Which kernel should I use ?
oops
Re: Which kernel should I use ?
#31
Post by oops » Thu Oct 04, 2018 2:39 am
Hierax_ca wrote:
Tue Oct 02, 2018 6:05 pm
FWIW, the MX Stable Repo now has the Debian LTS Kernel 4.9.0-8/4.9.110-3+debu5 (2018-09-30) for both 32- and 64-bit.
I also noticed that the Linux Kernel Archives (https://www.kernel.org/category/releases.html) have recently moved the 4.9 LTS EoL from 2019 to 2023 so it looks like there's a lot of life left in 4.9.x (vs. 4.14 which still expires in 2020).
Well seen. I fact, this topic is mostly interesting for the next LTS MX18/AntiX18 ... so the next défault MX18 kernel has to be a Long Time Support too.
Kulmbacher
#32
Post by Kulmbacher » Thu Oct 04, 2018 4:58 am
arky217 wrote:
Wed Oct 03, 2018 9:42 pm
...So, I guess I'll just continue using the 4.15 kernel unless I run into some problem,
and if so, I'll give the 4.9 kernel a try.
or just try them.
I had MX 4.15, installed Debian 4.9, both are now there!
Then choose the one you want to try in BootScreen (Advanced Options).
they called him, the fish!
#33
Post by anticapitalista » Thu Oct 04, 2018 6:25 am
The antiX kernels shown in MXPI are out of date.
https://antixlinux.com/l1tf-foreshadow- ... available/
#34
Post by dolphin_oracle » Thu Oct 04, 2018 6:33 am
Thanks...will update
lenovo ThinkPad T530 - MX-18
zorzi
#35
Post by zorzi » Thu Oct 04, 2018 8:11 am
arky217 wrote:
Wed Oct 03, 2018 7:19 pm
I am the original poster and I have read through all these posts
and I am still confused as to what to do.
Do I keep the MX kernel 4.15.0-1 or do I download and use the 4.9
kernel ?
If the 4.9 kernel, which one, the Debian, the AntiX, or the LiquorX ?
We can consider that, since its end of life, 4.15 kernel appears now as a bad security choice. 4.9 kernel is the better choice IMO.
Desktop: HP Pavilion a6435 (Athlon64 2x 2,6Ghz, Radeon R7-240, Ram 4 Go, HD 500 Go) / MX Linux 17
arky217
#36
Post by arky217 » Thu Oct 04, 2018 10:07 am
kernel ?
Well, I tried kernel 4.9 and everything seems ok; printers work, etc.
Question: Is there anyway to make the 4.9 kernel the default one
instead of selecting it every time I boot up ?
( I mean anyway other than uninstalling the 4.15 kernel)
#37
Post by dolphin_oracle » Thu Oct 04, 2018 10:09 am
MX-Boot-Options, choose your default boot entry.
namida12
#38
Post by namida12 » Thu Oct 04, 2018 12:40 pm
I am crashing on 4.17.4 & 4.18.7 often, am still using 4.15.14-antix.1-amd64-smp x86_64 for my Gen 1 Ryzen hardware.
Using Antix Package Installer for Kernel updates...
Kernel 4.18.7 will run fine overnight and longer if I do not use the system only seeding MX & Antix, but unfortunately system will crash when being used on internet, or office functions...
Kernel 4.15.14 will run for days...
Kernel 4.18.7 runs well on non Ryzen hardware...
JR
$ inxi -F
System:    Host: antix3 Kernel: 4.15.14-antix.1-amd64-smp x86_64 bits: 64 Desktop: IceWM 1.4.2
           Distro: antiX-17.1_x64-full Heather Heyer 17 March 2018
Machine:   Type: Laptop Mobo: MSI model: B350M GAMING PRO (MS-7A39) v: 1.0 serial: <root required>
           UEFI [Legacy]: American Megatrends v: 2.30 date: 03/24/2017
CPU:       Topology: Quad Core model: AMD Ryzen 5 1500X bits: 64 type: MT MCP L2 cache: 2048 KiB
           Speed: 1676 MHz min/max: 1550/3500 MHz Core speeds (MHz): 1: 1375 2: 1375 3: 1375 4: 1375 5: 1424
           6: 1433 7: 1411 8: 1432
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] RV670 [Radeon HD 3690/3850] driver: radeon v: kernel
           Display: server: X.Org 1.19.2 driver: ati,radeon unloaded: fbdev,modesetting,vesa
           resolution: 1920x1080~60Hz
           OpenGL: renderer: Gallium 0.4 on AMD RV670 (DRM 2.50.0 / 4.15.14-antix.1-amd64-smp LLVM 3.9.1)
           v: 3.3 Mesa 13.0.6
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] RV670/680 HDMI Audio [Radeon HD 3690/3800 Series]
           driver: snd_hda_intel
           Device-2: Advanced Micro Devices [AMD] driver: snd_hda_intel
           Sound Server: ALSA v: k4.15.14-antix.1-amd64-smp
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 18:d6:c7:06:f9:4a
Drives:    Local Storage: total: 232.89 GiB used: 132.62 GiB (56.9%)
           ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 13.72 GiB used: 7.79 GiB (56.8%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 205.70 GiB used: 124.83 GiB (60.7%) fs: ext4 dev: /dev/sda3
           ID-3: swap-1 size: 4.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 43.6 C mobo: N/A gpu: radeon temp: 84 C
Info:      Processes: 239 Uptime: 21h 22m Memory: 15.68 GiB used: 2.45 GiB (15.6%) Shell: bash inxi: 3.0.24
arky217
#39
Post by arky217 » Thu Oct 04, 2018 6:53 pm
I tried this and set it to 4.9, but it still boots to 4.15.
I tried it again and checked 'Enable saving last boot choice',
but it still boots to 4.9.
In fact, after I select 4.9 and check 'Enable saving last boot choice',
and close the MX boot options window and then immediately
open the MX boot options window again, my choice is not selected.
It keeps reverting to the first option 'MX 17 Horizon'.
Is that a bug, or am I overlooking something ?
Edit: Well, I got around this by using MX boot options to make
the grub menu 'flat' instead of 'tree' and then editing the grub
file directly and changing 'grub_default=saved' to 'grub_default=2'
which is the selection for kernel 4.9.
Then, of course, did a grub-update. Works now.
#40
Post by asqwerth » Thu Oct 04, 2018 11:53 pm
You didn't click on the APPLY button to get the update-grub process to run.
Return to “MX Help”
