ACP somewhere to which Richb and I have access. Will look, Rich may already know.
Looks like we are using Getaway for the overall style, but I don't see a detailed setting for something like code.
Re: Viewing Code
I'd be happier if when code is indicated it would call up geany if one has it,
and dislplay it that way. But I do have trouble with pale blue-gray.
64-bit MX -19.1 Samsung LiveUSB on Dell quad-core laptop
- Gordon Cooper
Re: Viewing Code
Had quick look at php's site. Found one style with a comment about users being able to alter colours but unsure if that meant
individuals or forum administrators. Will look again when there's more time.
Edit: In another Topic, Lucky9 wrote "I've never had a problem keeping several Browsers around." That may be
an answer to this problem, set up another browser for the MX Forum with different display settngs.
Re: Viewing Code
the antiX boards at antix.freeforums.org allow users to set a theme that takes effect while logged in. My personal fav over there is a green and black theme. of course, the software probably isn't the same, but it sure looks similar.
Re: Viewing Code
It is Getaway. There are two other options that can be set by admin, prosilver and subsilver2. Peregrine needs to verify, but as I recall, not all the modifications we added to the forum software will run properly with these two other themes. Also I am not sure they are any better.,
For those having difficulty, there are several browser extensions to adjust color.
Re: Viewing Code
the antiX boards have a ton of user-selectable themes. This is a screen shot of mine. sure makes code easy to see.
