Thunar hangs and lost Custom Actions
Re: Thunar hangs and lost Custom Actions
what, if anything, is running your desktop display? (thunar, zzzfm, something else, nothing?)
another things to check, especially since libgtk3.0 updated, is anything overriding gtk client side decorations or other gtk libraries. doesn't matter that thunar doesn't use them.
possibly a thumbnailer out of control, but that should show up in htop/top with a cpu consuming process (unlikely)
Not sure of the timing of the issue 26,27,28th but that with that apt list should give the application that broke it? Or did you make a new custom action in that timeline? All things you’ve most likely covered though.
If you wish to share that I’ll see if it breaks mine
No Desktop 'manager' XFCE4+Openbox w Nitrogen handling Wallpaper..dolphin_oracle wrote: ↑Mon Mar 28, 2022 1:21 pm what, if anything, is running your desktop display? (thunar, zzzfm, something else, nothing?)
Yes!dolphin_oracle wrote: ↑Mon Mar 28, 2022 1:29 pm another things to check, especially since libgtk3.0 updated, is anything overriding gtk client side decorations or other gtk libraries. doesn't matter that thunar doesn't use them.
If I open Thunar which I've noticed sometimes will let me open a folder or two before locking up once it goes unresponsive it's consuming 100% CPU in top
@Steve
I appreciate the offer of help but this isn't a straight up AVL-MXE install here, It's my main Desktop used to make AVL but it's a bit of a mutt upgraded manually from Buster so better just let me suffer the consequences... I'm hoping this issue is just on this system and not an AVL issue..
you might want to disable tumbler then and see if that helps.AVLinux wrote: ↑Mon Mar 28, 2022 1:45 pmYes!dolphin_oracle wrote: ↑Mon Mar 28, 2022 1:29 pm another things to check, especially since libgtk3.0 updated, is anything overriding gtk client side decorations or other gtk libraries. doesn't matter that thunar doesn't use them.
Plot thickens..
Overkill perhaps but I removed tumbler completely (Geez googling disabling tumbler shows a lot of people unhappy with it!). Anyway... Rebooted and same problem even with tumbler out of the picture.. This issue is pushing me further into the loving arms of LXDE!
Gotta run a few errands, I'll check back later and do some more googling, thanks so far!!
welp, not tumbler then.
If I were a betting man I’d put my money on zzzfm messing with a library thunar is using. But I’m not. I’d lose to much.
