Which kernel should I use ?
baldyeti
Re: Which kernel should I use ?
#21
Post by baldyeti » Fri Sep 28, 2018 5:33 am
oops wrote:
Fri Sep 28, 2018 5:16 am
Yes, version number is by CPU model.
Old examples: https://downloadcenter.intel.com/downlo ... a-File?v=t
thanks for that link, oops. So we all have the latest intel-provided microcode loaded, good to know.
zorzi
#22
Post by zorzi » Fri Sep 28, 2018 6:11 am
Stevo wrote:
Thu Sep 27, 2018 7:30 pm
oops wrote:
Thu Sep 27, 2018 6:11 pm
baldyeti wrote:
Thu Sep 27, 2018 6:05 pm
I've got the exact same intel microcode package installed, yet i am getting: microcode : 0x2e
... If so, it is probably not the latest one
Debian pushed the upstream version into Stretch as a security update, so 3.20180807a is going to be the latest:
https://packages.debian.org/search?keyw ... ection=all
I think just about all the latest threats you've seen for the kernels require that the hacker actually have physical access to your machine. If you're worried about Spectre and other similar exploits, you should be running the latest kernels we provide, or the Debian 4.9 kernel which gets updated. Unfortunately, backporting that newer kernel code to security patches for the 4.15 kernel is beyond our capabilities.
In fact, maybe unsupported kernels (4.13, 4.15...) should be removed from MX Repos after end of life. I suppose this requires a MX package installer update too, since MXPI still links to some of these kernels.
Desktop: HP Pavilion a6435 (Athlon64 2x 2,6Ghz, Radeon R7-240, Ram 4 Go, HD 500 Go) / MX Linux 17
Mauser
#23
Post by Mauser » Fri Sep 28, 2018 11:39 am
azrielle wrote:
Fri Sep 28, 2018 2:34 am
In light of recent revelation that NSA's security algorithm was incorporated into 4.17, 18, & 19, but will be removed in 20, I'd wait until a stable version of 4.20 came out!
I concur, but if you can it looks like switching to the Debian 4.9 kernel is the way to go in the mean time like what I did. With the NSA's (National Spy Agency) history they can't be trusted. Even if that NSA gift in the kernel is not enabled on Debian and MX Linux, what's going to stop the NSA from enabling it?
I am command line illiterate. :confused:
#24
Post by Stevo » Fri Sep 28, 2018 3:28 pm
Debian never enabled the NSA spec module, so it's not in any of those backported kernels. Liquorix did, but there aren't any userspace programs that use it, either.
#25
Post by Stevo » Fri Sep 28, 2018 3:31 pm
Even if the module is built, how exactly is the NSA supposed to reach out into your computer and "enable it"? If they can already do that to your machine, you have much bigger problems to worry about.
Hierax_ca
#26
Post by Hierax_ca » Tue Oct 02, 2018 6:05 pm
FWIW, the MX Stable Repo now has the Debian LTS Kernel 4.9.0-8/4.9.110-3+debu5 (2018-09-30) for both 32- and 64-bit.
I also noticed that the Linux Kernel Archives (https://www.kernel.org/category/releases.html) have recently moved the 4.9 LTS EoL from 2019 to 2023 so it looks like there's a lot of life left in 4.9.x (vs. 4.14 which still expires in 2020).
MX-17.1: Thinkpad x60t, x61t, x200t, x220t.
MX-18 (32-bit) Thinkpads: 600x*, A31p, T43p, T60p;
MX-18 (64-bit): MacBook13(5,1), Thinkpad x61s, T61pW, T601pF, x200, x301*, T500, W500, W700, W700ds, W701, W701ds*, x220, W520.
arky217
#27
Post by arky217 » Wed Oct 03, 2018 7:19 pm
I am the original poster and I have read through all these posts
and I am still confused as to what to do.
Do I keep the MX kernel 4.15.0-1 or do I download and use the 4.9
kernel ?
If the 4.9 kernel, which one, the Debian, the AntiX, or the LiquorX ?
#28
Post by dolphin_oracle » Wed Oct 03, 2018 8:14 pm
If you are really concerned and want to ensure automatic updates use the debian 4.9 and install from mx-packageinstaller.
Personally I use the default that ships with mx.
lenovo ThinkPad T530 - MX-18.3
lenovo s21e - antiX-19 beta 2 (live-USB)
Richard
#29
Post by Richard » Wed Oct 03, 2018 9:27 pm
This discussion brought up some questions concerning the large
variety of kernels available. I was curious as well about which kernel to use.
The 4.15 kernel runs fine with no problems. Also, the 4.18-MX kernel runs fine.
Even the latest 4.18-liquorix kernel runs very well and has some advantageous effects.
My main concern is heat on my older, reconditioned Lenovo T430.
My old 64bit desktop with MX ran about 10°C cooler than this laptop
when running the MX Snapshot utility. Probably just a laptop thing.
I usually point a fan at it while running MX Snapshot.
To that end, I installed several kernels and then ran the MX Snapshot utility
to observe the average temperatures during the first 6 to 10% or so.
Snapshot using only 2 of 4 threads.
The pairs of numbers represent the values from the Xfce4 Sensor plugin:
Snapshot Temps:	Core,°C		acpitz,°C	Fan, rpm	ACPI, °C
	idle temps<->snapping temps	etc.		etc		etc.
Click on the image below to make it legible.
Based on these results
I chose to use the 4.9 kernel since it ran cooler at idle and it as well as the others
passed the spectre-meltdown-checker with good results.
And maybe it is more secure during these interesting times.
Applying intel-pstate doesn't seem to have a beneficial effect on this processor.
Could be just pebkac.
All in all, we have a large selection of solid kernels. I didn't test the antiX kernels
although the 4.18 performed well and also passed the spectre-meltdown.
Real life got in the way. :)
Perhaps this data will be useful to someone.
Regards.
root@mx171:/home/richard# pinxi -Fxz
System:    Host: mx171 Kernel: 4.9.0-8-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
           Desktop: Xfce 4.12.3 Distro: MX-17.1_x64 Horizon March 14  2018
Machine:   Type: Laptop System: LENOVO product: 2347AY1 v: ThinkPad T430 serial: <filter>
           Mobo: LENOVO model: 2347AY1 v: NO DPK serial: <filter> UEFI [Legacy]: LENOVO
           v: G1ET73WW (2.09 ) date: 10/19/2012
Battery:   ID-1: BAT0 charge: 18.6 Wh condition: 18.8/56.2 Wh (34%) model: SANYO 45N1001
           status: Unknown
CPU:       Topology: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
           rev: 9 L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20750
           Speed: 1801 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1801 2: 1725 3: 1841
           4: 1933
Graphics:  Device-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
           bus ID: 00:02.0
           Display: x11 server: X.Org 1.19.2 driver: intel resolution: 1600x900~60Hz
           OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 3.3 Mesa 13.0.6
Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio driver: snd_hda_intel
           v: kernel bus ID: 00:1b.0
           Sound Server: ALSA v: k4.9.0-8-amd64
Network:   Device-1: Intel 82579LM Gigabit Network driver: e1000e v: 3.2.6-k port: 5080
           bus ID: 00:19.0
           Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi v: kernel
           port: efa0 bus ID: 03:00.0
Drives:    Local Storage: total: 148.30 GiB used: 82.12 GiB (55.4%)
           ID-1: /dev/mmcblk0 model: SA32G size: 29.05 GiB block size: physical: 512 B logical: 512 B
           ID-2: /dev/sda vendor: Samsung model: SSD 840 PRO Series size: 119.24 GiB block size:
           Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7740H rev: 1.S1 dev-links: cdrom,cdrw,dvd,dvdrw
           Features: speed: 62 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram
           state: running
Partition: ID-1: / raw size: 21.00 GiB size: 20.54 GiB (97.83%) used: 11.49 GiB (55.9%) fs: ext4 dev: /dev/sda2
           label: MX171
           ID-2: /DATA raw size: 98.25 GiB size: 96.20 GiB (97.92%) used: 70.63 GiB (73.4%) fs: ext4
           dev: /dev/sda1 label: DATA
Sensors:   System Temperatures: cpu: 62.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 3994
Info:      Processes: 232 Uptime: 3h 45m Memory: 7.49 GiB used: 2.22 GiB (29.6%) Init: SysVinit
           runlevel: 5 Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12 pinxi: 3.0.26-1
LT: MX18.3: Thinkpad T430: DualCore, Intel i5-3320M, Ivy Bridge; 8GB RAM; 4.19.0-5-amd64; 119GB SSD 840PRO, Intel Graphics-Audio-Network
NB: MX18.1, antiX19b2full: AsusTek EeePC 1005HA: Intel DualCore Atom N270, 1GB RAM, 4.19.0-1-686, 150GB HDD
arky217
#30
Post by arky217 » Wed Oct 03, 2018 9:42 pm
I haven't had any problems with the 4.15.0-1 kernel thus far.
(Well, I had some printer recognition problems, but I managed to fix those,
except the one I described under my post "Printer not working on installed snapshot".)
So, I guess I'll just continue using the 4.15 kernel unless I run into some problem,
and if so, I'll give the 4.9 kernel a try.
Thank you for the advice.
Return to “MX Help”
