How to upgrade Gimp to version 2.10
Re: How to upgrade Gimp to version 2.10
#11
Post by Stevo » Sun Sep 09, 2018 3:48 pm
In the future, instead of just removing the gimp package to downgrade, you need to remove all its other parts, too, such as libgimp. This can be done with
sudo apt-get remove *gimp*
or using the Status (installed) and search (gimp) features in Synaptic if you want a GUI.
vinoman
#12
Post by vinoman » Sun Sep 09, 2018 3:59 pm
Thanks for letting me know.
Moltke
#13
Post by Moltke » Mon Oct 08, 2018 5:03 pm
vinoman wrote:
Sun Sep 09, 2018 1:12 pm
reinstalled and was able to install gimp 2.10. Thanks :)
Glad you solved it! For anyone else trying to install/update gimp to its latest version - 2.10.6 at the moment - I did via flatpak as suggested on gimp's site https://www.gimp.org/downloads/
Without each other's help there ain't no hope for us :happy:
Eadwine Rose
#14
Post by Eadwine Rose » Tue Oct 09, 2018 3:37 am
No need to use flatpak. We have it in our test repos.
viewtopic.php?p=460135#p460135
MX-18.3_x64 May 26 2019 * 4.19.0-5-amd64 ext4 Xfce 4.12.3 * 8-core AMD Ryzen 7 2700
Asus TUF B450-Plus Gaming UEFI * Asus GTX 1050 Ti Nvidia 390.116 * 2x16Gb DDR4 2666 Kingston HyperX Predator
Samsung 860EVO * Samsung S24D330 & P2250 * HP Envy5030
Moltke
#15
Post by Moltke » Tue Oct 09, 2018 3:22 pm
I know "there's no" need to use flatpak, I was simply pointing out the fact that you can install it that way. And for the record, I'd have used the test repo method if 'd known but I didn't till I found this thread.
TTwrs
#16
Post by TTwrs » Fri Oct 12, 2018 5:56 pm
I'm using MX 16.1. How can I upgrade Gimp to 2.10.6. The latest version in the test repo is 2.8.22. Also, I prefer using Synaptic because it maintains a log of changes, whereas I don't think the MX Package Installer doesn't (at least not in the same place?).
#17
Post by Stevo » Fri Oct 12, 2018 6:55 pm
The build-dependencies for a newer GTK 3 than we have available in MX 15 prevented me from building it for that release. We do have flatpak available for MX 15, so you could try the GIMP flatpack. There are also AppImages, but some things may not work in those, or so I've read.
You can read the apt history log in the MX updater UI. Programs that installed outside the apt system won't appear in the log; flatpaks for example.
Moltke
#18
Post by Moltke » Wed Oct 24, 2018 6:08 pm
I updated Gimp from the test repo and it doesn't open anymore. The flatpak version does but the one from the test repo doesn't.
#19
Post by Stevo » Wed Oct 24, 2018 6:50 pm
Try removing all parts of gimp:
sudo apt remove *gimp*
Then reinstalling gimp from the test repo. If that doesn't work, does running "gimp" in the terminal show any errors?
Moltke
#20
Post by Moltke » Wed Oct 24, 2018 7:33 pm
Yes, it does return an error
gimp: symbol lookup error: /usr/lib/x86_64-linux-gnu/libgegl-0.4.so.0: undefined symbol: babl_format_with_space
