Forum users
  • Please read this before asking for help, and don't forget to add Quick System Info to help requests!
  • Please follow the Forum Rules
--MX-21 release info here
--Migration information to MX-21 here
--antiX-21 (Grup Yorum) release info here
Where is OpenSnitch? [solved]
siamhie
Re: Where is OpenSnitch?
#11 Post by siamhie »
mx2kx1k wrote: Tue Nov 30, 2021 2:12 am plans for update? now is v1.4.3 ...
Would be great...
Thx
You still haven't provided the QSI (aka Quick System Info) everyone is asking for.
Here's what mine looks like...Just paste the contents to your post, it's preformatted.
System:    Host: <filter> Kernel: 5.15.0-1mx-amd64 x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.15.0-1mx-amd64
           root=UUID=<filter> ro splash quiet
           init=/lib/systemd/systemd
           Desktop: Fluxbox 1.3.7 dm: LightDM 1.26.0 Distro: MX-21 Fluxbox Wildflower
Machine:   Type: Desktop System: ASUSTeK product: K30BF_M32BF_A_F_K31BF_6 v: N/A
           serial: <filter>
           Mobo: ASUSTeK model: K30BF_M32BF_A_F_K31BF_6 v: Rev X.0x serial: <filter>
           UEFI: American Megatrends v: 0401 date: 04/29/2015
Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
           charge: 55% (should be ignored) rechargeable: yes status: Discharging
           Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360 serial: <filter>
           charge: 100% (should be ignored) rechargeable: yes status: Discharging
CPU:       Topology: Quad Core model: AMD A10-7800 Radeon R7 12 Compute Cores 4C+8G bits: 64
           type: MCP arch: Steamroller family: 15 (21) model-id: 30 (48) stepping: 1
           microcode: 6003106 L2 cache: 2048 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 27930
           Speed: 1431 MHz min/max: 1400/3500 MHz boost: enabled Core speeds (MHz): 1: 2336
           2: 2035 3: 2109 4: 2255
           Vulnerabilities: Type: itlb_multihit status: Not affected
           Type: spec_store_bypass
           mitigation: Speculative Store Bypass disabled via prctl and seccomp
           Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics:  Device-1: AMD Kaveri [Radeon R7 Graphics] vendor: ASUSTeK driver: radeon v: kernel
           bus ID: 00:01.0 chip ID: 1002:130f
           Device-2: AMD Oland PRO [Radeon R7 240/340] vendor: ASUSTeK driver: radeon v: kernel
           bus ID: 01:00.0 chip ID: 1002:6613
           Display: x11 server: X.Org 1.20.13 driver: ati,radeon
           unloaded: fbdev,modesetting,vesa compositor: compton v: 1 resolution: 1920x1080~60Hz
           OpenGL: renderer: AMD OLAND (DRM 2.50.0 5.15.0-1mx-amd64 LLVM 12.0.1)
           v: 4.5 Mesa 21.2.5 direct render: Yes
Audio:     Device-1: AMD Kaveri HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 00:01.1 chip ID: 1002:1308
           Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 00:14.2 chip ID: 1022:780d
           Device-3: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series]
           vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 1002:aab0
           Sound Server: ALSA v: k5.15.0-1mx-amd64
Network:   Device-1: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave
           driver: rtl8821ae v: kernel port: d000 bus ID: 04:00.0 chip ID: 10ec:8821
           Device-2: NetGear Nighthawk A7000 802.11ac Wireless Adapter AC1900 [Realtek 8814AU]
           type: USB driver: 8814au bus ID: 2-2:2 chip ID: 0846:9054 serial: <filter>
           IF: wlan1 state: up mac: <filter>
Drives:    Local Storage: total: 1.36 TiB used: 584.79 GiB (41.9%)
           ID-1: /dev/sda vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB block size:
           physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
           rev: CC43 temp: 28 C scheme: MBR
           ID-2: /dev/sdb vendor: Samsung model: SSD 870 EVO 500GB size: 465.76 GiB block size:
           physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 1B6Q scheme: GPT
Partition: ID-1: / raw size: 130.00 GiB size: 126.90 GiB (97.62%) used: 11.81 GiB (9.3%)
           fs: ext4 dev: /dev/sdb3
           ID-2: /home raw size: 100.00 GiB size: 97.87 GiB (97.87%) used: 13.73 GiB (14.0%)
           fs: ext4 dev: /dev/sdb4
           ID-3: swap-1 size: 4.00 GiB used: 0 KiB (0.0%) fs: swap swappiness: 15 (default 60)
           cache pressure: 100 (default) dev: /dev/sdb2
Sensors:   System Temperatures: cpu: 3.9 C mobo: N/A
           GPU: device: radeon temp: 0 C device: radeon temp: 33 C
Repos:     No active apt repos in: /etc/apt/sources.list
           1: deb http://deb.debian.org/debian/ bullseye-updates main contrib non-free
           1: deb http://deb.debian.org/debian/ bullseye main contrib non-free
           2: deb http://security.debian.org/debian-security/ bullseye-security main contrib non-free
           1: deb http://la.mxrepo.com/mx/repo/ bullseye main non-free
           2: deb http://la.mxrepo.com/mx/repo/ bullseye ahs
Info:      Processes: 182 Uptime: 21m Memory: 14.66 GiB used: 1009.3 MiB (6.7%) Init: systemd
           v: 247 runlevel: 5 default: 5 Compilers: gcc: 10.2.1 alt: 10 clang: 11.0.1-2
           Shell: quick-system-in running in: quick-system-in inxi: 3.0.36
My comment was directed to @hkjz
This is my Fluxbox . There are many others like it, but this one is mine. My Fluxbox is my best friend. It is my life.
I must master it as I must master my life. Without me, my Fluxbox is useless. Without my Fluxbox, I am useless.
hugastaga
#12 Post by hugastaga »
I am sorry for forgetting the forum rules too soon. Now I know better.
Solution for me was changing MX repo to US Los Angeles.
When I get into trouble next time, I'll use Quick System Info too.
JayM
Qualified MX Guide
#13 Post by JayM »
If this is solved to your satisfaction, could you please mark the topic as solved by clicking the button with a checkmark icon next to the post containing the solution? Instructions are here. This will make it easier for others when they search the forum looking for a solution to the same problem. Thanks.
Eadwine Rose
#14 Post by Eadwine Rose »
Unfortunately s/he can't. There are multiple people in this thread who should have started their own topic, this last one is not the topic starter.
MX-21.3_x64 Oct20 '21 * 5.10.0-20-amd64 ext4 Xfce 4.18.0 * 8-core AMD Ryzen 7 2700
Asus TUF B450-Plus Gaming UEFI * Asus GTX 1050 Ti Nvidia 470.161.03 * 2x16Gb DDR4 2666 Kingston HyperX Predator
hkjz
#15 Post by hkjz »
SwampRabbit wrote: Mon Nov 29, 2021 6:33 pm
IF that fails...
- Use MX Repo Manager to switch to the LA or Salt Lake repo
- Do the above again
IF that fails...
Post the following:
- FULL Quick System Information
- Console Output (last tab) in MX Package Installer
Oddly enough,
in MX Repo Manager, in MX Repos tab,
I choose LA for example, click apply, get information :Success - your new selection will take effect the next time sources are updated, and then button comes back to Vietnam.
fehlix wrote: Mon Nov 29, 2021 11:19 pm As you preferred to disabled mx repository according to the other thread to solve a temporary repo issue ( viewtopic.php?p=664593#p664593 ) you won't see if you keep mx.list disabled.
but when i check in MX repo : individual sources : mx.list : deb [...] main non-free, and update&&upgrade, i got this error
$ sudo apt update && sudo apt dist-upgrade
Err:1 https://repo.nordvpn.com/deb/nordvpn/debian stable InRelease
  Could not resolve 'repo.nordvpn.com'
Hit:2 https://updates.signal.org/desktop/apt xenial InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://deb.debian.org/debian bullseye InRelease
Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
Hit:6 http://deb.debian.org/debian bullseye-backports InRelease
Ign:7 http://repo.vivaldi.com/stable/deb stable InRelease
Hit:8 http://repo.vivaldi.com/stable/deb stable Release
Err:10 https://mirror.freedif.org/MXLinux/repo/mx/repo bullseye InRelease
  Could not connect to mirror.freedif.org:443 (113.161.52.138), connection timed out
Reading package lists... Done
Building dependency tree... Done
All packages are up to date.
W: Failed to fetch https://mirror.freedif.org/MXLinux/repo/mx/repo/dists/bullseye/InRelease  Could not connect to mirror.freedif.org:443 (113.161.52.138), connection timed out
W: Failed to fetch https://repo.nordvpn.com/deb/nordvpn/debian/dists/stable/InRelease  Could not resolve 'repo.nordvpn.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
if it is UN-checked i have this
$ sudo apt update && sudo apt full-upgrade
Hit:1 https://updates.signal.org/desktop/apt xenial InRelease
Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
Hit:3 https://repo.nordvpn.com/deb/nordvpn/debian stable InRelease
Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
Hit:5 http://deb.debian.org/debian bullseye InRelease
QSI
System:    Host: <filter> Kernel: 5.10.0-9-amd64 x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/antiX/vmlinuz quiet splasht nosplash persist_all
           Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 dm: LightDM 1.26.0
           Distro: MX-21_x64 Wildflower October 20  2021 base: Debian GNU/Linux 11 (bullseye)
Machine:   Type: Desktop Mobo: Micro-Star model: Z370-A PRO (MS-7B48) v: 1.0 serial: <filter>
           UEFI: American Megatrends v: 2.70 date: 08/03/2018
CPU:       Topology: 6-Core model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Kaby Lake
           family: 6 model-id: 9E (158) stepping: A (10) microcode: 96 L2 cache: 12.0 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 76799
           Speed: 800 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
           5: 800 6: 800 7: 800 8: 800 9: 801 10: 800 11: 800 12: 800
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: mds
           status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
           STIBP: conditional, RSB filling
           Type: srbds status: Vulnerable: No microcode
           Type: tsx_async_abort
Graphics:  Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: Micro-Star MSI driver: N/A
           bus ID: 01:00.0 chip ID: 10de:1b82
           Display: x11 server: X.Org 1.20.11 driver: nouveau,vesa unloaded: fbdev,modesetting
           alternate: nv resolution: 1280x1024~77Hz
           OpenGL: renderer: llvmpipe (LLVM 11.0.1 256 bits) v: 4.5 Mesa 20.3.5 compat-v: 3.1
Audio:     Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
           v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
           Device-2: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
           driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f0
           Sound Server: ALSA v: k5.10.0-9-amd64
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
           vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus ID: 03:00.0
           chip ID: 10ec:8168
Drives:    Local Storage: total: 143.39 GiB used: 9.48 GiB (6.6%)
           ID-1: /dev/sda type: USB vendor: SanDisk model: Ultra USB 3.0 size: 114.56 GiB
           block size: physical: 512 B logical: 512 B serial: <filter> rev: 1.00 scheme: MBR
           ID-2: /dev/sdb type: USB vendor: Kingston model: DataTraveler 3.0 size: 28.83 GiB
           block size: physical: 512 B logical: 512 B serial: <filter> rev: 1100 temp: 7 C
           scheme: MBR
Partition: ID-1: / raw size: N/A size: 12.40 GiB used: 2.26 GiB (18.2%) fs: overlay
           source: ERR-102
Sensors:   System Temperatures: cpu: 35.0 C mobo: N/A
           3: deb-src http://deb.debian.org/debian bullseye main contrib non-free
           4: deb http://deb.debian.org/debian bullseye-backports main contrib non-free
           No active apt repos in: /etc/apt/sources.list.d/mx.list
           Active apt repos in: /etc/apt/sources.list.d/nordvpn.list
           1: deb https://repo.nordvpn.com/deb/nordvpn/debian stable main
           Active apt repos in: /etc/apt/sources.list.d/signal-xenial-added-by-mxpi.list
           1: deb [arch=amd64] https://updates.signal.org/desktop/apt xenial main
           1: deb [arch=amd64] http://repo.vivaldi.com/stable/deb/ stable main
Info:      Processes: 300 Uptime: 21m Memory: 15.58 GiB used: 1.94 GiB (12.4%) Init: SysVinit
           v: 2.96 runlevel: 5 default: 5 Compilers: gcc: 10.2.1 alt: 10 Shell: quick-system-in
#16 Post by fehlix »
hkjz wrote: Wed Dec 01, 2021 9:45 am
Disabling mx repos (mx.list) might create a lot of confusion.
Suggest this:
* Open MX Repo Manager
* Enable mx.list again in "Individual Sources" tab
* manually select closest mx repo in "MX Repos" tab (e.g in Europe either Italy/Milan or Netherlands/Ablasserdam
* reload package lists either on command line
sudo apt update
or
* Right-click on MX Updater icon and "Check for Updates"
The one you have selected above and failed to load is the last in the list of "mx repos" and might caused as a side effect of disabling mx.list in the first place or just b/c it could not find the fastest and keeping the last.
SwampRabbit
#17 Post by SwampRabbit »
While you’re adjusting repos, you should disable
This shouldn’t be manually enabled as it can lead to issues, if you want to install things from backports use MX Package Installer > Backports tab.
hkjz
#18 Post by hkjz »
fehlix wrote: Wed Dec 01, 2021 1:20 pm Disabling mx repos (mx.list) might create a lot of confusion.
Suggest this:
sudo apt update
or
SwampRabbit wrote: Wed Dec 01, 2021 1:49 pm While you’re adjusting repos, you should disable
did both, enabled, disabled, i could mark right mirror as well, somehow ALL works properly now,
it works, thanks
Machine:   Type: Desktop Mobo: ASUSTeK model: PRIME B250M-K v: Rev X.0x serial: <filter>
           UEFI: American Megatrends v: 0809 date: 07/07/2017
CPU:       Topology: Quad Core model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
           family: 6 model-id: 9E (158) stepping: 9 microcode: 5E L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 24000
           Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
           Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
           Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
           Type: spec_store_bypass status: Vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Graphics:  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: N/A
           bus ID: 01:00.0 chip ID: 10de:1c82
Audio:     Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel
           Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
           v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
           Device-3: Pixart Imaging GE 1.3 MP MiniCam Pro type: USB
           driver: snd-usb-audio,uvcvideo bus ID: 1-7:3 chip ID: 093a:2700
           vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: d000 bus ID: 03:00.0
           chip ID: 10ec:8168
           IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives:    Local Storage: total: 28.83 GiB used: 10.42 GiB (36.2%)
           ID-1: /dev/sda type: USB vendor: Kingston model: DataTraveler 3.0 size: 28.83 GiB
           block size: physical: 512 B logical: 512 B serial: <filter> rev: 1100 scheme: MBR
Partition: ID-1: / raw size: N/A size: 12.40 GiB used: 2.86 GiB (23.1%) fs: overlay
           source: ERR-102
Sensors:   System Temperatures: cpu: 29.8 C mobo: 27.8 C
           1: deb http://it.mxrepo.com/mx/repo/ bullseye main non-free
Info:      Processes: 236 Uptime: 14m Memory: 15.58 GiB used: 1.83 GiB (11.7%) Init: SysVinit
Return to “MX Repositories”
