SOLVED..Needing Help Please..(initramfs)
Re: Needing Help Please..(initramfs)
#11
Post by timkb4cq » Tue Aug 13, 2019 4:53 pm
Turns out the google-earth message is just a warning, not an error
You'll have to delete the corrupted cache. A successful apt-update will rebuild it. So run
sudo rm -rf /var/lib/apt/lists/*
sudo apt update
To get rid of the annoying google-earth warning use Thunar to navigate to /etc/apt/ and Right-Click -> Edit as Root on sources.list
In the google-earth line, between the deb and https:// insert [arch=amd64] (yes, the brackets are to be typed).
Save the file and the next sudo apt-update the warning will be gone.
CaptED71
#12
Post by CaptED71 » Tue Aug 13, 2019 5:48 pm
Thank You Timkb4cq...
That did the trick ... Heading up to mark it SOLVED..
Again Thank You
Ed
Ancient_Hermit
Re: SOLVED..Needing Help Please..(initramfs)
#13
Post by Ancient_Hermit » Tue Aug 13, 2019 7:00 pm
My thanks to you both. I shadowed some of this and got no errors, then got 4 updates.
They applied fine, I reckon I might be OK booting up in the am. Sure hope so because I'm not sure what I'll do if there is a problem! <eek>
Glad it turned out ok so far. Nice!
Cheers,
Ian
Return to “MX Help”
