Request: Latest MAME
Raitsa
Post by Raitsa » Fri Sep 21, 2018 4:55 am
Hi guys, I am hoping the latest MAME (0.201) gets added to the MX 17 repository.
https://github.com/mamedev/mame/releases
Re: Request: Latest MAME
Post by Stevo » Fri Sep 21, 2018 6:34 pm
I can try rebuilding the Debian Experimental 0.201 version.
Post by Stevo » Fri Sep 21, 2018 7:44 pm
Update: this is one of the ones that fails to build in my convenient and faster pbuilder setup, but it did succeed on the first 64-bit build in Virtual Box after a long compile process. Now setting up a 32-bit build.
Post by Stevo » Sat Sep 22, 2018 2:24 pm
32-bit builds fail, which I seem to remember they also did years ago, with a "virtual memory exhausted: can not allocate memory" error, even though they are using real memory in Virtual Box. The 0.200 version in Buster also fails the same way. Trying an OBS build to see what happens there: https://build.opensuse.org/package/show ... ports/mame
For now, I'll send up the 64-bit 0.201 builds to the test repo.
Raitsa
Post by Raitsa » Sat Sep 22, 2018 3:07 pm
Excellent, thanks a LOT Stevo, MX sure is a great distro.
Donated.
Raitsa
Post by Raitsa » Thu Dec 27, 2018 4:31 pm
Hey there Stevo, I am hoping to see MAME 0.205 update in the repos because of these very cool release infos:
"There are hundreds more Commodore 64 cassettes in the software list now"
https://www.mamedev.org/releases/whatsnew_0205.txt
Post by Stevo » Thu Dec 27, 2018 5:39 pm
Debian upstream just has .203, but I see that deb-multimedia has .205, so maybe I can rebuild those sources.
Raitsa
Post by Raitsa » Fri Dec 28, 2018 6:50 am
Sounds really great stevo, here is hoping this succeeds :)
Post by Stevo » Fri Dec 28, 2018 4:37 pm
Well, I tried getting the newer 0.205 source with a "get-orig-source" in the 0.201 debian/rules file, which worked, but when I tried using the 0.203 debian folder as a template for 0.205, builds failed in pbuilder, sbuild, and Virtual Box with some compiler errors.
Let me see if I can at least build 0.203 before I tackle converting 0.205 from deb-multimedia.
Raitsa
#10
Post by Raitsa » Thu Jan 03, 2019 7:03 pm
Would it be possible to have Negatron, an intuitive front-end for MAME on the repos as well?
http://babelsoft.net/products/negatron.htm
